glue to rebond rubber tailskid to LS6
Old July 24th 17, 05:57 PM posted to rec.aviation.soaring
kirk.stant
Default glue to rebond rubber tailskid to LS6
The black rubber tailskid (the one with the embedded rollerblade wheel) on my LS6 has come loose - after the last landing when I noticed grass stuck between the boom and the skid, I was able to simply pull off the skid - undamaged as far as I can tell.
Looking for suggestions on what bonding agent (and process, if needed, other than common sense cleaning and roughening) to use to reattach it.
Since it has to be able to break away in a ground loop, I assume there is an optimum (or even required) bonding strength?
I don't remember seeing this covered in my LS6 maintenance manual, but need to check it again; meanwhile, anyone have recent experience rebonding a tail skid?
Suggestions?
Kirk
66
Looking for Wedekind sleeves and tailskid with wheel... [email protected] Soaring 6 January 30th 15 02:42 AM
Keep the rubber side down! Waveguru Soaring 1 September 24th 12 04:57 AM
Gluing rubber pieces [email protected] Home Built 16 June 2nd 09 05:32 AM
Rubber stamp??? Tri-Pacer Owning 13 January 28th 06 07:04 PM
Rubber Stamp ??? Tri-Pacer Home Built 7 January 26th 06 01:34 PM
