Transponders
Old January 22nd 04, 06:22 AM
bumper
How long the battery lasts will depend on how big it is (yes Virginia,
bigger is better), what its state of charge and condition is, what the
current draw of the transponder is (don't forget the blind encoder), what
the interrogation rate is, and if you also have solar panels . . . oh, and
how fast you pedal.
bumper ZZ (reverse all after @)
"Dare to be different . . . circle in sink."
"CH" wrote in message
news
and how long does the battery last?
with the transponder on?
Australia decided, that planes without a permanent source
of power on board, do not need transponders in mixed
airspace.
I would prefer, that IFR traffic out of airport airspace should
fly higher than the convection height from sunrise to sunset :-)
How's that??
Chris
"Ben Flewett" wrote in message
Are you on drugs? This is a bad idea for so, so many
reasons. Here are a few...
1. I don't want to pedal.
2. My feet are busy operating the rudder.
3. My cockpit is a constant state of crisis, which
allows no time for pedalling.
4. I sometimes fly in airspace for hours at a time.
I resent have to move the stick for hours at a time,
let alone having to pedal for hours at a time.
5. Weight.
6. Complexity.
7. I like a simple life.
8. I don't want a bearded sandal wearer installing
weird science contraptions in my glider.
Here's an idea. Why not use a battery?
At 15:00 21 January 2004, Vaughn Simon wrote:
'Mil80C' wrote in message
A question to you fine soaring fraternity, what would
your response be to
someone who suggested that it might be feasable to
run a transponder in a
glider with a pedal generator?
A raised eyebrow, a polite silence, a glance at
my wris****ch, followed
by a graceful withdrawal.
Vaughn
BEER! So much more than just a breakfast drink!
Old January 22nd 04, 09:26 AM
Ramy Yanetz
$30 will get you an extra battery which will run your transponder longer
than you can stay in the air. Unfortunately many pilots as well as the FAA
don't know this.
Ramy
news
airspace.
How's that??
Chris
5. Weight.
6. Complexity.
your response be to
Vaughn
Old January 22nd 04, 10:10 AM
Ben Flewett
I have two batteries and have flown for many hours
on transponder - no problem. The drain is higher if
you use mode C (height encoding) but still no problem.
source
airspace.
should
to sunset :-)
How's that??
Chris
'Ben Flewett' wrote in message
5. Weight.
6. Complexity.
your response be to
at
Vaughn
Old January 22nd 04, 10:13 AM
Mil80C
Thanks all for your responses, the idea was posted in another NG and as I am
not of the soaring fraternaty, could not speak against it with any
experience. I will say that as an ATC, I will allways support your sport.
"Ramy Yanetz" wrote in message
om...
don't know this.
Ramy
news
airspace.
How's that??
Chris
5. Weight.
6. Complexity.
your response be to
Vaughn
Old January 22nd 04, 02:23 PM
Chris Nicholas
Mil80c , another point you need to be
aware of;
Many gliders, e.g. mine (a Ka6E), have neither panel space for a
transponder nor capability of carrying any more weight for the extra
batteries - I am already on max AUW, on a CofA which has already been
extended as far as it can be - I am 208 pounds with a parachute, and
there are plenty of heavier pilots than that.
If a new generation of lightweight, low power transponders emerges (the
UK CAA has persuaded one manufacturer to build a prototype which tested
OK), and if ICAO accept 20 w output instead of 100+, and if the thing is
taken to commercial production, and if it can come with an option of a
small remote control panel I could strap to my knee, with the larger
piece and battery going into the stowage behind the pilot's seat, and if
I can lose enought weight to compensate for it, then it might be viable.
I'm not holding my breath while we wait for all that to happen.
Regards - Chris N.
Old January 22nd 04, 05:57 PM
Robert Ehrlich
aware of;
Regards - Chris N.
An experiment in the french Alps made with a group of tow planes
mimicking glider flight, i.e. circling together from time to time has
shown that transponders, except in mode S, may not be very useful in
gliders. As soon as 2 or more gliders are close together, e.g. circling
in the same thermal of working together the same ridge, they are hit
simultaneaously by the radar beam and generate simultaneaously their
responses, which results in both interfering and nothing useful
received at ATC. I had the chance of having one of the engineers
involved in the experiment as a passenger last September and he confirmed
this. In mode S, as each transponder is specifically adressable,
this mess will probably not occur, a new experiment using them is
planned.
Old January 22nd 04, 06:32 PM
Marc Ramsey
planned.
This study is sometimes cited as an excuse to put off installation of
transponders until inexpensive mode S transponders are available. My
take on it is that it addressed a fairly narrow concern, the possible
inability of ATC to properly discern a group of thermalling mode C
equipped gliders. It did not examine whether airborne collision
avoidance systems would continue to provide warnings when confronted by
such situations.
The times when I've been surprised by the close approach of larger
aircraft have been while cruising between thermals, when I'm generally
alone or at a fair distance from other gliders. While thermalling, I
have a view of pretty much the entire sky, and I have a much better
chance of seeing approaching traffic in plenty of time to avoid it.
Marc
Old January 22nd 04, 08:40 PM
Swiftel
:-) bugger - I thought they land vertically...??
by the way - when I flew in "black forest gliding site"
in Colorado 1980, it was possible to fly with the glider
on top over the incoming traffic to the mountains and
higher than a certain minimum height stright over the
airport. Is that still possible in the US in times of new
home security or is it now forbidden and are you will
be shot down and then imprisioned under Ashcrofts
creation, the patriot act?
Chris
Aye, and that's the rub: they come down to the airport, don't they? And
the airport airspace doesn't go all the way up to 18000 here in the USA,
but only to about 10,000 or so. And the buggers don't drop down into the
top, but slide in from the side. Can you believe it?
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old January 22nd 04, 09:06 PM
Eric Greenwell
planned.
such situations.
Surely this situation occurs at Minden regularly. Does Reno ATC have
trouble "losing" gliders when they thermal together? Or are they still
aware that something is located there, even if Mode C info is lost? And
even if it is a problem, doesn't ATC still much prefer gliders to have a
transponder than not?
I'd expect at least ONE good signal to be received every 5-15 seconds,
as the gliders' positions change and one antenna is in a much better
position the other ones.
Eric Greenwell
Washington State
USA
Old January 22nd 04, 09:21 PM
Eric Greenwell
aware of;
Transponder + encoder = 1 kg
7 amphour battery = 2.3 kg
ant and cable = .4 kg
mounting all of it = .5 kg
TOTAL = 4.2 kg or 9.3 pounds
If this is what is keeping you from installing a transponder that you
think you need, I suggest you take another look at your priorities. Put
in the transponder by - losing 10 pounds; getting a lighter parachute;
removing something from the panel; flying 10 pounds overgross and cut
your critical speeds a couple of knots. Or, if you want to spend about
$600-700 more, get the Filser Mode S when it's available and shave off a
couple pounds using a smaller battery and no external encoder.
Eric Greenwell
Washington State
USA
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 01:15 PM
Dual Transponders? Scott Aron Bloom Instrument Flight Rules 17 December 14th 03 05:54 AM
Mode S Transponders - Can ATC tell the difference? Doodybutch Owning 2 August 10th 03 06:21 AM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 2nd 03 11:27 PM
