Simon,
I can give you one data point. My early LS-6 came with only the bottom of the wing sealed (mylar type, venetian blind, I think) Anyway, she didn't get her killer climb, until I added mylar to the top of the wing. These were just stuck on and not recessed into the wing. As a general rule, I would say that recessing is better, but a bunch of work and if done by unskilled hands, could result in a mess. Use trailing edge guides on your router and monitor the depth very closely. Before you start, I would lay a straight edge across the wing / aileron juncture, see if lowering the wing side (routing out) will cause the mylar to be forced up as it hits the aileron. This should not be allowed and will lead to mylar separation when left in a hot trailer. BTW, the mylar width should be just wide enough to just touch the control surface and shouldn't be forced up when the control surface is moved. If hinge gaps are too wide to allow the mylar to completely cover the gaps, then use a *gap bridge* made of thin plastic or wide tape. Thake a good look at an ASW-27, Schleicher's attention to detail is something to behold and the cleanest set-up I have seen. JJ Sinclair |
Service Bulletins, Service Letters, Service Spares Letters | O. Sami Saydjari | Owning | 5 | December 26th 03 05:36 AM |
History of Contest Scoring | Bill Feldbaumer | Soaring | 8 | October 8th 03 02:14 PM |
Contest Numbers/Letters | Ken Kochanski | Soaring | 4 | October 5th 03 07:08 AM |
Region 6 South Contest (USA) | BMacLean | Soaring | 0 | September 1st 03 08:37 PM |
2003 Air Sailing Contest pre-report synopsis | Jim Price | Soaring | 0 | July 10th 03 10:19 PM |
