Wing Loading / climb rate
Old February 3rd 17, 08:09 AM posted to rec.aviation.soaring
Tom Claffey[_2_]
Default Wing Loading / climb rate
At 23:39 02 February 2017, Jim wrote:
I have had a similar question, with a small difference, for many years.
My question is:
"Using only s single glider and changing only the max flying weight -
addin=
g ballast shot bags, whatever - will that glider give its pilot a greater
p=
otential thermal climb rate when heavier or lighter?"
I am aware that higher weight will alter airspeeds but that is not my
curio=
sity - other than a higher weight will raise stall speed some - which may
a=
dd difficulties for the heavier glider using very narrow thermals - turn
ra=
dius varies as the square of true airspeed, etc.
For any glider increasing the weight will reduce it's climb rate.
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Climb Rate for DG-600M Steve B Soaring 5 August 25th 03 08:17 AM
