Eric Greenwell originally replied...
If you believe that, perhaps you haven't been told "all the bad things". For example, I've had HP pilots tell me getting sucked up into a cloud can be "awkward" to deal with when all you've got is flaps. My first and only flight in an HP went like Mr. Berry's; even so, I hope anyone beginning to fly a flaps only glider gets thorough checkout, because there are ways to go wrong. Bob Whelan followed with... No offense, Eric, but speaking from the vantage point of one with all his (greater-than) 1-26 glide-ratio time in flaps-only ships (C-70, HP-14, Zuni), the more powerful the flaps, the _less_ 'exciting' it need be if you allow yourself to get sucked into a cloud. Eric G. further replied... The situations described to me were the difficulty of avoiding the cloud entry in the first place. A pilot can open his spoilers at 90 knots and begin descending immediately, but deploying the flaps at 90 knots first increases your altitude, making it much harder to stay out of the cloud. If you do lose control in a cloud, lots of drag is an advantage. The main point I hoped to make is landings aren't the only way spoilers and glide path flap operation differs, and one good landing isn't enough to know the pitfalls, even for landings. I think everyone agrees the HP series is a great ship to make off-field landings in the hands of a good pilot. I figured there was some nuance I was missing. No harm no foul. I agree with all your points. For my part I just wanted to throw out for general consideration that though flaps ARE different than spoilers, 'different' doesn't necessarily strongly equate with 'bad.' Nor does 'different' necessarily strongly equate with 'large cojones.' Free information is always worth every cent paid for it, but (in my flap-biased view) there seems to be more misleading/'flaps are bad' information floating around about flaps than there is of the sort to be found in this particular thread...which thus far contains accurate - if necessarily incomplete - information in every post. Just to provide a counterpoint to your scenario of avoiding the cloud in the first place (always a good idea, if not always achieved), it's worth pondering how ANYone comes to the decision s/he may require imminent cloud avoidance techniques. Consider the particular case of a powerful western U.S. cloud street. Odds are J. Pilot will be cruising along at 80+ mph and suddenly have a "HolyCOW!' moment upon realizing cloud avoidance is necessary. Options likely to spring to the surprised mind?: 1) course change; 2) nosing over/adding energy; 3) adding gear drag; 4) adding flap/spoiler drag. All will be exciting in a suddenly more thrill-filled cockpit. I've spoken to 2 pilots (years apart) soon after each first intentionally opened spoilers at above-pattern speeds, one in a St'd Cirrus near 120 knots trying to get below a finish gate in a regionals, and the other in an Astir-CS trying to avoid being sucked into a big, wide, western cloudstreet who had options 1, 2, & 3 prove insufficient. We laughed about things because we were on the ground, but they were both wide-eyed recollecting the BIG negative G event occasioned by opening spoilers at higher-than-pattern-speeds, even though both had time to realize prior to pulling the spoiler handle they were treading in new (for them, at the times) territory. Playing Joe Test Pilot is always best done (IMHO) under more controlled conditions than 'needing' to play JTP. FWIW, I thought the St'd Cirrus pilot did by far the more foolish thing...because he took an avoidable risk, whereas the Astir CS pilot felt he had no other choice. Both whanged their heads on the canopy. The Astir pilot wound up in a high-speed, gear-down, spoilers-out slip trying desperately to stay out of the cloud street. About the time he could see he was going to be successful avoiding the cloud, he heard a radio call to the effect, "Glider at XXX over YYY, this is Cessna ZZZ. Are you OK?" Being at XXX over YYY, he declined to answer (would've required a 3rd hand w/o a boom mic), though afterwards he could appreciate a certain irony in the situation! Regards, Bob W. --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.538 / Virus Database: 333 - Release Date: 11/10/2003 |
Here are some pictures of Jim Harper's HP-16:
http://www.soaridaho.com/Schreder/HP...rst_Flight.htm Wayne http://www.soaridaho.com/ "Wallace Berry" wrote in message ... Hi all, I'm here to report that I cheated death and survived a flight in a glider with the dreaded "Landing Flaps and V-Tails of Death". Jim Harper graciously allowed me to fly his beautiful HP-16. What's an HP-16 you say? Well, looks to be just like the HP-18 (or I should say the HP-18 is just like the -16) except that the -16 has a large and comfortable all metal cockpit instead of the narrow composite cockpit of the -18. Jim's -16 is equipped with winglets and, as far as I know, the ailerons are standard (not with the J.D. Colling mod, correct me if I'm wrong Jim). Center stick. Tow was behind our 180hp Cessna 175 on a 275 foot long rope. Started out in -2 flap position, went to + 5 at 40 knots. Had no trouble keeping the wings level. The bird lifted off level and was easy to fly on tow. Released and tried slow flight (no stalls), flight up to 90 knots. Steep turns, etc. Well sealed and quiet. Good rudder response and easy to coordinate compared to my 301 Libelle. More stable in a thermal than my Libelle. Aileron response was a little slower than my Libelle at thermaling speeds, but was positive and more than adequate for centering thermals. Climbed a few hundred feet in a very week thermal. Very nice thermalling glider. Landing was the best part. I stayed high and close in the pattern. I rolled on some flap on downwind, maybe 30 degrees or so. I was way high on final so I started rolling in more flaps. I never quite got to the full 90 degrees mark as I had the nose down at a truly obscene angle just to maintain 50 knots. Steeper than my 301 with the tailchute and full divebrakes. Steeper than a Mosquito with everything hanging out. This was more like parachuting than flying. Nothing but dirt out the front of the canopy. The horizon was visible more towards the top of the canopy. I aimed at a target and just kept the nose pointed there. I pulled back on the stick when I ran out of nerve. The bird settled on with a slight bump of the tailwheel and a little bounce as the main dropped on (I flared just a bit too much). I have no doubt that I could easily put this bird in a tiny field much easier than I could my Libelle (and that is not difficult at all). So, I'd have to say that all the bad things I've been told about landing flaps on gliders and V-tails are definitely untrue with respect to the HP-16. It is a comfortable and easy to fly glider and compares very well to my Libelle and also to other glass birds, including my favorites for handling, the Mosquito and LS-4. |
Wayne Paul wrote:
Here are some pictures of Jim Harper's HP-16: http://www.soaridaho.com/Schreder/HP...rst_Flight.htm Wayne http://www.soaridaho.com/ "Wallace Berry" wrote in message ... Wayne, what's it like to land an HP in a strong, gusty wind? Do you use a higher approach speed and only partial flap? -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
![]() "Eric Greenwell" wrote in message ... Wayne, what's it like to land an HP in a strong, gusty wind? Do you use a higher approach speed and only partial flap? Eric, I am a low time glider pilot and I think more experienced pilots could provide more insight then I; however, from my limited experience you are right on target. Several years ago I purchase a HP-16T (now owned by Brian Case). I search the web for information and found almost nothing, so I started a web site to act as a repository of information relating to Dick's designs. The site was well receive by HP/RS/RHJ owner and article, pictures, etc started arriving. The result is http://www.soaridaho.com/Schreder The information on the site reflects the cooperation of HP enthusiasts, not my expertise. Bob Kuykendall started a complementary service by forming the hp-gliders news group. (http://groups.yahoo.com/group/hp-gliders). The combination of the two resources have served Schreder sailplane design owners over the past five+ years. After I sold my HP-16T to Brian I purchase a HP-14 which I have been restoring for the past 3 years. Here are some relevant landing related articles that I have collected: Dick Schreder -- http://www.soaridaho.com/Schreder/St...r_on_Flaps.htm Steve du Pont -- http://www.soaridaho.com/Schreder/Large-span_flaps.html Bob Kuykendall - http://www.soaridaho.com/Schreder/St..._HP_flight.htm Wayne http://www.soaridaho.com |
On Tue, 18 Nov 2003 07:47:58 -0800, Eric Greenwell
wrote: .... text deleted ... Wayne, what's it like to land an HP in a strong, gusty wind? Do you use a higher approach speed and only partial flap? -- Eric, I resisted jumping into this thread, but for what it's worth, while I no longer fly a PIK, I did own a PIK20B for 18 years and have something over 2000 hours in this 90deg flap only ship. Most of the important points on 90deg flaps have already been said. - they are different, so there is an initial learning curve that is made more difficult by the lack of 90deg flaped trainers. I often recommended new PIK pilots to get an hour in a Cessna 150 to get a feel for high flap deflection behavior. - once mastered, they can be modulated during any portion of the pattern with no problem. As has been said before, if you are floating and can not get the ship down, put on more flap. Once the main wheel is on the ground, dump the flap (full negative (up)) to plant the ship on the ground. - Like any flapped ship, so not get below the flaps up stall speed during the pattern, until your final flare. This allows you to modulate the flaps with no concern about pulling out flap and stalling. - On the PIK, I recommended new pilots move the PIK flap handle (5 turns total) in full 360deg increments, always stopping at the top of the circle. This made modulation like normal spoilers, pulling the handle back from the top position lowered flap, increased drag, just like pulling back a spoiler handle. And the opposite for pushing forward from a top position, less drag. - Relating to your question, the only drawback I found in the 90deg flaps was landing in very gusty conditions. Here I would limit the down flap to something like 45deg. Since this only occured with strong headwind components, I did not need large flap deflections. - The strong advantage to the 90deg flaps was in short field landing, where you could point the ship at a spot on the ground and modulate the flaps to control airspeed. BTW, the only time in all my flying that I used 90deg flaps was in off-field landings over a tree line, and for routine practice. Typical landing flap varied between 30deg and 60deg. Bob |
OK, It's winter time and I'm bored, so let me throw my 2 cents in here. The
only flight I ever had in a ship with flaps only was in a PIK-20B. It was a test flight after a broken fuselage. Things went well until it got time to land. I rolled in 45 degrees of flaps and everything looked just about right. Came over the fence at 50 knots and waited for her to settle down. I waited and waited and waited. By now I had floated down most of the 4000 foot runway and I'm still floating about 1 foot off the ground. What do I do? Musn't dump the flaps or she will drop like a stone, right? Finally got the wheel on the ground and jumped on the brake. That night I read the flight manual and it said to slowely crank off the flaps in this situation. I think the flaps only ships are OK, but require a different set of skills that must be mastered. Probably not for the low time pilot or those who don't read the flight manual before flight. My real problem was being about 5 knots too fast. Proper speed control is critical. JJ Sinclair |
JJ Sinclair wrote:
OK, It's winter time and I'm bored, so let me throw my 2 cents in here. The only flight I ever had in a ship with flaps only was in a PIK-20B. It was a test flight after a broken fuselage. Things went well until it got time to land. I rolled in 45 degrees of flaps and everything looked just about right. Came over the fence at 50 knots and waited for her to settle down. I waited and waited and waited. By now I had floated down most of the 4000 foot runway and I'm still floating about 1 foot off the ground. What do I do? Musn't dump the flaps or she will drop like a stone, right? Finally got the wheel on the ground and jumped on the brake. That night I read the flight manual and it said to slowely crank off the flaps in this situation. I think the flaps only ships are OK, but require a different set of skills that must be mastered. Probably not for the low time pilot or those who don't read the flight manual before flight. My real problem was being about 5 knots too fast. Proper speed control is critical. So I'm told. Our club had a member from Long Island, where the club there had a 1-35. He said they got rid of it after a while because they got tired of pulling it out of the weeds at the end. Without a landing flap equipped two seater, they weren't able to train their low time pilots well enough to land it properly. I think there would be a lot more acceptance of HP style flaps if we had two seaters to train in. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
JJ Sinclair wrote: OK, It's winter time and I'm bored, so let me throw my 2 cents in here. The only flight I ever had in a ship with flaps only was in a PIK-20B. It was a test flight after a broken fuselage. Things went well until it got time to land. I rolled in 45 degrees of flaps and everything looked just about right. Came over the fence at 50 knots and waited for her to settle down. I waited and waited and waited. By now I had floated down most of the 4000 foot runway and I'm still floating about 1 foot off the ground. What do I do? Musn't dump the flaps or she will drop like a stone, right? Finally got the wheel on the ground and jumped on the brake. That night I read the flight manual and it said to slowely crank off the flaps in this situation. I think the flaps only ships are OK, but require a different set of skills that must be mastered. Probably not for the low time pilot or those who don't read the flight manual before flight. My real problem was being about 5 knots too fast. Proper speed control is critical. So I'm told. Our club had a member from Long Island, where the club there had a 1-35. He said they got rid of it after a while because they got tired of pulling it out of the weeds at the end. Without a landing flap equipped two seater, they weren't able to train their low time pilots well enough to land it properly. I think there would be a lot more acceptance of HP style flaps if we had two seaters to train in. Flaps only ships are very rare in France and kowledge about their handling is probably even more rare. I wonder how one can handle in such a ship what is described in our flight Bible, the "blue book" (Manuel du pilote Vol a Voile, i.e. glider pilot's manual) as the 3 most common mistakes when landing: 1) flare to high; 2) flare with excessive back stick action; 3) bounce. In this 3 cases the glider comes a few feet above the ground at a speed just marginally above stall speed and quickly decaying due to the drag of open airbrakes. The immediate action to avoid that the glider falls on the ground like a stone in the following seconds is to retract the air-brakes, so that the drag stops killing your speed and you regain some lift, then try to land better ahead. But what can you do with no air-brakes? |
![]() "Robert Ehrlich" wrote in message ... Eric Greenwell wrote: JJ Sinclair wrote: OK, It's winter time and I'm bored, so let me throw my 2 cents in here. The only flight I ever had in a ship with flaps only was in a PIK-20B. It was a test flight after a broken fuselage. Things went well until it got time to land. I rolled in 45 degrees of flaps and everything looked just about right. Came over the fence at 50 knots and waited for her to settle down. I waited and waited and waited. By now I had floated down most of the 4000 foot runway and I'm still floating about 1 foot off the ground. What do I do? Musn't dump the flaps or she will drop like a stone, right? Finally got the wheel on the ground and jumped on the brake. That night I read the flight manual and it said to slowely crank off the flaps in this situation. I think the flaps only ships are OK, but require a different set of skills that must be mastered. Probably not for the low time pilot or those who don't read the flight manual before flight. My real problem was being about 5 knots too fast. Proper speed control is critical. So I'm told. Our club had a member from Long Island, where the club there had a 1-35. He said they got rid of it after a while because they got tired of pulling it out of the weeds at the end. Without a landing flap equipped two seater, they weren't able to train their low time pilots well enough to land it properly. I think there would be a lot more acceptance of HP style flaps if we had two seaters to train in. Flaps only ships are very rare in France and kowledge about their handling is probably even more rare. I wonder how one can handle in such a ship what is described in our flight Bible, the "blue book" (Manuel du pilote Vol a Voile, i.e. glider pilot's manual) as the 3 most common mistakes when landing: 1) flare to high; 2) flare with excessive back stick action; 3) bounce. In this 3 cases the glider comes a few feet above the ground at a speed just marginally above stall speed and quickly decaying due to the drag of open airbrakes. The immediate action to avoid that the glider falls on the ground like a stone in the following seconds is to retract the air-brakes, so that the drag stops killing your speed and you regain some lift, then try to land better ahead. But what can you do with no air-brakes? Flaps, once deflected beyond about 10 degrees, produce mainly drag. In steady-state glides, drag is drag whether produced by flaps or spoilers. For a given amount of drag, a flapped glider will have the nose much further down than a glider with spoilers, however. This gives a much better view of the runway. The main difference is in the transients as the drag devices are extended or retracted. The trick with flaps is to manage the transients. Yanking on flaps from the retracted position will produce a upward transient before the drag steepens the glide path. Yanking on spoilers will produce a downward transient before the glider settles into a steeper glide. This generally means that the pilot should not make large, sudden changes in flap settings near the ground - but this is good advice for spoilers as well. Large flap deflections change the relationship between pitch and airspeed. Large changes in pitch result in small changes in airspeed so that the nose can be steeply down and the airspeed will not increase much. This invites the technique popular with HP glider pilots of just aiming the glider steeply down at the flair point with 90 degrees of flap deployed. If the glide appears to be overshooting the aim point, pushing the nose further down steepens the glide without much increase in airspeed. If it appears that you are undershooting, just raise the nose a little and shallow the glide. Extremely accurate landings are possible with no changes made in the flap setting. The height to start the flare is a bit tricky to judge at first and the flare is greatly exaggerated compared to spoiler only gliders. If you flare too high, the recovery is to just relax some of the back stick and let the glider settle before completing the flare. "Leave 'em where they are" is good advice when landing with flaps. I really like flaps. They eliminate the discontinuity in the upper wing surface created by the spoiler box. Once mastered, they permit much lower energy landings than with spoilers. A for as a trainer, the IS28b2 Lark can be landed with flaps only although the glide is quite shallow. I looked at the flap drive geometry on my Lark with the thought that it might be modified to allow 45 degrees or more of positive flap just for training scenarios. It would be possible but the paperwork would be a nightmare. Bill Daniels |
![]() "Robert Ehrlich" wrote in message ... Eric Greenwell wrote: JJ Sinclair wrote: OK, It's winter time and I'm bored, so let me throw my 2 cents in here. The only flight I ever had in a ship with flaps only was in a PIK-20B. It was a test flight after a broken fuselage. Things went well until it got time to land. I rolled in 45 degrees of flaps and everything looked just about right. Came over the fence at 50 knots and waited for her to settle down. I waited and waited and waited. By now I had floated down most of the 4000 foot runway and I'm still floating about 1 foot off the ground. What do I do? Musn't dump the flaps or she will drop like a stone, right? Finally got the wheel on the ground and jumped on the brake. That night I read the flight manual and it said to slowely crank off the flaps in this situation. I think the flaps only ships are OK, but require a different set of skills that must be mastered. Probably not for the low time pilot or those who don't read the flight manual before flight. My real problem was being about 5 knots too fast. Proper speed control is critical. So I'm told. Our club had a member from Long Island, where the club there had a 1-35. He said they got rid of it after a while because they got tired of pulling it out of the weeds at the end. Without a landing flap equipped two seater, they weren't able to train their low time pilots well enough to land it properly. I think there would be a lot more acceptance of HP style flaps if we had two seaters to train in. Flaps only ships are very rare in France and kowledge about their handling is probably even more rare. I wonder how one can handle in such a ship what is described in our flight Bible, the "blue book" (Manuel du pilote Vol a Voile, i.e. glider pilot's manual) as the 3 most common mistakes when landing: 1) flare to high; 2) flare with excessive back stick action; 3) bounce. In this 3 cases the glider comes a few feet above the ground at a speed just marginally above stall speed and quickly decaying due to the drag of open airbrakes. The immediate action to avoid that the glider falls on the ground like a stone in the following seconds is to retract the air-brakes, so that the drag stops killing your speed and you regain some lift, then try to land better ahead. But what can you do with no air-brakes? The landing is executed in a way as not to use full 90 degree flap in the final stages of the final. Rather manage the final approach in a way that allows the use of less flap. You will have some flap action in reserve to arrest any excessive sink, similar to using only partial spoiler. In Fact, when looking at my flying style with the flap only glider, I use the flap, like you would use the spoiler. I constantly make use of them during the pattern to place my self at any point I would like to be. When making misjudgements it is no different to correct them, as with spoilered gliders. It is best for a newcomer to place the glider relative high on final crank in full flaps and aim for the beginning of the run way. That way you will have enough speed for corrections if you make a misjudgement and if you are on glide path you burn of all the energy very quickly. It really does not matter if you use and extra 200 feet. In the end it the touch down speed that counts. As for out landings into small fields with high obstacle, it requires different approaches and only practice at your home field will make you proficient. Udo |
f-84G Flaps question | Frederico Afonso | Military Aviation | 0 | September 8th 04 05:58 PM |
757 flaps miss-aligned in cruise | AnyBody43 | General Aviation | 1 | April 2nd 04 01:01 AM |
Cessna 182S flaps | EDR | Piloting | 7 | January 16th 04 02:37 AM |
Slats and Fowler Flaps On Light Plane | Brock | Home Built | 28 | July 31st 03 10:12 PM |
automatic flaps problem in Beechcraft KAF90 | deeknow | Simulators | 0 | July 24th 03 02:45 AM |
