#11
There is talk of trying a hybrid to eliminate line sag for longer runs,have
to wait and see on that one. The point about the rope storing energy equal to a bigger engine, well we are already using a 5.7 ltr V8 with performance mods to get high output,to get more pull is going to cost a lot in terms of the engine verses $250US for 1000 metres of poly. The second part of this is the club 1.5hrs drive south of us had their winch motor stolen because it was very highly tweaked up and a prize worth stealing gary "Bill Daniels" wrote in message hlink.net... Actually, I'm not sure the economic effect would be positive. The rope that winds onto the drum first doesn't see much wear so the effect of using cheap rope might not be significant. Looking at the big picture, the cost difference per launch for cable replacement might not be worth the hassle of using two kinds of rope. The price of high-strength synthetics is coming down anyway. All the engineering data I have says Spectra will outlast lesser synthetics by a factor of 10 or more. Nothing wrong with experimenting with cheaper materials though. If you want a "bungee effect", then nylon would be a better material than poly. The bungee effect is a way to store engine power and then release it at the point of peak power demand with the result that a smaller engine can do the work for a larger one. My gut reaction is that it would be better to use a larger engine and no bungee effect - an engine is controllable and the bungee effect is not. A stretchy rope is a step away from precise control of the launch. In my experience, most problems that arise in winch operations come from poorly thought out efforts to save money up front. The best way to save money is to do the thing right the first time. Bill Daniels "F.L. Whiteley" wrote in message ... 1. with a hybrid solution on a LONG (=5000ft) run, you still get 2500ft of bungee effect at the beginning of the launch (not sure that 5000ft of bungee effect is wanted) 2. then ELIMINATE the sag as the launch gets higher using the lighter and thinner and more expensive rope I'm not suggesting this for launch runs of 1000m, but those about 1400m length or greater where someone has already demonstrated that 10mm poly has issues of weight and drag. Frank "goneill" wrote in message ... Big point ,the bungee effect is VERY DESIRABLE at the initial acceleration and rotation into the full climb,this is where the extra height is coming from , no wasted field length ,the penalty for the bungee effect is at the top of the launch where the the winch needs to have the release with no tension so the rope does not catapult at the winch and snag in the feed guide. A number of single seaters are requesting 70 knots on the winch and dipping the nose for release then pulling up with the residual speed often getting 1600-1700ft. Overall the good effects outweigh the few minor problems created ,these problems are negated by operational changes gary "F.L. Whiteley" wrote in message ... "goneill" wrote in message ... Other info now obtained poly is 10 millimetres diameter and with use shrinks to 8ml Durability is 1000-1500 launches on grass field being dragged out by 4wd from stationary winch Our local cost is $245US for 1000metres of rope.DO THE MATH.ITS CHEAP We charge round $8US per launch this to help fund another winch The winch motor is a 5.7ltr V8 petrol driving through an auto box to an old truck axle with diff modified to drive one side at time (your common winch) The difference is the drums.The drums have a centre core cut from the old front wheel of a road roller 12ml thick hardened steel (we got it for free)and the side plates 10ml thick with a welded on bevel at the top to act as a guide. All this to stop the crushing effects.of the stretched rope I have the email of one of the main members who helped in the experimentation stage and is on the instructor,s panel so can explain the changes to the flight training on winch launching with our style of winch. Another club has also switched to this method and is having the same success as we are on a similar strip length.Most single seaters are getting close to or +50% of rope length in height. Trials at another club with 5400ft of runway found that the sag in the rope with longer lengths tended to get premature releases in top third of launch as angle of the rope into the release was not as flat. This was a limited number of launches. gary Gary, Thanks for the information. Now, if the poly could be spliced ~50/50 or so with something like 1/8" Validator 12 http://www.samsonrope.com/admin/data...dator12_LR.pdf , (Vectran) http://www.pelicanrope.com/peli05c.htm both the bungee and sag effects could be reduced with some cost benefits. This could be a solution for long runs. When we launched with 1000ft of Spectra on the end of the wire rope, we didn't pull the Spectra through the rollers. Two synthetics with a reasonable join might work well as a hybrid solution. Vectran is stronger than Spectra with a higher critical temperature, but with somewhat less abrasion resistence. There are some interesting 1/4" vectran sheathed products http://www.pelicanrope.com/new04.htm for improved abrasion resistence. And Plasma 12 http://www.cortlandcable.com/psrope/...PlasmaRev9.pdf Spectra in a variety of sizes. Frank Whiteley Colorado |
I have nothing against cheap rope, if the long term economics work. But, if
you reduce the question to how much extra it costs for each launch, an all spectra rope would likely add less than $1 US per launch and return an extra 25% in height achieved, at least on long (5000 feet+) winch runs. (Don't expect to see that much extra height on short runs.) For me, adding $1 to the launch costs for a higher, sweeter, more reliable launch is well worth it. Tweaking an ex-automobile engine for more output is an expensive way to go in the long run since it tends to make for a peaky torque curve and less reliability. What seems to work best for a winch is an engine with a flat power curve and a huge torque reserve. Every automobile power train that I have seen used in glider winch had problems of one kind or another - usually inadequate control of the launch because of the transmission shifting to accommodate the peaky torque curve. Getting an engine stolen is a security issue, not a winch design issue. But, if the engine had been a 3000 pound diesel, the bandits would have probably left it alone. Bill Daniels "goneill" wrote in message ... There is talk of trying a hybrid to eliminate line sag for longer runs,have to wait and see on that one. The point about the rope storing energy equal to a bigger engine, well we are already using a 5.7 ltr V8 with performance mods to get high output,to get more pull is going to cost a lot in terms of the engine verses $250US for 1000 metres of poly. The second part of this is the club 1.5hrs drive south of us had their winch motor stolen because it was very highly tweaked up and a prize worth stealing gary "Bill Daniels" wrote in message hlink.net... Actually, I'm not sure the economic effect would be positive. The rope that winds onto the drum first doesn't see much wear so the effect of using cheap rope might not be significant. Looking at the big picture, the cost difference per launch for cable replacement might not be worth the hassle of using two kinds of rope. The price of high-strength synthetics is coming down anyway. All the engineering data I have says Spectra will outlast lesser synthetics by a factor of 10 or more. Nothing wrong with experimenting with cheaper materials though. If you want a "bungee effect", then nylon would be a better material than poly. The bungee effect is a way to store engine power and then release it at the point of peak power demand with the result that a smaller engine can do the work for a larger one. My gut reaction is that it would be better to use a larger engine and no bungee effect - an engine is controllable and the bungee effect is not. A stretchy rope is a step away from precise control of the launch. In my experience, most problems that arise in winch operations come from poorly thought out efforts to save money up front. The best way to save money is to do the thing right the first time. Bill Daniels "F.L. Whiteley" wrote in message ... 1. with a hybrid solution on a LONG (=5000ft) run, you still get 2500ft of bungee effect at the beginning of the launch (not sure that 5000ft of bungee effect is wanted) 2. then ELIMINATE the sag as the launch gets higher using the lighter and thinner and more expensive rope I'm not suggesting this for launch runs of 1000m, but those about 1400m length or greater where someone has already demonstrated that 10mm poly has issues of weight and drag. Frank "goneill" wrote in message ... Big point ,the bungee effect is VERY DESIRABLE at the initial acceleration and rotation into the full climb,this is where the extra height is coming from , no wasted field length ,the penalty for the bungee effect is at the top of the launch where the the winch needs to have the release with no tension so the rope does not catapult at the winch and snag in the feed guide. A number of single seaters are requesting 70 knots on the winch and dipping the nose for release then pulling up with the residual speed often getting 1600-1700ft. Overall the good effects outweigh the few minor problems created ,these problems are negated by operational changes gary "F.L. Whiteley" wrote in message ... "goneill" wrote in message ... Other info now obtained poly is 10 millimetres diameter and with use shrinks to 8ml Durability is 1000-1500 launches on grass field being dragged out by 4wd from stationary winch Our local cost is $245US for 1000metres of rope.DO THE MATH.ITS CHEAP We charge round $8US per launch this to help fund another winch The winch motor is a 5.7ltr V8 petrol driving through an auto box to an old truck axle with diff modified to drive one side at time (your common winch) The difference is the drums.The drums have a centre core cut from the old front wheel of a road roller 12ml thick hardened steel (we got it for free)and the side plates 10ml thick with a welded on bevel at the top to act as a guide. All this to stop the crushing effects.of the stretched rope I have the email of one of the main members who helped in the experimentation stage and is on the instructor,s panel so can explain the changes to the flight training on winch launching with our style of winch. Another club has also switched to this method and is having the same success as we are on a similar strip length.Most single seaters are getting close to or +50% of rope length in height. Trials at another club with 5400ft of runway found that the sag in the rope with longer lengths tended to get premature releases in top third of launch as angle of the rope into the release was not as flat. This was a limited number of launches. gary Gary, Thanks for the information. Now, if the poly could be spliced ~50/50 or so with something like 1/8" Validator 12 http://www.samsonrope.com/admin/data...dator12_LR.pdf , (Vectran) http://www.pelicanrope.com/peli05c.htm both the bungee and sag effects could be reduced with some cost benefits. This could be a solution for long runs. When we launched with 1000ft of Spectra on the end of the wire rope, we didn't pull the Spectra through the rollers. Two synthetics with a reasonable join might work well as a hybrid solution. Vectran is stronger than Spectra with a higher critical temperature, but with somewhat less abrasion resistence. There are some interesting 1/4" vectran sheathed products http://www.pelicanrope.com/new04.htm for improved abrasion resistence. And Plasma 12 http://www.cortlandcable.com/psrope/...PlasmaRev9.pdf Spectra in a variety of sizes. Frank Whiteley Colorado |
Vectran would not be a very suitable winch rope. It tends to fatigue
relatively rapidly with bending. It is useful as standing rigging on sailboats but isn't used for running rigging. Technora is about the same tensile strength and modulus (both have very high modulus) without the fatigue problem. I don't have any proof of this but was told this by someone who appeared to know quite a lot about all the various new fibers being used in rope. Gary, Thanks for the information. Now, if the poly could be spliced ~50/50 or so with something like 1/8" Validator 12 http://www.samsonrope.com/admin/data...dator12_LR.pdf , (Vectran) http://www.pelicanrope.com/peli05c.htm both the bungee and sag effects could be reduced with some cost benefits. This could be a solution for long runs. When we launched with 1000ft of Spectra on the end of the wire rope, we didn't pull the Spectra through the rollers. Two synthetics with a reasonable join might work well as a hybrid solution. Vectran is stronger than Spectra with a higher critical temperature, but with somewhat less abrasion resistence. There are some interesting 1/4" vectran sheathed products http://www.pelicanrope.com/new04.htm for improved abrasion resistence. And Plasma 12 http://www.cortlandcable.com/psrope/...PlasmaRev9.pdf Spectra in a variety of sizes. Frank Whiteley Colorado |
I was not present at the original trials but I believe the extra height from
Spectra type rope was about the same as the poly. The one other effect of poly is its memory seems to be only to shrink into its own length and if released under tension pulls away from the glider and only throws loops towards the winch but they do not reach the winch if the drum is stopped no tendency for the ends to whip . I saw a suggestion about nylon earlier in the thread to create the bungee effect but correct me if I am wrong but nylon does tend to whip out gary "Bill Daniels" wrote in message link.net... I have nothing against cheap rope, if the long term economics work. But, if you reduce the question to how much extra it costs for each launch, an all spectra rope would likely add less than $1 US per launch and return an extra 25% in height achieved, at least on long (5000 feet+) winch runs. (Don't expect to see that much extra height on short runs.) For me, adding $1 to the launch costs for a higher, sweeter, more reliable launch is well worth it. Tweaking an ex-automobile engine for more output is an expensive way to go in the long run since it tends to make for a peaky torque curve and less reliability. What seems to work best for a winch is an engine with a flat power curve and a huge torque reserve. Every automobile power train that I have seen used in glider winch had problems of one kind or another - usually inadequate control of the launch because of the transmission shifting to accommodate the peaky torque curve. Getting an engine stolen is a security issue, not a winch design issue. But, if the engine had been a 3000 pound diesel, the bandits would have probably left it alone. Bill Daniels "goneill" wrote in message ... There is talk of trying a hybrid to eliminate line sag for longer runs,have to wait and see on that one. The point about the rope storing energy equal to a bigger engine, well we are already using a 5.7 ltr V8 with performance mods to get high output,to get more pull is going to cost a lot in terms of the engine verses $250US for 1000 metres of poly. The second part of this is the club 1.5hrs drive south of us had their winch motor stolen because it was very highly tweaked up and a prize worth stealing gary "Bill Daniels" wrote in message hlink.net... Actually, I'm not sure the economic effect would be positive. The rope that winds onto the drum first doesn't see much wear so the effect of using cheap rope might not be significant. Looking at the big picture, the cost difference per launch for cable replacement might not be worth the hassle of using two kinds of rope. The price of high-strength synthetics is coming down anyway. All the engineering data I have says Spectra will outlast lesser synthetics by a factor of 10 or more. Nothing wrong with experimenting with cheaper materials though. If you want a "bungee effect", then nylon would be a better material than poly. The bungee effect is a way to store engine power and then release it at the point of peak power demand with the result that a smaller engine can do the work for a larger one. My gut reaction is that it would be better to use a larger engine and no bungee effect - an engine is controllable and the bungee effect is not. A stretchy rope is a step away from precise control of the launch. In my experience, most problems that arise in winch operations come from poorly thought out efforts to save money up front. The best way to save money is to do the thing right the first time. Bill Daniels "F.L. Whiteley" wrote in message ... 1. with a hybrid solution on a LONG (=5000ft) run, you still get 2500ft of bungee effect at the beginning of the launch (not sure that 5000ft of bungee effect is wanted) 2. then ELIMINATE the sag as the launch gets higher using the lighter and thinner and more expensive rope I'm not suggesting this for launch runs of 1000m, but those about 1400m length or greater where someone has already demonstrated that 10mm poly has issues of weight and drag. Frank "goneill" wrote in message ... Big point ,the bungee effect is VERY DESIRABLE at the initial acceleration and rotation into the full climb,this is where the extra height is coming from , no wasted field length ,the penalty for the bungee effect is at the top of the launch where the the winch needs to have the release with no tension so the rope does not catapult at the winch and snag in the feed guide. A number of single seaters are requesting 70 knots on the winch and dipping the nose for release then pulling up with the residual speed often getting 1600-1700ft. Overall the good effects outweigh the few minor problems created ,these problems are negated by operational changes gary "F.L. Whiteley" wrote in message ... "goneill" wrote in message ... Other info now obtained poly is 10 millimetres diameter and with use shrinks to 8ml Durability is 1000-1500 launches on grass field being dragged out by 4wd from stationary winch Our local cost is $245US for 1000metres of rope.DO THE MATH.ITS CHEAP We charge round $8US per launch this to help fund another winch The winch motor is a 5.7ltr V8 petrol driving through an auto box to an old truck axle with diff modified to drive one side at time (your common winch) The difference is the drums.The drums have a centre core cut from the old front wheel of a road roller 12ml thick hardened steel (we got it for free)and the side plates 10ml thick with a welded on bevel at the top to act as a guide. All this to stop the crushing effects.of the stretched rope I have the email of one of the main members who helped in the experimentation stage and is on the instructor,s panel so can explain the changes to the flight training on winch launching with our style of winch. Another club has also switched to this method and is having the same success as we are on a similar strip length.Most single seaters are getting close to or +50% of rope length in height. Trials at another club with 5400ft of runway found that the sag in the rope with longer lengths tended to get premature releases in top third of launch as angle of the rope into the release was not as flat. This was a limited number of launches. gary Gary, Thanks for the information. Now, if the poly could be spliced ~50/50 or so with something like 1/8" Validator 12 http://www.samsonrope.com/admin/data...dator12_LR.pdf , (Vectran) http://www.pelicanrope.com/peli05c.htm both the bungee and sag effects could be reduced with some cost benefits. This could be a solution for long runs. When we launched with 1000ft of Spectra on the end of the wire rope, we didn't pull the Spectra through the rollers. Two synthetics with a reasonable join might work well as a hybrid solution. Vectran is stronger than Spectra with a higher critical temperature, but with somewhat less abrasion resistence. There are some interesting 1/4" vectran sheathed products http://www.pelicanrope.com/new04.htm for improved abrasion resistence. And Plasma 12 http://www.cortlandcable.com/psrope/...PlasmaRev9.pdf Spectra in a variety of sizes. Frank Whiteley Colorado |
How about this "bungee effect" scenario:
You accelerate the glider smartly and stretch the rope. The glider lifts off normally but encounters a strong headwind layer at 100 feet AGL. The pilot frantically signals for less speed and the winch driver promptly reduces power, but the "bungee effect" just keeps pulling the glider faster until the stored energy is depleted. Then the glider airspeed sags as the reduced winch engine power is felt. The pilot signals for more speed and the winch engine throttle is again advanced, but the additional power is absorbed in stretching the rope before the glider sees the additional speed. Then repeat cycle. I once tried auto tow with 3000 feet of 5mm nylon and this is what I encountered. We never did tame the launch so we went back to steel wire. _______ This is a very bad way to control a launch unless the winch power is set very low so the glider pilot controls airspeed with pitch attitude. I don't like the idea of winch rope that stretches any more than needed to damp vibrations. I like the idea of instantaneous airspeed response to throttle changes. Spectra stretches less than 1% at the failure point. Spectra is pretty much a "drop in" replacement for steel wire except that it is 90% lighter. It's much better to have reserve power from a large, high torque engine and a winch line with little stretch. My dream winch is a powerful one that has a telemetry link to the glider. The winch pulls the glider to the desired airspeed at the maximum safe acceleration and holds it precisely there while the pilot pulls up to tension the rope to 80 - 90% of the weak-link breaking point. That is the definition of an optimized launch. Bill Daniels |
First line of your reply is the wrong way round, the full power signal is
given and about 1-2 seconds stretching later the glider accelerates very rapidly and is airborne 1-2 fuse lengths, depending on which glider and winch power setting has been used you have a very short initial climb phase and have to rotate to full climb or you will overspeed ,the winch reduces his power setting as you rotate into the full climb arc. We are not talking a huge effect here and your reference to your use of nylon as a launch rope ,if I am correct nylon has far more spring in it than poly. Autotow we do here for fun every now and again and the acceleration is slower The other thing to remember is this club and other clubs have dialed up many thousands of launches on this poly rope and it has shown to be consistant and predictable in the bungee effect gary "Bill Daniels" wrote in message link.net... How about this "bungee effect" scenario: You accelerate the glider smartly and stretch the rope. The glider lifts off normally but encounters a strong headwind layer at 100 feet AGL. The pilot frantically signals for less speed and the winch driver promptly reduces power, but the "bungee effect" just keeps pulling the glider faster until the stored energy is depleted. Then the glider airspeed sags as the reduced winch engine power is felt. The pilot signals for more speed and the winch engine throttle is again advanced, but the additional power is absorbed in stretching the rope before the glider sees the additional speed. Then repeat cycle. I once tried auto tow with 3000 feet of 5mm nylon and this is what I encountered. We never did tame the launch so we went back to steel wire. _______ This is a very bad way to control a launch unless the winch power is set very low so the glider pilot controls airspeed with pitch attitude. I don't like the idea of winch rope that stretches any more than needed to damp vibrations. I like the idea of instantaneous airspeed response to throttle changes. Spectra stretches less than 1% at the failure point. Spectra is pretty much a "drop in" replacement for steel wire except that it is 90% lighter. It's much better to have reserve power from a large, high torque engine and a winch line with little stretch. My dream winch is a powerful one that has a telemetry link to the glider. The winch pulls the glider to the desired airspeed at the maximum safe acceleration and holds it precisely there while the pilot pulls up to tension the rope to 80 - 90% of the weak-link breaking point. That is the definition of an optimized launch. Bill Daniels |
On Fri, 2 Jan 2004 17:39:28 +1300, "goneill"
wrote: We are not talking a huge effect here Agreed. I was watching launches at Auckland a few weeks ago and didn't notice any gross bungee effects. All the launches I saw looked pretty smooth. One question: I saw that you were using a long plastic covered strop between the drogue and glider, but could not see either a weak link or a set of colour coded strops. Did I miss something? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
The weak link is there between chute and strop
so when the pilot pulls the bung there is something relatively large to find attached to the rings. The strop seems to come down slower than just the rings gary "Martin Gregorie" wrote in message ... On Fri, 2 Jan 2004 17:39:28 +1300, "goneill" wrote: We are not talking a huge effect here Agreed. I was watching launches at Auckland a few weeks ago and didn't notice any gross bungee effects. All the launches I saw looked pretty smooth. One question: I saw that you were using a long plastic covered strop between the drogue and glider, but could not see either a weak link or a set of colour coded strops. Did I miss something? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
On Sat, 3 Jan 2004 08:36:59 +1300, "goneill"
wrote: The weak link is there between chute and strop so when the pilot pulls the bung there is something relatively large to find attached to the rings. .....makes sense -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Martin Gregorie wrote: On Fri, 2 Jan 2004 17:39:28 +1300, "goneill" wrote: We are not talking a huge effect here Agreed. I was watching launches at Auckland a few weeks ago and didn't notice any gross bungee effects. All the launches I saw looked pretty smooth. I took a couple of winch launches at Puhipuhi in a Janus on I think poly rope last week. Seemed pretty smooth, and I didn't notice bad effects from stretching. Not that I got much height from my own pathetic attempt (less than 1000 ft), but it was enough to get away... -- Bruce |
More Spectra Winch Rope | Bob Johnson | Soaring | 0 | December 24th 03 05:45 PM |
Spectra winch rope | Bob Johnson | Soaring | 0 | December 24th 03 04:25 PM |
Tow Rope Freindly Fences | John Spargo | Soaring | 8 | September 2nd 03 04:17 AM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
Using Plasma Rope For Winch Tows | Craig Freeman | Soaring | 56 | August 24th 03 10:55 PM |
