problems of getting s glider out of Canada?
On Friday, February 3, 2017 at 3:30:04 PM UTC-7, Morris Carter wrote:
problems of getting s glider out of Canada? Not hard to get one out. Expensive to get it in someplace else. Where do you want to take it? |
On Friday, February 3, 2017 at 6:46:02 PM UTC-5, Tim Taylor wrote:
On Friday, February 3, 2017 at 3:30:04 PM UTC-7, Morris Carter wrote: problems of getting s glider out of Canada? Not hard to get one out. Expensive to get it in someplace else. Where do you want to take it? Assuming it's going to the US, here's the (Canadian side) process https://www.tc.gc.ca/eng/civilaviati...xport-2039.htm It is highly recommended to get the Export C of A. Don't forget that you also must export/import the trailer, which can be more difficult than the glider within. Dan |
The trailer is not so bad. Get a bill of sale, and the Canadian title & registration. Leave the Canadian tag on it. Drive it across the border. Mail the tag back to canada. Take the Canadian title and registration to the dmv. At least that was what it was like for me. Check with your dmv first though.
As others have said- buying a glider out of Canada is not difficult since 99% of all gliders in Canada fly under a standard C of A, unlike all the experimental gliders in the US.
This means that Canadian gliders have not been modified and still conform to the original type certificate and for the most part repairs were properly performed and documented by a certified shop. Of course, this is something that you will have to assess with each glider. It is much easier buying out of Canada than importing to Canada! |
On the US side of things, you will need an N number. Reserve one right away, this can take some time to be assigned after the ship is de-registered in Canada. Then put it on the bird, 3" vinel is a good way to go. Armed with an N number, you can apply for US Registration. The ship will need an airworthiness inspection which may require a DAR (these guys don't work cheep)........ I went Experimental with an A&P inspection, then requested an airworthiness certificate from our local FSDO. All in all, not a big issue, but it may take some time to get everything accomplished.
JJ |
Some things I learned while importing my Stemme from Mexico:
1. A US licensed pilot may fly a foreign registered aircraft in US airspace (though saying "Five Juliet" is much easier than saying "Xray Bravo Mike India Golf" on the radio). 2. I was required to pay a bond to US Customs to get clearance into the US (even though, under the Customs regulations, there is no duty on importing civil aircraft). That was an unexpected and onerous expense. 3. Local Customs agents at Laredo, Tucson, and Albuquerque did not know how to handle importing a civil aircraft and so a Customs broker (another fee) was required. 4. Reserving an N-number cost $5.00, IIRC, but took about 6 weeks of waiting. Even after finding my desired number available, the FAA does not know if they have another request for the same number ahead in the queue, and so you'll have to wait until your number is awarded before buying vinyl stick-ons. 5. The FAA would not accept electronic communications from Mexico. All documentation had to be in hard copy (which took extra time). I was told this was for Mexico only and other countries may be acceptable to the FAA. YMMV. 6. Hire one of the documentation companies in Oklahoma City who will walk your paperwork through the bowels of the FAA in a day rather than waiting weeks for your paperwork to filter down through the system. IIRC, that cost about $150 and was ever so worth it. 7. The sellers of the aircraft (a corporation) were anxious to remove the aircraft from the Mexican registry and demanded I remove the XB number while I was still enroute home, effectively grounding the aircraft until my N-number was issued and DAR inspection were completed. 8. DAR inspection and Standard Airworthiness Certificate was quick (if planned ahead) and expensive ($800 + travel expenses). Other than the the above, the whole process was a breeze. My advice is to contact an A&P/IA, a DAR, and a Customs broker well in advance and have all parties ready to act when you get ready to import an aircraft. Good Luck! On 2/4/2017 7:07 AM, wrote: On the US side of things, you will need an N number. Reserve one right away, this can take some time to be assigned after the ship is de-registered in Canada. Then put it on the bird, 3" vinel is a good way to go. Armed with an N number, you can apply for US Registration. The ship will need an airworthiness inspection which may require a DAR (these guys don't work cheep)....... I went Experimental with an A&P inspection, then requested an airworthiness certificate from our local FSDO. All in all, not a big issue, but it may take some time to get everything accomplished. JJ -- Dan, 5J |
On Friday, February 3, 2017 at 10:30:04 PM UTC, Morris Carter wrote:
problems of getting s glider out of Canada? When I was looking to buy an ship out of Canada, the local DAR told me to check for an original logbook for the US, and if they have it get it. He said it would help in the certification process. |
| Thread Tools | |
| Display Modes | |
| glider battery duration problems | John Marshall | Soaring | 86 | October 24th 13 05:39 AM |
| What does a hangar for a 15M glider cost? | son_of_flubber | Soaring | 8 | August 23rd 13 08:00 PM |
| Any EASA problems with USA glider licence? | POPS | Soaring | 8 | September 7th 12 10:10 PM |
| Cost to earn a glider certificate? | Jim Logajan | Soaring | 46 | June 12th 08 02:28 AM |
| Glider Pilot Network Server Problems | Andy Kirkland | Soaring | 0 | February 20th 08 04:07 PM |
