radio / vario interference - HELP!
Old October 25th 03, 07:15 PM
Chris Davison
Default radio / vario interference - HELP!
A problem with interference, all advice welcome.
..radio by itself works fine...but when I turn the
vario on I get huge amounts of noise (even some with
Squelch ON). Radio is a Dittel FSG50, vario is Cambridge
302/303.
Where do I start looking?
Chris
Old October 26th 03, 03:37 AM
JJ Sinclair
Hi Chris,
I just went through this (breaking squelch) problem with my Borgelt B-100 and I
found some very interesting things:
1. When the NMEA cable from the cambridge GPS was moved near the radio antenna
cable, I got full squelch. Move it away and the squelch went silent.
2. When the cable going to the LCD display was moved near the antenna cable, I
My fix was to move the antenna cable (RG-58) to the other side of the
instrument panel and routed it out the right side, about 12 inches AWAY from
all the other cables.
JJ Sinclair
Old October 26th 03, 01:49 PM
Richard Pfiffner
Chris,
All cables are not equal. Make sure you have a shielded cable with ferrite
supressor.
Richard
www.craggyaero.com
"Chris Davison" wrote in message
302/303.
Chris
Old October 26th 03, 11:30 PM
HL Falbaum
Solved same problem with 302/303 and Dittel FSG70M by rerouting the cable
from 302 to 303 (display). Turn everything on, squelch off and get teh
noise. Then start unplugging cables-start with the 302 to 303 cable. As soon
as the noise quits, you have found it!
Good luck!
Hartley Falbaum
ASW27B "KF" USA
302/303.
Chris
Old October 27th 03, 09:20 PM
Ian Forbes
.radio by itself works fine...but when I turn the vario on I get huge
amounts of noise (even some with Squelch ON). Radio is a Dittel FSG50,
vario is Cambridge 302/303.
Chris
I had a similar, but much worse problem, with an early 2 channel Magellan
GPS about 10 years ago. The GPS was mounted in a bracket on the panel of
my Nimbus II. The antenna was remote mounted on top of the instrument
panel with a foot long extension cable. There was a power cable with an
integral DC regulator which plugged into a 12V power socket that I fitted
behind the panel.
The interference was so bad that it would break through the squelch on the
radio of the glider lined up behind me on the start grid!
I eventually fixed it by wrapping both the antenna cable and the power
cable with steel wool (the stuff Grandma used for cleaning pots in the
kitchen). I pulled a large size shrink wrap over the wool and shrunk it in
place. The result was two rather ugly cables of nearly 1 inch diameter -
but no interference!
The 2 channel GPS had a habit of loosing the satellites in a thermal but
on the glides it would lock in and give a readout within a minute or so.
It cost me a small fortune at the time but was much less than price of a
more sophisticated unit. Compared to map reading it was great! I flew many
thousands of km with that setup.
Ian
GPS / radio interference Cub Driver Piloting 2 October 31st 04 10:57 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Radio Interference Information Ross Richardson Piloting 0 October 17th 03 02:06 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
