Issues with Dell Streak
Old March 26th 17, 03:58 AM posted to rec.aviation.soaring
Jim[_33_]
Default Issues with Dell Streak
On Saturday, March 25, 2017 at 7:15:30 AM UTC-7, Dan Marotta wrote:
I just heard from Wade that Windows 10 is preventing the update from
happening. It appears to be a driver issue and I doubt there are any
Windows 10 drivers for a Dell Streak. Can anybody here help? I've
suggested finding a Windows Vista or 8 computer to do the update.
Dan (Hater of all things Windows, but refuse the Apple kool-aid)
On 3/24/2017 11:12 PM, Wade G wrote:
Thanks for the input!
I'm working on Dan's outline tonight and will report on results.
Wade
Dan, 5J
I haven't seen any coolaid but the Mac and iPad work great for me. I spent a LOT of years working with Windows stuff and I can't believe just how much easier to work with the Apple stuff is.
Old March 26th 17, 05:36 AM posted to rec.aviation.soaring
Wade G
I'd agree that learning windows stuff has a curve but I tried iGlide on the iPhone. Useless trying to see the iPhone in the sun! Hence, I am on the hunt currently to resurrect this Streak.
Old March 26th 17, 07:31 AM posted to rec.aviation.soaring
Wade G
Tried again to get onto the XCSoar forum (where this issue belongs) with no password code sent to my email. Does anyone have any contact info for an administrator? I looked for one but couldn't find an email address to contact them.
Update on the Streak....no joy. Still not able to get Windows 10 to recognize the Streak via USB when in fastboot mode.
Old March 26th 17, 02:33 PM posted to rec.aviation.soaring
Soartech
Try Max Kellerman. He seems to be the head of XCsoar development.Search the archives of this list. I think he is on it occasionally.
Old March 26th 17, 04:05 PM posted to rec.aviation.soaring
Did you check your junk mail? Wouldn't be the first time an email I was waiting for ended up there, even if I had received emails from that address before. Shrug.
Has happened on Windows as well as Apple OS.
Old March 26th 17, 04:51 PM posted to rec.aviation.soaring
Dan Marotta
If you don't have a gmail account, set one up and use it to register the
Streak.
You may also get this thing to work by copying the necessary files
directly to your SD card on your PC and then install the card and go
through the setup procedures. I've not tried that and don't have the in
depth knowledge to state that it will work, but I do know you can
install applications that way using .apk files.
On 3/25/2017 5:52 PM, Wade G wrote:
That is logical but my attempts to register are met with no email to me to get the reg completed. Until then I have a new toy (actually an old Streak) to play with and I'm too obsessive to wait!
Wade
Dan, 5J
Old March 27th 17, 06:32 AM posted to rec.aviation.soaring
Wade G
I tried the SD card. Android 1.6 doesn't seem to have the option to allow for programs that are not straight from the android market to be installed. It tells me it's doing it for my security. A nanny!
Old March 27th 17, 10:43 AM posted to rec.aviation.soaring
Bruce Hoult
I've never used Android as old as 1.6, but it would be quite surprising if you can't install APK files from a PC command line using the "adb" program.
Old March 27th 17, 03:25 PM posted to rec.aviation.soaring
Andy Gough[_2_]
On Monday, March 27, 2017 at 1:32:54 AM UTC-4, Wade G wrote:
I tried the SD card. Android 1.6 doesn't seem to have the option to allow for programs that are not straight from the android market to be installed.. It tells me it's doing it for my security. A nanny!
I am not sure how you are attempting to download the program but regardless of Android version if you can connect your Streak to the internet go to:
http://download.xcsoar.org/releases/6.8.7/ANDROID/ and download the .apk file, it should download to your downloads file on your Streak. You will need to download a file manager program to access the file if it does not install automatically, I use Astro, you may find a better one. Before you attempt installation go to: SettingsApplicationsUnknown sources this will allow the installation to proceed.
It should work, it did for my Streak 1.6.
Regardless you will not be happy with the performance you need to upgrade. You might not be able to upgrade using Windows 10 but give it a try and if it does not cooperate find a friend with a lower operating system.
Before you attempt to upgrade read my previous post about using the QDL tool to reconfigure your Streak 1.6 to accept the 2.3.3 Olleh upgrade.
Old March 28th 17, 02:39 AM posted to rec.aviation.soaring
Wade G
Things are on standby as the old Streak starts a tour of the western US. It's on it's way to Dan's to see if his older Windows and computer that has successfully accomplished the task can recognize this Streak.
My computer is stuck with Windows 10 and furthermore, who knows what modifications our 2yr old daughter has done to it when we're not watching!
Will update as needed.
Wade
CAI302 to Dell Streak 5 Wade G Soaring 4 March 21st 17 06:37 PM
Wanted: Dell Streak 5 Wade G Soaring 3 March 4th 17 10:21 PM
Dell Streak - what ROM version? [email protected] Soaring 7 May 24th 14 05:09 PM
Temperature Probe for Dell Streak Dan Marotta Soaring 14 April 20th 13 02:56 AM
Dell Streak 5 available soartech[_2_] Soaring 0 November 14th 12 05:44 PM
