Cutting plasma rope
Old November 4th 03, 09:28 AM
Dave Martin
Bob
I think Marcel answered your questions
I can think of and know of instances where the winch
driver should cut the cable instantly, moving or stationary.
Should -- must -- need -- want -- ought to cut the
cable are all subjective and cannot be answered fully
in the space available. Ultimately I suppose on which
side of the incident you are sitting, on the winch
or in the air and the final outcome.
I witnessed an incident where the pilot on a winch
launch failed to take the correct action when travelling
too fast, he released and accelerated flying under
the cable which then wrapped itself round the glider.
Removed the tail plane and embedded itself in the
fin
The glider did a neat 180 and then dived at about 45
degrees earthwards. The winch driver did not cut the
cable. Just before the glider hit the ground, the winch
cable pulled tight and stopped the glider in mid air.
It 'landed' with greatly reduce forward speed and
energy. It hit the ground almost flat.
The glider was wrecked but the pilot lived.
Talking to the winch driver afterward, he failed to
cut the cable because events happened so fast, he froze.
It was probably all over in less than 10 seconds.
Whatever the incident, the winch driver MUST have the
facility to cut the rope. Only hindsight will tell
whether he should have or should not have cut the cable.
The answer to the problem is training the brain on
each end of the wire to treat the wire and the winch
with utmost respect.
Dave Martin
Old November 4th 03, 11:06 AM
W.J. \(Bill\) Dean \(U.K.\).
As I am sure Dave Martin knows there was another accident in the U.K. where
the cable got round the glider's wing after the glider had released it.
The winch driver operated the cutter while the glider was still drawing the
cable out, which did not succeed in cutting the cable; the winch driver was
left with nothing else he could do, then the cable hung up, tightened, and
the pilot was killed.
So here was a case where it was necessary to cut the cable when it was
moving.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Dave Martin" wrote in message
Bob
fin
Dave Martin
Old November 4th 03, 04:53 PM
Bob Johnson
Hello Bill --
In an attempt to summarize the search for an effective synthetic rope
guillotine then, I would say that we are expecting to develop an
emergency line cutter at least as effective and safe as those we
already employ against steel lines, stranded and solid, moving and
stationary.
Since the numerous winch builders and users on your side of the pond
will by necessity be building and rigorously testing an ideal unit
fairly soon, we'll be interested in learning of your solution(s) to the
problem!
I personally favor trying a "cigar cutter" powered by a compressed gas
cylinder. The cutting blade could be veed to gather the line into the
stationary blade and suitable finger guards can be added to prevent
injuries. The actuating cylnder diameter can be made as large as
necessary to multiply the bottle force enough to secure a successful
cut. Also, at least two units could be installed to provide a backup.
In the oilfield we use diaphragm operated rising stem valves that could
be adapted for trials by developing a new valve "trim". A typical 6-inch
diaphragm valve would have about 25 sq in of area. Powered by only a 100
psi cylinder, around 2500 lb of downward force would be available to the
descending stem. That ought to cut something.
A plus is that the valve body could have short pipe nipples screwed onto
each end, rendering personal injuries a non-issue. These nipples could
also be used to secure the unit the the winch by use of heavy duty pipe
clamps. Finally,the higher the pressure, the larger the gas cylinder and
the smaller the diaphragm, the faster the unit would operate.
BJ
moving.
Bob
fin
Dave Martin
Old November 4th 03, 05:43 PM
Dave Martin
Hi Bob
I do not think we have numerous winch builders on this
side of the pond, possibly four in Europe.
Before we get into expensive guillotines we need to
prove the cable with the kit we have. Part of the
cost effective equation would be installing new guillotines
on existing winches. Possibly developing a graft on
guillotine so the winch can use either steel or synthetic.
I don't see a major technical problem with this just
an expense that may prevent clubs from adopting the
rope
But first let us prove the cable.
Dave
PS I can report that I have had several generous offers
of financial help. A few more and we could be looking
at a realistic project.
Dave
synthetic rope
to develop an
as those we
moving and
stationary.
side of the pond
an ideal unit
solution(s) to the
problem!
I personally favor trying a 'cigar cutter' powered
by a compressed gas
the line into the
added to prevent
as large as
a successful
provide a backup.
valves that could
be adapted for trials by developing a new valve 'trim'.
A typical 6-inch
be available to the
These nipples could
of heavy duty pipe
operate.
BJ
Old November 4th 03, 06:02 PM
Bob Johnson
Hello Dave-
This is an extreme statement, so I make it in jest, but I could build
something out of balsa wood that would serve when someone asked if I
have a guillotine, I could reply with some confidence, "Yes, I have a
guillotine"! 8)
BJ
Dave Martin wrote:
Hi Bob
rope
Dave
Dave
synthetic rope
to develop an
as those we
moving and
stationary.
side of the pond
an ideal unit
solution(s) to the
problem!
by a compressed gas
the line into the
added to prevent
as large as
a successful
provide a backup.
valves that could
A typical 6-inch
be available to the
These nipples could
of heavy duty pipe
operate.
BJ
Old November 4th 03, 06:40 PM
goneill
Has anyone approached the rope suppliers for some developement funding
I would think that to enlarge their market that some funds could be
allocatted
possibly from their advertising budget since they don't have to advertise to
gain
clients.
gary
"Bob Johnson" wrote in message
Hello Bill --
stationary.
problem!
BJ
where
was
and
moving.
Bob
fin
Dave Martin
Old November 4th 03, 11:18 PM
Dave Martin
funding
funds could beallocatted possibly from their advertising
budget since they don't have to advertise to gain clients.
gary
I have approached the UK importer and he looking into
this prospect and other avenues are being tried
Dave
Old November 5th 03, 02:33 AM
CH
the gliding school Oerlinghausen in Germany
is using the plasma cable as well. I was told,
that a small modifiaction of the capping
system did the trick, but I have no details.
Chris
"Robert Makin" wrote in message
There is considerable interest in the UK in using
plasma/dyneema rope for winch launching. However,
the main obstacle appears to be finding an efficient
method of cutting the rope in event of an emergency.
Has anyone ot there found the definitive method???
Old November 6th 03, 01:35 AM
soarski
I translated the important part off a Winch Homepage from German. in
one of the other threads!
They modify the Guilutine so it comes down on a brass anvil,over which
the rope is running. The cutting device, probably something like a big
knife,more like chopping than a shearing action.
Dieter
"CH" wrote in message ...
Chris
Plasma Ropes ----- Help Dave Martin Soaring 7 September 30th 03 11:23 PM
Tow Rope Freindly Fences John Spargo Soaring 8 September 2nd 03 04:17 AM
Using Plasma Rope For Winch Tows Craig Freeman Soaring 56 August 24th 03 10:55 PM
Winching: Steel vs. Plasma Bob Johnson Soaring 10 August 12th 03 05:41 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
