Stewart Kissel wrote:
Well it is mid-winter, when Puch-spinning competes with the PW-5 flaming, 2-33 viability, and what-sorta-hat-to-wear as a topic. (NOT INTENDED TO MAKE LIGHT OF THE SERIOUSNESS OF THIS TOPIC) After a review of old threads on this topic, I was interested in not finding a pilot's report on difficulty in the spin-recovery characteristics of this ship. Anyone out there in ras-world care to comment on a first-person experience? The club I am a member of requires spin training in the Puchatz prior to flying it solo. To demonstrate that a spin is not an uncontrollable event he had me enter the spin from a nose high attitude, just prior to the stall I kicked in rudder. I was then to hold the glider in the spin for two full revolutions before taking it out. I had to do that in both directions. After that we took another tow and I did 3 or 4 incipient spins in each direction. The spins were totally predictable. I do not recall how long it took to recover from the fully developed spin, but I never had the feeling we were not going to get out of it. In the spin the Puch's nose will go beyond vertical. You can really notice this when flying from the backseat. (The Blanik L-13 will do this also.) I was very happy for the spin training I got. Since then I have gotten into two inadvertent spins. Both times I recognized them for what they were and recovered with a minimal lose of altitude and no panic. BTW, now that I am an instructor I teach spins differently. No one gets in trouble from an intentional stall then kicking the rudder over to induce the spin. I teach it by simulating a low approach on base leg. In this situation the pilot is inadvertently pulling the stick back, trying to keep the plane up, but actually only lowering its speed. Often times folks will then make a shallow turn to final, on the mistaken believe that a shallow turn will loose less altitude. The turn is initiated in the same place they normally would make their turn. When it becomes apparent that the runway will be overshot, still not willing to steeply bank the glider, it is then over rudder to try to make the turn. Since the pilot has been pulling back on the stick he is now slow enough to cause a stall and resultant spin too low to the ground to recover. After explaining on the ground what we are going to do I demonstrate the spin , at quite high altitude. I will allow the glider to do about half a spin revolution. This is enough to get the students attention to the seriousness of this happening at low altitude, but not enough to waste a lot of altitude or severely scare the student. I then have them practice entering and recovering incipient spins in both directions. I do not solo any student or transition pilot until they can explain and demonstrate what causes a spin and how to recover from one. At 15:42 23 January 2004, Owain Walters wrote: Everyone is always an expert arent they? Why do internet lurkers always have an opinion on things they dont know the first fact about? |
![]() "JC" JRC at visi dot com wrote in message ... In the spin the Puch's nose will go beyond vertical. You can really notice this when flying from the backseat. (The Blanik L-13 will do this also.) (What follows is part of my standard pre-flight briefing to students before teaching spins -the pro's can ignore if they wish.) Various gliders may in fact go past the vertical with respect to the ground but there is more to it. Most of us have the mental picture of a spin entry sequence as if the glider stops all its forward motion at the stall and thereafter proceeds straight down in the spin. With a bit of thought, this is seen as wrong. In fact, the glider carries substantial forward motion through the stall and into the spin. The result of this is that the path of the gliders center of gravity traces an arc that transitions from level flight to vertical in the spin. (Imagine the path of a Badminton birdie.) Usually, the first full turn or two of autorotation is in this arc so that, at the 180 degree points, the glider is somewhat inverted with respect to the ground. To the pilot, this appears as if the spin is asymmetrical as the glider first goes past the vertical and then rotates to a more nose-up attitude. This may well be the source of a lot of the, "Wow, that glider spins funny", or "It tries to go flat in the spin", type of statements. If the pilot holds the glider in the spin, the path will become vertical and, from the perspective of the pilot, will appear to spin symmetrically. With some gliders, I have seen this take two or more turns. If the recovery is attempted at the first 180 degree point, the glider will reach a higher airspeed in the dive recovery and burn more altitude. A better technique is to apply anti-spin controls at a point that will stop the rotation at the 360 degree point. The difference in altitude loss can be substantial. The higher the airspeed at which the stall break occurs, and the faster the glider snaps into the spin, the more pronounced this effect appears. Bill Daniels |
On 23 Jan 2004 15:52:31 GMT, Stewart Kissel
wrote: Well it is mid-winter, when Puch-spinning competes with the PW-5 flaming, 2-33 viability, and what-sorta-hat-to-wear as a topic. (NOT INTENDED TO MAKE LIGHT OF THE SERIOUSNESS OF THIS TOPIC) After a review of old threads on this topic, I was interested in not finding a pilot's report on difficulty in the spin-recovery characteristics of this ship. Anyone out there in ras-world care to comment on a first-person experience? I'm due to do annuals some time between now and the start of March, which will involve spinning the Puchacz. I'm rather looking forward to it: I enjoy spinning at a sensible altitude. As others have said, in general its a predictable glider: no surprises in spinning. However, I have been warned that if you start to pull out too soon AND still have a bit of anti-spin rudder on it will flick-roll in the opposite direction and that the only way out of that is to complete the barrel. Its a fairly draggy glider, so I always pause a bit longer than usual after the spin stops before starting to pull out. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
I don't claim any great expertise on the Puchacz but
my limited experience of spinning it (BGA Instructor's course) is that it is predictable and 'standard' in its recovery. I have been told (though not tried it myself) that if aggressively entered into the spin - i.e. from a high-nose stall - it will tuck its nose very low as it spins, even going past the vertical. That could be disconcerting and make recovery harder but the standard actions always work. I knew John well, by the way, and know that he would have been current as he instructed regularly midweek at Dunstable as well as his home club. I don't know how current he was on the Puch. Rob At 15:54 23 January 2004, Stewart Kissel wrote: Well it is mid-winter, when Puch-spinning competes with the PW-5 flaming, 2-33 viability, and what-sorta-hat-to-wear as a topic. (NOT INTENDED TO MAKE LIGHT OF THE SERIOUSNESS OF THIS TOPIC) After a review of old threads on this topic, I was interested in not finding a pilot's report on difficulty in the spin-recovery characteristics of this ship. Anyone out there in ras-world care to comment on a first-person experience? At 15:42 23 January 2004, Owain Walters wrote: Everyone is always an expert arent they? Why do internet lurkers always have an opinion on things they dont know the first fact about? |
Hmmmmm, This is terribly sad to read (and my prayers
will be for their family and friends) but also very pertinent as last Sunday, I took an aerotow to 3000' and did my 'spinning' and some further exercises in spinning. What aircraft did I have all this fun in. . . You guessed it, a Puch. . . . Hmmmm, slightly sick feeling in the stomach. . . It will be interesting to read some more detail of the cause and specific details if they are known. My experience was very positive, the a/c span very quickly under the instructor's control as I had been briefed. I just did what it said on the can and was very pleased to feel the G as I recovered and found the a/c behaving as per the briefing. Having said all this and to end on a postive note, I am hoping to get my first flight in a single seater this weekend, probably tomorrow, hope you vastly experienced guys (& gals) can remember just how excellent I'm sure that must have felt! Any tips??? At 15:06 23 January 2004, Todd Pattist wrote: Al Eddie wrote: The issue is more likely to be of type familiarity and recency in general, not the fact that a particular aircraft type is totally predictable in its behaviour. Upon what facts do you base your conclusion that the aircraft has spinning characteristics that are 'totally predictable?' Questions have been repeatedly raised about the spin behavior of this aircraft. I don't know if it has any problem, and I don't know if it has more accidents than any other type. I do know that it is possible for an aircraft to have unusual flight modes and spin modes that are difficult to enter and may occur only rarely in specific flight attitudes or other seldom encountered conditions. Unfortunately, we don't have perfect knowledge about what happens in all accidents. I don't think you can rule out unpredictable behavior in the spin, nor attribute the accident to a lack of 'type familiarity and recency in general.' Todd Pattist - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) David Pye Kent Gliding Club Charing Mob: 07946-302975 Home: 01732-873088 East Malling, Kent, UK |
details if they are known. You'll be lucky! Accident reports are rarely released in any detail. Most seem to get a one or two sentence wrap up in the back of the S&G Magazine. The feedback loop to pilots IMVHO is atrocious. Ian Molesworth |
There are two sources for U.K. accident and incident reports.
Those accidents which are investigated by the government may be found at: Department of Transport, Air Accident Investigation Bureau http://www.aaib.gov.uk/ , Bulletins (from 1996). The reports are also published in a printed monthly pamphlet sent to all UK flying organisations including gliding clubs. The snag with this database is that it is in order of date (by month) of publication of the report, and I have not found a way of searching by accident date. I have made out my own index on a word document, to link by accident date to the report, of the accidents which interest me; most of these are to tugs (all of which are reported), a few are serious glider accidents. The other source is the British Gliding Association for accident and incident reports where the BGA lead the investigation. A very short summary appears in Sailplane & Gliding, and is also included in an annual summary available in print from the BGA. At one time there was a link on the BGA web-site to an on-line copy put up by the Essex club. However I cannot now find that link, and the last time I looked that database had not been updated for several years. According to the terms of reference of the BGA Accident Investigators (available on-line at http://www.gliding.co.uk/forms/subcommitteesterms.pdf see the last of 12 pages), "Subsequent to each investigation a report is to be prepared, to the format of the Air Accidents Investigation Branch ("AAIB") of the Department for Transport ("DfT"), ----- ". I have never seen or heard of any of these reports being published or made available, they are not even given to pilots directly involved in accidents or incidents, or sent to the reporting club. The DfT publish the reports, why not the BGA? I think this is a disgrace. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "tango4" wrote in message ... It will be interesting to read some more detail of the cause and specific details if they are known. You'll be lucky! Accident reports are rarely released in any detail. Most seem to get a one or two sentence wrap up in the back of the S&G Magazine. The feedback loop to pilots IMVHO is atrocious. Ian Molesworth |
![]() I make no comment regarding the accident other than to say it is truly saddening. As far a the Puchacz goes: In my limited experience I find it will spin more readily than any other two seat training aircraft that I have flown. It also demands correct spin recovery actions to recover. Failure to do so can result in no recovery or reversal of spin direction. Flown within in its weight limits, I have found no problems. However, as an instructor, I continually find a problem with peoples spin recovery technique - particularly so when they are not current. The main problem I find is people not applying FULL opposite rudder. Usually I find it's actually half to two thirds. It's possible to get away with this in just about any other glider used for training, but try it in a Puchazc and the chances are it's not going to work. I'm also astounded by the amount of people who really believe that they are applying FULL opposite rudder when they actually are NOT. I've even had reasonably high houred pilots argue that they had full rudder in when they actually did not. The other one I see almost as much is the stick going forward ok but still with some 'in spin' aileron in. If you waffle round a turn slow and with incorrectly co-ordinated controls in a K13, K21 etc chances are you'll probably get away with it unless you drastically provoke it. If you do it in a puchacz then the chances are that it will bite. No suprises here - it demands correct flying. If you do spin your K13, DG500 etc and you apply your two thirds rudder in recovery chances are it'll work just fine. Spin your Puchacz with half a bootfull of rudder in your recovery and chances are it won't work. Personally speaking, I really concentrate hard on making sure I feel that pedal go right on to the stop and the stick go centrally forward. IMHO I suspect people get molly coddled flying around in docile aircraft that don't highlight innacurate flying. I also suspect that alot of people don't regularly spin themselves whilst flying solo and REALLY concentrate on what they are ACTUALLY doing whilst recovering. At 17:18 23 January 2004, Tango4 wrote: It will be interesting to read some more detail of the cause and specific details if they are known. You'll be lucky! Accident reports are rarely released in any detail. Most seem to get a one or two sentence wrap up in the back of the S&G Magazine. The feedback loop to pilots IMVHO is atrocious. Ian Molesworth |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Cirrus and Lancair Make Bonanza Obsolete? | Potential Bo Buyer | Owning | 211 | November 20th 03 05:29 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
