Brian Whatcott wrote: On Sun, 20 Jun 2004 10:40:40 +0000, (Robert Bonomi) wrote: In article , Brian Whatcott wrote: On Mon, 14 Jun 2004 15:17:48 GMT, Dave S wrote: // /// how much energy the radio system is being exposed to flying by the transmitting elements a mile away laterally, and how prudent that is for the longevity of the components. Lets use 50,000 watts if that is appropriate for the example. Dave Here's a rough, rough estimate of intercepted power. If 50 kw were distributed through a spherical surface of 1 mile in radius, what would the power intercepted by one square yard? (arbitrary cross-section value for a 1/4 wave whip...) power times Antenna cross-section / Extended surface area [4/3 pi r squared] = 4 milliwatts [Brian] Correction: surface area of a sphere is 4 pi r squared (volume is 4/3 pi r cubed) 1.294 milliwatts per SQUARE YARD of surface area, at 1 statute mile /// It's true, they they are limited to 50kw 'out the back of the transmitter' , *BUT* 'gain' antennas are almost universally deployed by VHF (and above) stations. An 'effective radiated power' in the several _megawatt_ range is not uncommon. /// A typical VHF aircraft antenna is, electrically, about 4/3 of a yard long. if it is 1/4" in diameter, it presents a maximum cross-section of just about 1/100 of 1 square yard. Which, at 100% capture/conversion efficiency would pick up just under 0.5milliwatts of energy. v^2 would be 0.025 -- the peak voltage would be about 0.158 V. Capture/conversion efficiency is nowhere *near* 100%. /// [Robert] I am glad SOMEONE knew the formula for the surface of a sphere. That's a correction factor of X3 Then things go a little askew. "Cross-section" is not a term denoting actual area, but equivalent radio cross-section. As in "The Stealth bomber had a radar cross section of 1.2 square feet" Of course, the surface area that _reflects_ a signal back to the source has absolutely *nothing* to do with how much signal is -absorbed- by a receiving antenna. In fact, the _more_ signal that is absorbed, the *less* that is reflected back to the source. The Stealth technology utilizes _that_, plus 'carefully shaped' surfaces to reflect remaining signal energy in a direction _other_ than back to the signal source. Just as cross-sections can be reduced, cross-sections can be increased (at a given frequency) , for example, . by a broadside dipole array. Oh my, a 'Microsoft tech support' response -- "technically accurate, but useless in application". _How_many_ 'broadside dipole arrays' are in use, *airborne* in civilian light aircraft? The 'effective' relative cross-sectional area of such an antenna is given _directly_ by the 'gain' of the antenna, basis a standard 1/2 wave dipole. 3db gain == double the effective cross-section, 6db == 4x the effective cross-section, etc. The antenna under discussion is that used for VHF reception in a typical civilian light aircraft. A quarter-wavelength whip -- 'normal' to a ground-plane. Giving an 'effective' size-equivalent of a 1/2 wavelength dipole. If the whip is a 'coil-loaded' unit, to give a reduced physical size, then actual signal capture is reduced below that of a full-length 1/4-wave unit. *IF* one is using a 'gain' antenna -- say a "5/8-wave" unit -- it is trivial to factor in the additional 'effective' cross-section; by simply using the 'gain' of the antenna. The '5/8 wave' whip is the -only- commonly-used _omni-directional_ 'gain' antenna in common use on VHF frequencies. With a theoretical 3db gain, it has an 'output voltage level' that is, at best, only about 40% higher than the 1/4-wave whip. That's the major problem with your input, in fact. The _big_ problem with my analysis is the execrable 'capture efficiency' of a standard 1/4-wave whip (or 1/2-wave dipole). I simply don't have a good handle on _how_poor_ that efficiency actually is. The lack of any measurable radio 'shadow' behind a broadside dipole array, and the 'gain' of a 3-element beam, vs a single 1/2-wave dipole element suggests that the 'efficiency' value is _very_ low. |
Dave S wrote in message ink.net...
When circumnavigating the Class B its not uncommon to be as close as a mile to these towers and once or twice I've heard bleed-over on the VHF radios of the aircraft. My question is, given the limited "resistance" of some of the radio components (and the ability to tolerate less than a watt input if I paraphrased it correctly) I am wondering just how much energy the radio system is being exposed to flying by the transmitting elements a mile away laterally, and how prudent that is for the longevity of the components. Lets use 50,000 watts if that is appropriate for the example. Dave Actually, many UHF stations will have effective radiated powers up to 5 million watts, if you are directly horizontal from their antenna. One on which I work is directional, and I have flown a circle around it and been able to hear the bleed over/sync buzz in my VHF radios increase and decrease according to the pattern of the antenna. I also had a handheld GPS permanently quit working once when I flew by that antenna. Fortunately, Magellan fixed it under warranty. -- Gene Seibel http://pad39a.com/gene/broadcast.html Because I fly, I envy no one. |
