On Thursday, May 25, 2017 at 7:00:44 PM UTC-4, wrote:
Just double checking my understanding of the see you mobile, (Oudie) reserve altitude correction. If I set my reserve at 1000' and my target field is at 700' and my "Arrival Altitude" says 2700' ... does that mean I will arrive at 3700' essentially 2000 above the ground? Dennis DC Thank you all. I just wanted to double check the logic. Yes Evan I think you are right in keeping the information unfiltered is ultimately the way to go. Dennis DC |
Reserve alt. is less and less helpful the farther out you are. Glide ratio will become the dominant factor when you are 25 miles out.
With Oudie, I tend to do the following: First, make sure your ship's actual performance comes close to what the polar says. You can adjust (degrade) it by flying a final glide on a still air day and using the "bugs" setting. Fly the correct STF and watch your arrival altitude. if it starts to drop, your glide ratio is worse than the Oudie thinks- add in a few points of bugs and continue doing this until arrival altitude remains more or less constant over 5 minutes. As an example, I always set "bugs" to 6% in my ship. I set my safety height to 1500'. Your milage may vary, but I like flying the pattern a bit higher/faster anyway. You can use the arrival alt. to plan your exit from your final climb. Once you have climbed 0-500' above final glide, leave the thermal (YMMV) and head home. Make sure your MCCready is set to what you want FIRST though, as it will effect your glide slope. Set up the Oudie to display both your current L/D and required L/D to your target. No matter how far out you are, this will tell you if you are going to make it home, IF conditions remain constant (current L/D required L/D) I also like to set the Oudie to display required L/D to each airport on the map. That way I can tell at a glance what is reachable and how challenging it might be to get there, based on my current L/D. Everyone has a different way of thinking about all this. I am just sharing what works for me. Matt H |
| Thread Tools | |
| Display Modes | |
| Good News on Delorme InReach (2 min tracking and altitude vs. Spot w/10 min tracking and no altitude) | Sean F (F2) | Soaring | 34 | February 24th 13 01:46 AM |
| Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 08:41 PM |
| GPS altitude vs altimeter altitude | Chris W | Piloting | 37 | April 19th 06 11:45 AM |
| Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 11:48 AM |
| FA: New ASA IP Trainer V6.5 IFR - no reserve | Scaggs Island Pilots Supplies | Aviation Marketplace | 0 | August 26th 03 04:07 AM |
