#11
![]() The bolt in the middle of the scissor should be tightened a little. Then you can lift it from the top without pulling the piston out of the cylinder AS Thanks Al, The problem I had was with a 2-jack set-up on my ASH-25 trailer. Should we be using DOT-3 automotive brake fluid in your jacks? JJ Sinclair |
![]() No brake fluid ,please. Just hydraulic oil or oil from automatic hydraulic car gears gears. AS Oops, I stand corrected. I would like to thank you for making a real quality product. Your fully fumctional trailers make assembling and disassembling the glider a joy, not a burden. Only those who have owned a dysfunctional trailers, can really appreciate the Cobra. Keep up the good work, JJ Sinclair |
Just hydraulic oil or oil from automatic hydraulic car gears gears. AS What Al means is ATF a.k.a. automatic Trans Fluid is ok |
COBRA TALON, COBRA SPOT | Allen Thomson | Military Aviation | 0 | December 9th 03 06:44 PM |
