Ian Strachan wrote:
At the last IGC Plenary meeting earlier in 2003, a new approval level for GNSS flight recorders was agreed. This was for "all IGC badge and distance diploma flights" and was in addition to the existing levels for "all flights" and "badge flights up to and including Diamonds". The latter is used for types of recorder units that do not have their own GPS receiver but rely on a separate GPS unit connected to the recorder by cable. Let's admit that this third level was necessary... Now the problem is that most people refer to "IGC approved" loggers, not mentionning whether it is for "all IGC badge and distance diploma flights" or "all flights" or "badge flights up to and including Diamonds" ... in fact most glider pilots ignore that there are different level of IGC approval ! May I suggest that there be somewhat shorter names such as "approved level 1, 2 or 3" or "class A, B or C" ? Things would be clearer this way. Now, what about World Championships ??? Are they less important that world records ??? I don't think so. One could say that it is more difficult to cheat in a Championship than for records, that's right, but it is not impossible (and it already happened !), and the stake is higher too. You (GFAC) didn't say anything about which approval level would be appropriate for World Championships, did you ? If I read the rules for these Championships, it says (Annex A 5.4.a) : "All GNSS FR’s approved by the IGC up to two months prior to the Opening Day shall be accepted." Does it mean that all loggers SHALL be accepted, whatever their approval level ??? Same question for national records or Championships, what type of approved loggers would you recommand ? I understand that for these type of performances NACs may have their own rules, and allow non-IGC-approved loggers (which is not even permitted for a mere 50 km silver D badge, but this is another debate...), but I think that IGC should emit at least a recommendation. -- Denis Private replies: remove "moncourrielest" from my e-mail address Pour me répondre utiliser l'adresse courriel figurant après moncourrielest" dans mon adresse courriel... |
Tim Newport-Peace wrote:
I don't think it is within GFAC's remit to say what should or should not be used for World Championships. That is for the Annex A team to decide upon. Annex A is part of the Sporting Code as well as are world records or badges ; Annex A group are the specialists for World Championships within SC3, like there is a Sporting code specialist for records and badges within main part of SC3. I think GFAC should not decide which loggers should or should not be used for badges and records neither... they should approve loggers within a security classification (class A, B, C, etc.), and it should be up to the sporting code specialist (for main SC3 and Annex A) to propose to the IGC plenary which class of approval is required for badges, records, Championships, etc. As part of Annex A group I would recommand that only loggers approved for world records be accepted for world championships. But it is not the case today. -- Denis Private replies: remove "moncourrielest" from my e-mail address Pour me répondre utiliser l'adresse courriel figurant après moncourrielest" dans mon adresse courriel... |
X-no-archive: yes
In article , Denis Flament writes As part of Annex A group I would recommand that only loggers approved for world records be accepted for world championships. But it is not the case today. I did not find anywhere in SC3A and mention of Recorder Categories, and prior to this announcement, there were two categories one for 'Badges up to Diamond' and another for full approval. It would seem to me that as any recorder could be used up to now, Ian's announcement does not effect SC3A, as it simply divided previously accepted recorders into two subdivisions. I think I must disagree with Denis about "only loggers approved for world records be accepted for world championships". In any competition it is far more difficult to falsify a recording because: 1. The task is not known until a relatively short time before take- off. 2. The Start-Line Open time will not be known in advance of take- off 3. The recorder must be handed in within a relatively short time from landing. 4. The falsified record would need show the correct time for Takeoff, Finishing and Landing. These checks, especially the combination of 3 and 4, will give an added level of security, so that a lower level of FR security should be accepted. Tim Newport-Peace "Indecision is the Key to Flexibility." |
I did not find anywhere in SC3A any mention of Recorder Categories, you're right, there are none I think I must disagree with Denis about "only loggers approved for world records be accepted for world championships". In any competition it is far more difficult to falsify a recording Not so much, you may use a simple software to modify slightly your depature time without changing take-off, landing, etc. When using photo-time cameras it was difficult too to cheat, but it has been done (at least at WGC 93 in sweden) And, apart from the technical considerations, there is so few pilots attempting world records that no reasonable manufacturer will ever present any new model in this category !!! It's not economically viable. -- Denis Private replies: remove "moncourrielest" from my e-mail address Pour me répondre utiliser l'adresse courriel figurant après moncourrielest" dans mon adresse courriel... |
Wow! If they do away with the pressure sensor requirement,
I can submit SoaringPilot for approval. If it only gets the lowest level approval, I'd be happy. I'm sure Jerry and Henryk would agree. However, I won't get my hopes up. That way if it happens, it will be a WONDERFUL surprise. :-) Later!-MarkAt 22:42 19 November 2003, Marc Ramsey wrote:I personally believe thepressure sensor requirement should be eliminated for badge/diploma levelapproval.Marc |
Mark Hawkins wrote:
Wow! If they do away with the pressure sensor requirement, I can submit SoaringPilot for approval. If it only gets the lowest level approval, I'd be happy. I'm sure Jerry and Henryk would agree. However, I won't get my hopes up. That way if it happens, it will be a WONDERFUL surprise. :-) Later!-Mark At 22:42 19 November 2003, Marc Ramsey wrote: I personally believe thepressure sensor requirement should be eliminated for badge/diploma levelapproval. The lack of a pressure sensor is not the only thing that prevents PDA software from getting approval. But, keep trying, Mark 8^) Marc |
