IGC APproval for GPS with WAAS
Old November 26th 03, 10:02 PM
Mike Borgelt
On Tue, 25 Nov 2003 22:37:33 +0000, Tim Newport-Peace
] wrote:
I don't think it happens quite that way. If you submit a recorder that
does not conform the Specification in Force at the time, approval will
not be granted until it DOES conform. The specification would need to be
changed FIRST.
As opposed to NOT approving a recorder which does meet the
specification at the time and then changing the specification later?
Which GFAC has done.
I do not believe that the requirement for Barometric Altitude will be
removed any time soon.
I agree, that would be far too sensible a decision for IGC/GFAC to
make.
Mike Borgelt
Old November 26th 03, 11:00 PM
Adrian Jansen
I agree with your analysis in principle, but I dont *know* that WAAS works
like this. In any case I dont see any point in the enhanced accuracy of WAAS
for glider flights. The errors in the normal GPS signals are already small
enough. I just dont want to see an 'improvement' leading to yet another
unforseen problem.
Regards,
Adrian Jansen
J & K MicroSystems
Microcomputer solutions for industrial control
"Bruce Hoult" wrote in message
"Adrian Jansen" wrote:
You might want to consider the implications of WAAS. I have no direct
experience, but the principle is that you take an external signal and
use it
to 'correct' the GPS location to another place - hopefully more
accurate.
But what is to stop you sending bogus 'corrections' and making the GPS
think
its somewhere else entirely ? The WAAS signals are much easier to
generate
than the original GPS satellite signals. Sounds an easy way to cheat to
me.
But how far can the WAAS signal "correct" the GPS one?
I assume the principle is that the transmitter knows exactly where it
really is, so if GPS says it is somewhere else then the difference is an
error which will apply to all other GPS receivers in the area. Since
the GPS error is likely to be on the order of 5m - 10m, and very very
unlikely to be more than a couple of hundred meters, I would expect the
system to be designed to correct the GPS positions by no more than a few
hundred meters.
Another characteristic is that the correction is the same not only for a
reasonably large geographic area, but that the necessary correction
changes quite slowly, over a period of many minutes. If I was designing
the system, I expect I would also take advantage of that to reduce the
amount of information that need to be transmitted.
So I would expect a maximum correction possible of, say, less than a km,
and rapid changes to the correction to be either impossible or else
rather unusual and therefore suspicious.
I don't see how you could use that to make any significant difference to
a glider flight.
-- Bruce
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 05:28 PM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
WAAS Big John Piloting 8 July 22nd 03 01:06 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
