In-Flight CG Calculation
Old May 30th 17, 01:28 PM posted to rec.aviation.soaring
Default In-Flight CG Calculation
On Tuesday, May 30, 2017 at 1:04:35 AM UTC-4, JS wrote:
On Monday, May 29, 2017 at 2:55:51 PM UTC-7, Matt Herron Jr. wrote:
On Monday, May 29, 2017 at 8:47:42 AM UTC-7, wrote:
On Monday, May 29, 2017 at 11:28:43 AM UTC-4, Matt Herron Jr. wrote:
On Monday, May 29, 2017 at 6:20:59 AM UTC-7, wrote:
Just curious if current technology could easily/cheaply support this calculation ... using a couple of accelerometers ... kk
are you concerned with dumping water and changing your CG?
Hi Matt ... not really, the factory numbers and methods we all use are sound and time tested ... and I just used these methods to calculate CGs for an empty ship - and with pilot and chute - just to know 'exactly' where the CG is located. I was just curious if CG could be calculated in flight ... using hardware/electronics that are available today. Just a question on a rainy afternoon in Delaware. kk
May I humbly recommend a C of G program I wrote specifically for gliders? It's called SeeG and is available he http://www.glideplan.com/styled-2/page12/index.html
Lots of discovery tools for adding moments, playing with water, charting effects of changing CG, etc.
Matt
Matt, you beat me to it.
Was going to ask Kilo Kilo the millennial question:
"Don't they make an app for that?"
Hey ... I'm not one of those millennials ... I'm a grumpy senior citizen .... :-)
Old May 30th 17, 01:57 PM posted to rec.aviation.soaring
I have found that when the CG is right (best climb), I don't need to trim aft when entering a thermal. If you have a tail tank, keep adding a small amount of water on each flight until you don't have to trim aft anymore, then put that amount of lead in the tail. This is mainly true for flapped ships, but I have found the Genesus-2 no longer needs aft trim when the CG reaches about 90% of allowable range and that's where she climbs best. The Nimbus-3 likes to be near 100%, as does the ASW-20, but the LS-6 likes to be about 85% of allowable. When I flew the 6 with CG near 100%, I found I was trimming forward when entering a thermal, indicating my CG was too far aft.
So, if you buy into this, your trim knob becomes your in flight CG indicator!
JJ
Old May 30th 17, 03:36 PM posted to rec.aviation.soaring
Matt Herron Jr.
Changing the CG will have an effect on the longitudinal stability of the glider. In theory if you could measure the frequency of the short-period oscillation you could estimate the location of the CG. I believe this is because changing the CG changes the longitudinal radius of gyration of the glider - more aft CG - larger radius of gyration - longer period oscillation (I think). You can look at some equations for longitudinal modes he
http://www.iitk.ac.in/aero/fltlab/dynamics.html
I'd say it's not a practical thing to hope for. The short-period mode is typically on the order of a second or so and I can't imagine being able to conduct an experiment in-flight that would give a very precise indication....unless of course your CG is far enough aft to be statically unstable, in which case your butt will be all the accelerometer you need.
Now, if you could instrument all the fuselage-to-tail and fuselage-to-wing attach points with strain gauges you might be on to something...
Andy Blackburn
9B
Interesting theory, Andy. My guess is that you get a longer oscillation with the CG more forward because as the glider slows up from the last oscillation, and as the effect of the elevator pulling down goes away, the forward CG pulls the glider into a steeper nose down correction. It then takes longer to bleed off the extra speed as it corrects again. Move it even further forward and you get stalls between the oscillations.
Old May 30th 17, 05:11 PM posted to rec.aviation.soaring
JS
JJ's trim handle technique seems the best in-flight indicator, and requires no additional sensors.
What happened to the "That Looks About Right" technique? Isn't that how it all ends up?
The Blanik L13 was great for TLAR. If it went over on the nose when you climbed in the C/G was too far forward, so put the big pilot in the back. The DG1000 is similar, but waits until the wheel brake is applied on landing... Ask the USAF TPS.
From experience, an LS4 with 70 liters of water in the cockpit is beyond the forward C/G limit. Also from experience the Nimbus 3 at 108% and ASW27 at 112% fly nicely.
Wondering what the CG position on XX's test flight of the same N3 with the broken Mercury weight shift system was.
Old May 31st 17, 05:51 AM posted to rec.aviation.soaring
2G
In flight CG measurement is also known as the trim position.
Tom
Old June 3rd 17, 10:10 PM posted to rec.aviation.soaring
JJ: can you explain what you wrote about the trim? Clearly the purpose of trim is to be able to adjust your hand-off speed. Thus if your trim is set for cruise and you stop to thermal you'd need to move the trim somewhat aft? If your CG is so far aft that no change in trim is needed, then the trim control becomes useless and you have no hands-off pitch stability. Moreover, in my experience in several glider types with the CG close to the official rear limit (I am lightweight and thus have always flown that way) the trim still needs to be moved.
Old June 3rd 17, 11:10 PM posted to rec.aviation.soaring
In flapped ships, the speed is controlled by moving the flaps......down and the ship slows down.......up and she speeds up, this happens when the CG is aft at 85 to 100% of the allowable range. Will Schueman wrote about this in his modications to the H-301 Libelle. I first noticed it in my Nimbus-3, on the first flight after adding tail weight to put her at 100% of allowable CG range, I realized after an hour and a half, that I hadn't touched the trim! I have observed the same thing in non-flapped ships, I can slow down my Genesis-2 to thermal speed without the need to apply aft trim (CG @90%)........still needs forward trim to go faster than 65 knots, but she will slow to 45 with a little back pressure and thermal with no back trim required (trim neutral).
Does that make sense?
JJ
302 wind calculation 5Z Soaring 1 March 26th 10 11:56 AM
302 wind calculation AK Soaring 0 March 26th 10 02:47 AM
flight computer calculation Tim General Aviation 1 April 26th 05 10:40 AM
Three leg GS to TAS calculation Mike Rapoport Owning 21 September 12th 04 04:37 AM
The "Complex" TAS calculation Arnold Pieper Soaring 2 December 14th 03 12:22 PM
