most comfortable parachute ?
Old June 8th 17, 01:47 PM posted to rec.aviation.soaring
Default most comfortable parachute ?
On Wednesday, June 7, 2017 at 4:49:25 PM UTC-5, S9 wrote:
Hey all,
I've been flying with a Security 150 for quite a while. It is most comfortable. I tried a Security 350 and it is most uncomfortable. It's time to replace the 150. What chute do you suggest that is very comfortable for those 5+ hour flights?
Thanks Steve
Thanks for the responses. I agree the answer depends as in all questions. Good input on the Nationals vs Softy. The long softy looks very similar to the 150 I have currently. I use a lumbar support pad and that looks like it would work well in the long softy too.
Do most of you use the sheepskin backing or the cotton pad backing or none at all?
long shot.. .Anyone have a long softy for sale?
Thanks Steve
Old June 8th 17, 02:08 PM posted to rec.aviation.soaring
Craig Reinholt
I have a new Softie. It is less comfortable than my previous National 425.
Regarding a ram air chute, they are designed to open softly and they take about 800' to fully open. An emergency round chute is designed to open quickly in 300'-350'. Is your momentary comfort worth that 500'?
Old June 8th 17, 05:54 PM posted to rec.aviation.soaring
On Thursday, June 8, 2017 at 9:08:32 AM UTC-4, Craig Reinholt wrote:
I have a new Softie. It is less comfortable than my previous National 425..
Not true. They are equal or the square is a bit faster. Either way opening time variances between the two overlap. Besides a handle fumble or pilot chute kicking around for a second before inflating will burn far more altitude than any difference between round/square. If I was in the business of selling pilot rigs I would go to the big contests pay a young durable skydiver to jump a round, then jump a square afterwards land and open my order book. Guaranteed every pilot who saw the difference live would bust out a credit card.
Old June 9th 17, 02:54 AM posted to rec.aviation.soaring
Dan Marotta
Good points Gregg. Also in the information I received from Rigging
Innovations was a note that opening time, and hence altitude loss, is a
function of the jumper's attitude at the time of deployment, i.e., if
the deployment is downward to to the side, the opening time will be
longer. Of course, the same holds true for the round parachute.
Dan, 5J
Old June 9th 17, 04:06 PM posted to rec.aviation.soaring
Dan Marotta
"...if the deployment is downward or to the side, the opening time will
be longer."
What I meant to say was altitude loss would be greater.
a function of the jumper's attitude at the time of deployment, i.e.,
if the deployment is downward to to the side, the opening time will be
National 425.
500'?
credit card.
Dan, 5J
Old June 9th 17, 05:55 AM posted to rec.aviation.soaring
Craig Reinholt
Considering the information came from a Master rigger (3+ decades), ex Para-Phernalia manufacturing employee, Dealer for Softie, and over 10,000 jumps, I am pretty certain his information is accurate.
Making assertions about operator error if using a round chute and not with a ram chute and using that as reason for possible performance differences is ridiculous.
Old June 9th 17, 12:08 PM posted to rec.aviation.soaring
There is your problem. Information came from someone in the business of selling round parachutes to the ignorant. Variables in deployment(pilot speed at pulling, pilot chute hesitations, etc.) variables not necessarily operator error, easily offset any difference in opening distance round/square. Although squares are faster and more reliable. And easier to find someone to pack. The most common backup automatic opener used in skydiving for the last 20+ years is set to start the reserve opening at 750' if square reserves(all there are in skydiving now) take 800' to open there are a lot of people who opened at -50' and lived.
Old June 9th 17, 04:13 PM posted to rec.aviation.soaring
Dan Marotta
Am I reading you correctly? Are you trying to BS the situation with
information from "a reliable source"? I'm talking about an FAA TSO
which was tested to the FAA's satisfaction. Dream on, Friend.
Dan, 5J
Old June 9th 17, 02:46 AM posted to rec.aviation.soaring
Dan Marotta
I just spoke with the president of Rigging Innovations and in response
to your claim that the ram air chute is designed to take about 800' to
open, this was part of his response: "When we certified the P-124 in
1996 it was only necessary to measure the opening time. The TSO standard
called for opening in less that 3 seconds from pack opening to inflated
canopy. There was no practical method to measure the altitude loss.
Today we have newer technology and the current TSO calls for less than 3
seconds OR less than 300 ft altitude loss."
I don't believe I'm giving up 500' by wearing my P-124.
Dan
Dan, 5J
Old June 8th 17, 04:13 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I have had softie and National chutes. My current chute a Butler, with air bladder lumbar support and "crash pad" (little elongated triangle temper foam pad at bottom of chute that fills space between bottom of chute and seat pan. This is by far the most comfortable chute I have ever worn. Loaned it to a friend and he too thought it the most comfortable..
On Wednesday, June 7, 2017 at 2:49:25 PM UTC-7, S9 wrote:
Hey all,
Thanks Steve
Old Parachute Dan Marotta Soaring 9 March 3rd 11 04:51 PM
Comfortable 4 seaters? Paul Tomblin Owning 41 January 21st 05 03:54 PM
Looking for a 28' Parachute MC Soaring 8 January 16th 05 12:09 AM
F.S. Parachute Tom Stowers Products 1 October 1st 04 12:36 AM
Parachute anyone? [email protected] Home Built 18 January 21st 04 07:39 AM
