Flap performance
Old July 19th 17, 05:01 PM posted to rec.aviation.soaring
JS
Default Flap performance
Just:
Always good to have concern about making too big a move, but I believe with time in H301 and Janus, you'll be fine. The Ventus has better glide path control than either.
Get one with modern winglets, or add them. The Ventus A/B without winglets is where the bad reputation came from. While the factory ASW20 is easier to fly, it also improves with good winglets.
Old July 19th 17, 05:10 PM posted to rec.aviation.soaring
For some clarification. I wouldn't call myself "experienced" in a Janus. I've had several flights in it with an instructor. I found it to be an odd mix of surprisingly pleasant (I find it more fun to fly than any other two place ship I've flown, which have all been trainers) and demanding. I recall one point on a particular tow where I asked the instructor to take over. I've never done that before and never since. In hindsight I was probably doing fine but I felt like I was really struggling to keep behind the tug... but I had significantly less experience than I have now and it was only one flight.
My question really was: how does it fly in neutral flaps versus a Discus. I'm not suggesting that I would fly without the flaps. The question is, if I haven't mastered the ship, and the use of flaps am I actually going to be worse off than in a non-flapped ship. I'm looking at the amount that I fly and realistically assessing that I'll likely never master the ship the way a serious competition pilot would. If that's the case, would I actually be worse off in a flapped ship.
Thanks for the input.
On Wednesday, July 19, 2017 at 2:59:05 AM UTC-4, Just Me wrote:
I'm considering purchasing a Ventus B. I'm aware of the "stability" issues, although some the extent of the stability issue seems to vary from plane to plane and pilot to pilot. I've talked to some people who say its not a big deal, and others who say its problematic. It's hard for me to know what to expect.
However, I was discussing flaps with a flight instructor and a question came up: How does a Ventus in neutral flaps compare to a Discus (I'm aware of the handling difference)? If you are in competition, flying a flapped ships, against other flapped ships, you better be an expert with the flaps. But if you are doing cross country work, are flaps essentially just an asset that is optionally available to allow you to slow down in a thermal or speed up in cruise.
He asserted that the Discus wing was considerably more advanced than the Ventus wing, and that you had to effectively use the flaps or you were actually better off (performance wise) with the Discus -- ie if you aren't flying a lot, you should stay away from flaps.
Can anyone compare the performance of a Discus to a Ventus, or better yet, does anyone have polars for a Discus and a Ventus (as a function of flap setting)?
FWIW, I have about 200 hours, and have flown flapped ships, including a 301 Libelle and a Janus -- as well as a wide variety of other non-flapped ships.
Old July 19th 17, 05:31 PM posted to rec.aviation.soaring
Tango Whisky
Le mercredi 19 juillet 2017 18:10:25 UTC+2, a écritÂ*:
I have been flying as instructor in a group where we were doing ab-initio training on a Janus B. Students were told to leave the flaps alone and in neutral position until post-solo training, and that worked pretty well.
Bert "TW"
Old July 19th 17, 05:57 PM posted to rec.aviation.soaring
Jim White[_3_]
I once flew my 27 alongside a Discus2a over a 40k glide in a comp in still
air. Both at 55kts me in neutral flap. At the end of the glide I was about
200ft better off.
At 100kts, I think I would have him by significantly more!
Old July 19th 17, 06:36 PM posted to rec.aviation.soaring
Bruce Hoult
I've taken a fair number of first timers (or power transition pilots) in a Janus A. I always put it into +6 and left it there for them. Calmed it down a lot and made it act about like a Grob.
Old July 19th 17, 06:58 PM posted to rec.aviation.soaring
Just Me[_2_]
I just want to be clear, I'm NOT scared of flaps. I have 60 hours in a flapped Libelle and probably 10 hours in a Janus A (all flying tail). The question is, given that I anticipate flying 20-40 hrs a year, am I overcomplicating my flying experience by selecting a Ventus (or any flapped ship) to the point that it will be either less enjoyable or that I'll actually get less performance than a comparable standard class ship (Discus) if I'm not on top of them. I'm not scared I'll kill myself. I am scared that I may not enjoy flying as much or not be as confident at being able to get into a "groove" on a thermal.
Part of the problem is there is no doubt in my mind that a Ventus is harder to fly than a Discus or, say an LS8, but some people have suggested its no big deal, others have said, you take your hand off the stick for two seconds and you're in a spiral dive... And all have come from people who actually have flown them. Its hard for me to know what to make of it. One Ventus owner who flew the same Janus A I flew said it was pretty comparable. He also said, always use the winglets.
Old July 19th 17, 08:35 PM posted to rec.aviation.soaring
Matt Herron Jr.
I have several hundred hours in a Ventus C with winglets. It flies very nicely, and likes to go fast. No bad habits, but I find that it is a little twitchy in pitch control, and I have a harder time maintaining constant speed in thermals. Last year I moved the CG back to about 80% aft and I felt like I had a new ship! Much easier to maintain airspeed in circling or straight flight. much less (or no) need to re-trim after changing flaps. I usually land and thermal in +2 rather than "L" flap setting, as it can get a little "wallowy" in "L". On takeoff, flaps are in -1 position, and I move them to +2 to leave the ground rather than use the stick. This also provides a better view of the tug on tow.
YMMV
Matt H.
Old July 20th 17, 12:03 PM posted to rec.aviation.soaring
I switched from a Libelle Club directly to an LS6a and I found it really benign and easy to fly (almost in unballasted condition) and not so flap setting sensitive (if you set neutral and leave it for the rest of the flight you have an LS8!).
Carlo
Old July 19th 17, 06:34 PM posted to rec.aviation.soaring
Bruce Hoult
Ahh .. I know what you mean. My first couple of flights in a Janus I was working so hard on tow that I completely lost situational awareness. How high are we? Where is the airport? No idea.
You don't want that to happen flying solo.
So I'd definitely recommend going back and getting a sign-off in that Janus and putting in 20 or 30 hours in it before attempting a Ventus.
Old July 20th 17, 10:56 AM
Brett Brett is offline
Member
First recorded activity by AviationBanter: May 2006
[quote='Just Me[_2_];951833']I'm considering purchasing a Ventus B. I'm aware of the "stability" issues, although some the extent of the stability issue seems to vary from plane to plane and pilot to pilot. I've talked to some people who say its not a big deal, and others who say its problematic. It's hard for me to know what to expect.
Checkout the Dick Johnson flight tests at http://web.archive.org/web/200502061...es/Johnson.asp (hope the link works)
You will see the Ventus is clearly superior at speeds over 80Kt.
And no - you don't have to be an expert to use flaps - if you can change gears in a manual car at about the right time as any idiot can, you will have no problem using flaps. If you don't want to use flaps you are far better off with a standard class glider with a wing profile optimized as such.
A Ventus B is a great glider but there are far more suitable flapped or unflapped gliders in this price range for you to be considering at your stage of flying.
LS3 flap detent Peter Thomas[_2_] Soaring 0 April 7th 09 10:15 PM
flap speeds? bagmaker Soaring 9 December 24th 06 07:20 PM
Flap design [email protected] Home Built 2 May 15th 05 12:44 AM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 12:09 AM
