Well,
You all almost have it right. The coffin corner is that place in an aircraft's speed and altitude range where low speed stall runs into high speed mach buffet. It has little to do with VNE. Mach buffet occurs when some part of the aircraft structure causes airflow separation in the transonic region. It is almost never caused by the wing per se but usually by some projection such as a flap track, aileron edge, tail surface, etc. Mach buffet is also not a stall per se but simply separation turbulence. Obviously, going faster would result in a full high speed stall. It is true that you can get into trouble by getting so high that you can't slow down because of stall and can't speed up because of mach buffet. Most older transport aircraft have tables that tell you what the limits are between stall and mach buffet for a given weight and altitude. The 727, for example, could fly at 39,000 feet but it required a light airplane and smooth air. It also left as few as 15 kts between stall and buffet. The U-2 was really the ultimate motor glider. If I remember correctly, the wing was basically a beefed-up sailplane wing and the whole aircraft had an original design life of about 150 hours. It seems to have passed that with ease. With the J-75 engine, the U-2 had a coffin corner of about 100,000 ft. I wonder what the glide ratio was? Cheers, Allan "Jim" wrote in message ... Still thinking about VNE and whether it is usually stated as a TAS rather than an IAS (one must read the POH to be sure, of course). I've gotten the notion, probably from comments I've not understood very well, that the "coffin corner" is the intersection of stall speed as an IAS indication on the airspeed indicator, and VNE understood as a TAS and thus occurs at a decreasing IAS with altitude. I guess the consequence of this notion is that as aircraft altitude goes up the stall speed TAS goes up to ultimately bump into the VNE TAS. If VNE is published as an IAS, like stall speed, then stall speed and VNE would never converge. Or maybe it was the Manuevering TAS that could bump into the VNE TAS. IS this what is sometimes referred to as the "coffin corner"? |
ADP wrote:
The coffin corner is that place in an aircraft's speed and altitude range where low speed stall runs into high speed mach buffet. It has little to do with VNE. Yes, it has a lot to do with Vne. It is the place where the stall speed runs into *something* limiting the high speed. The upper speed limit is Vne by definition, whatever the cause of this limit may be. Note that Vne may vary with altitude, temperature, whatever. This red line is just a simplification. The mach number matters because in real life, the coffin corner was relevant to military aircraft only. Their Vne was typically set by mach speed. Stefan |
Yes, it has a lot to do with Vne. It is the place where the stall speed runs into *something* limiting the high speed. The upper speed limit is Vne by definition, whatever the cause of this limit may be. Note that Vne may vary with altitude, temperature, whatever. This red line is just a simplification. The mach number matters because in real life, the coffin corner was relevant to military aircraft only. Their Vne was typically set by mach speed. Stefan I think now you splitting hairs. But if you really want to, Vne does not even apply to most aircraft for which the "coffin corner" is an issue. The "red line" on the airspeed indicator is not fixed and moves, it is the lesser of Vmo or Mmo, which is the maximum operating speed (akin to but not technically the same as Vne) or mach number. Ivan |
IIRC, the U2 pilots used to flirt with that corner for hours.
Marc Till ADP a écrit: Well, You all almost have it right. The coffin corner is that place in an aircraft's speed and altitude range where low speed stall runs into high speed mach buffet. It has little to do with VNE. Mach buffet occurs when some part of the aircraft structure causes airflow separation in the transonic region. It is almost never caused by the wing per se but usually by some projection such as a flap track, aileron edge, tail surface, etc. Mach buffet is also not a stall per se but simply separation turbulence. Obviously, going faster would result in a full high speed stall. It is true that you can get into trouble by getting so high that you can't slow down because of stall and can't speed up because of mach buffet. Most older transport aircraft have tables that tell you what the limits are between stall and mach buffet for a given weight and altitude. The 727, for example, could fly at 39,000 feet but it required a light airplane and smooth air. It also left as few as 15 kts between stall and buffet. The U-2 was really the ultimate motor glider. If I remember correctly, the wing was basically a beefed-up sailplane wing and the whole aircraft had an original design life of about 150 hours. It seems to have passed that with ease. With the J-75 engine, the U-2 had a coffin corner of about 100,000 ft. I wonder what the glide ratio was? Cheers, Allan "Jim" wrote in message ... Still thinking about VNE and whether it is usually stated as a TAS rather than an IAS (one must read the POH to be sure, of course). I've gotten the notion, probably from comments I've not understood very well, that the "coffin corner" is the intersection of stall speed as an IAS indication on the airspeed indicator, and VNE understood as a TAS and thus occurs at a decreasing IAS with altitude. I guess the consequence of this notion is that as aircraft altitude goes up the stall speed TAS goes up to ultimately bump into the VNE TAS. If VNE is published as an IAS, like stall speed, then stall speed and VNE would never converge. Or maybe it was the Manuevering TAS that could bump into the VNE TAS. IS this what is sometimes referred to as the "coffin corner"? |
| Thread Tools | |
| Display Modes | |
