Thoughts on panel upgrade?
Old January 30th 17, 08:59 PM posted to rec.aviation.soaring
Paul[_10_]
Default Thoughts on panel upgrade?
Thanks for all the input! I'm really glad to hear my vario should still be able to function OK (not hobbled by old pressure transducers or slow CPU).
My Kobo isn't tied to the vario, but I'm going to look into doing that, as waremark mentioned. The odd vertical thing is a G meter, by the way. The dash speaker is inop, there's a speaker in back, so that space is available.. I think I'll just paint, label and maybe rearrange (thx for the suggestions, ND) the panel, and leave well enough alone... for now!
Old January 30th 17, 09:13 PM posted to rec.aviation.soaring
Ben Coleman
My Kobo isn't tied to the vario, but I'm going to look into doing that, as waremark mentioned. The odd vertical thing is a G meter, by the way. The dash speaker is inop, there's a speaker in back, so that space is available. I think I'll just paint, label and maybe rearrange (thx for the suggestions, ND) the panel, and leave well enough alone... for now!
I changed out my lnav/gps-nav for a S100 last season. I was tired of making cables to integrate the Lnav with my XCSoar tablet and never quite getting it to work - though that doesn't impact soaring performance. I have been very happy with the S100 and the clean integration using bluetooth. The beep generator (vario) seems to work well. I am using electronic TE compensation as I found I had a TE leak which was probably impacting my Lnav performance as they are generally held in high regard yet mine never seemed quite right.
Cheers Ben
Old January 30th 17, 09:25 PM posted to rec.aviation.soaring
JS
For your second soaring season, these guys are putting you on the right track: Clean up the existing panel and connect the Kobo to the Cambridge stuff.. There are adapters/cables to connect your GPS-NAV (the box the L-NAV and square Cambridge display connect to) to Oudie, I assume Kobo is essentially the same as Oudie.
Try to move the radio up so you can easily see what you're adjusting, less workload if you're landing out. Where the speaker is/was?
Old January 30th 17, 10:07 PM posted to rec.aviation.soaring
Dan Marotta
Oh, yes - the speaker. Get it out of the panel! Especially since it's
not in use. That magnet can wreck havoc on your compass (don't ask me
how I know).
For your second soaring season, these guys are putting you on the right track: Clean up the existing panel and connect the Kobo to the Cambridge stuff. There are adapters/cables to connect your GPS-NAV (the box the L-NAV and square Cambridge display connect to) to Oudie, I assume Kobo is essentially the same as Oudie.
Dan, 5J
Old January 30th 17, 11:18 PM posted to rec.aviation.soaring
Agreed.
To the OP, unless you fly at sea level, please get used to setting the altimeter to field elevation, all aero maps use altitude above sea level. It is also good to get used to it now before getting much further.
If need be, use a small piece of white tape in the middle of the altimeter with field elevation written on it as a reminder. I do that when flying at a contest site. As an example, HHSC/Elmira is on a hill next to a valley, quite a difference between the two elevations. It would also be a hassle doing a final glide over ridges to a valley airport and trying to figure out if you will clear terrain.
You may also want to inquire about getting your airspeed calibrated/serviced, yours is quite a bit off "0" unless it was really windy when you took the picture. ;-)
NOTE: I'm an ex-CFIG, contest and badge pilot in regards to altimeter setting.
Old January 30th 17, 10:05 PM posted to rec.aviation.soaring
Dan Marotta
I was able to interface an Android to a Cambridge 302 using a K6BT
serial to Bluetooth converter. It's one of the more expensive
converters on the market and you can certainly find something less
expensive.
When I upgraded to a ClearNav system and added a PowerFlarm, I retained
the K6BT and added another one so that my wife's Android could still
enjoy receiving all of the information via Bluetooth while my ClearNav
system worked via serial cables. We fly a two-seater. I used simple
RJ-45 splitters to implement the wiring.
To get your silver badge and beyond you'll need a calibrated and sealed
recorder. You'll probably need to send the Cambridge unit to Gary at
ClearNav or Paul at Cumulus Soaring or Rex at Williams or Richard at
Craggy or... All of us old timers got all of our badges and diamonds
with a camera and barograph (which we had to send in for
calibration/sealing). The logger is much easier to get everything in
order. You'll still need to do the flying yourself!
Good Luck!
Dan, 5J
Old January 31st 17, 01:25 PM posted to rec.aviation.soaring
ND
yeah man! get a label maker from staples, and get rid of unnecessary stuff. you can even fill in the holes with some glass and cut new holes in that same panel if you wanna go the low cost route.
Old January 31st 17, 01:29 PM posted to rec.aviation.soaring
ND
do you use a suction cup mount to the canopy for your phone/navagation app? you may consider getting a ram mount for your phone, attach it to the panel. again, consider putting that on the far left.
Old January 31st 17, 01:19 PM posted to rec.aviation.soaring
ND
On Monday, January 30, 2017 at 3:13:42 PM UTC-5, Bruce Hoult wrote:
On Monday, January 30, 2017 at 10:52:13 PM UTC+3, ND wrote:
On Monday, January 30, 2017 at 12:17:59 AM UTC-5, Paul wrote:
I'm hoping some of you might be kind enough to offer some perspective regarding my panel (pic he https://s29.postimg.org/qvb54ydzb/Panel_2.jpg), it's equipped with:
* Cambridge L-NAV computer with vario display, audio vario & gear warning
* Cambridge GPS-NAV flight recorder & LCD navigation display
* Sage mechanical vario
Not pictured:
* Kobo XCSoar tablet (sunlight readable black & white flight computer)
* Android tablet, running Avare, connected to Stratux for traffic & weather
I've been flying gliders one season, and managed to earn the bronze badge. I plan to start on the silver badge this spring, and hope to fly cross country. I've only used the Cambridge as a vario, and it works fine; I imagine it's navigation interface is clunky compared to my tablets. The Kobo XCSoar tablet gives lots of glider flight data, and the Android tablet also runs XCSoar, in case of a Kobo failure.
I imagine some of you have been down this road. Other than the obvious aesthetics, what's the benefit of replacing the Cambridge gear with something like an LXNAV S100?
Paul
the SN10, and CAI303 are both excellent instruments. if you like xcsoar stick with it. as far as a panel upgrade is concerned, you may simply have this one reconfigured and made more pretty.
if you do have it spruced up, think about functionality and what you most actively need. i like to put instruments with buttons on the left side of the panel, so you can use your free hand to manipulate them without having to trade hands on the stick. switches and fuses are also good to have on the left because you can easily access them with your free hand.
also it makes good sense to put more important/pertinent informaion near the top of the panel. specifically, the vario and the airspeed indicator. the altimeter is not needed quite as often. plus, most soaring programs (xc soar, oudie, lx and c-nav) all have altitude readouts on them, and are prominantly displayed.
your currently layout is not bad! i would put the radio into a 57mm hole off center, and move the temperature gauge down to the bottom of the panel. i'd also get rid of that vertical vario thingy (whatever it is) to the right of the altimeter.
That speaker takes up valuable panel space too. it doesn't need to be mounted on the face of the panel, it could be wired to the support bracket behind the panel, or even moved back behind your head. that frees up some space, de-clutters the panel.
those are my thoughts on "panel theory" X-D
hopefully that helps if you decide to have it re-done.
Andy
"Vertical vario thing"
I assumed that's a G meter?
good call. couldn't think of what it might be last night.
Old February 2nd 17, 03:48 AM posted to rec.aviation.soaring
Surge
Slight thread jack:
There are some good tips are some really good tips on this newsgroup when it comes to panel upgrades and electrical systems.
I redid a panel upgrade last year and it went from this:
https://s27.postimg.org/ojdfgpfmb/Ni...201_190105.jpg
to this:
https://s28.postimg.org/j14qyy8rh/20...164751_640.jpg
Just need to fix the shroud which the previous owner messed up.
I used a Brother label printer for the labels, the two master battery switch setup with common bus behind the panel (master fuses at batteries), individual switches and fuses to each instrument (automotive blade fuse block behind panel) and XT60 RC connectors to the instruments so that they can be removed with ease (I couldn't source Anderson Powerpole connectors where I live and it was too expensive to ship).
Thick walled silicone hose is cheap (sourced from China via eBay), comes in various colours and works extremely well. Removing instruments is easy and it reseals perfectly every time.
I see a lot of guys using those huge (ugly) master switches but there are smaller more elegant switches available which can switch 10A to 20A DC if you're willing to browse a few spec sheets.
One can do a first class job without having to break the bank.
Thanks for all the tips guys - keep them coming.
Ventus Panel upgrade Fish Soaring 3 September 12th 06 10:44 PM
Glass panel upgrade to a Turbo Arrow? Tauno Voipio Owning 9 March 12th 06 04:29 AM
panel upgrade from VFR to IFR John Doe Owning 5 September 26th 05 10:05 PM
cost of panel upgrade on bonanza soxinbox Owning 19 October 29th 04 04:35 AM
Beech F-33/B-55 panel upgrade or STC Gordon Rich-Phillips Owning 2 January 14th 04 01:28 PM
