FES vs Gas Engine – Finding a Thermal?
Old August 29th 17, 11:34 PM posted to rec.aviation.soaring
Default _FES_vs_Gas_Engine_–_Finding_a_Thermal?
As a facilities, RC electric and automotive guy, beyond depleted batteries or really crappy wiring, the "no run" on electric is likely magnitudes better than any gas.
Regardless of FES or pylon.
The electric motor is a ton less, but current battery tech (no pun intended) makes the gas/electric swap (for similar power) a wash. The batteries take a lot of weight, but it's closer to fuselage centerline so the CG effect is limited.
Cost, well, how is it certified and how open is your aviation authority?
Engineering, like marriage, there is give and take, nothing is perfect. Make the best decision you can, live with any potential downside.
Old August 30th 17, 10:27 AM posted to rec.aviation.soaring
I don't think that there will be much drag from the erected but not turning pylon and prop of the GP 14/15 design. The blades are folded backwards and the pylon looks pretty aerodynamic. I think it is a brilliant concept - with the added benefit of being a self launcher rather than a sustainer. If the GP 15 was more advanced through the certification and a more known design I would be waiting for one now instead of for a Solo engines self launcher.
Old August 25th 17, 07:37 AM posted to rec.aviation.soaring
Default FES vs Gas Engine – Finding a Thermal?
In my Solo 2350 powered 29E, I find it quite possible to recognize a thermal even though everything is vibrating and the vario readout is very nervous.. I try to circle with a constant speed and if the vario constantly is positive and I still have the impression (seat of the pants input) I'm in a thermal after 2 or 3 turns, I shut off the engine.
Of course only if situation (altitude, landout situation) permits.
Old August 25th 17, 08:40 AM posted to rec.aviation.soaring
Tango Whisky
Le vendredi 25 août 2017 08:37:15 UTC+2, a écritÂ*:
In my Solo 2350 powered 29E, I find it quite possible to recognize a thermal even though everything is vibrating and the vario readout is very nervous. I try to circle with a constant speed and if the vario constantly is positive and I still have the impression (seat of the pants input) I'm in a thermal after 2 or 3 turns, I shut off the engine.
With my Ventus cM, I do exactly the same. I judge the quality of the thermal by the reading of the integrator value (and my seat pans); the TE probe sits in the propwash (haven't seen the necessity for a pneumatic switch during the last 10 years...) which makes the realtime vario reading fairly useless.
Old August 25th 17, 03:07 PM posted to rec.aviation.soaring
Dave Walsh
I'm with Dave Nadler on this; it's pretty easy to sense when
the Antares 20E is in a thermal even with the engine running.
Never flown a FES.
With a bit of practice sensing the thermal in the all-vibro-Solo
powered DG808 was possible too. I never bothered though,
just climb 5000+ feet, switch off and set off searching.
Dave N: Be interesting to know what on earth "plummet
mode" is in the Arcus M?
Dave Walsh
Old August 25th 17, 03:29 PM posted to rec.aviation.soaring
Dave Nadler
Plummet-mode is when engine is extended and not running.
Not exciting in Antares or FES, a bit more so with turbos.
Exciting in gas-powered pylon self-launchers (engine/radiator drag).
ArcusM is not too bad - about 500fpm.
Some motorgliders are more like 800fpm which definitely focuses one's attention.
Planning for plummet-mode is especially important for safety during:
- departure route
- powered flight between landable areas
- shut-down activities
These engines have a very high failure rate and its truly exciting to have
a failure on departure - you better have your response planned in advance.
Power-plant retraction is also failure-prone, so advance planning about
when to give up and restart or land is advisable...
Hope that's clear!
Best Regards, Dave
Old August 28th 17, 03:30 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote on 8/25/2017 7:29 AM:
- departure route
Fortunately for Schleicher self-launchers, the "plummet mode" Dave describes does
not exist. Glide ratio for my ASH 26 E is about 20:1 in the pattern with the pylon
up and gear down. It feels like I'm flying Blanik - nothing to worry about, and
the practical effect of landing with the pylon up means I use somewhat less
spoiler than with the mast retracted. Gliders with the "engine on a stick", like
PIK 20E, are strongly affected when the pylon is up.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old August 25th 17, 04:47 PM posted to rec.aviation.soaring
Shaun Murdoch
Default FES_vs_Gas_Engine_–_Finding_a_Thermal?
With the FES, the vario still shows sensible readings but will show
positive proportional to the power you've put in if the motor is
running. So you'll see climb rate going up in thermals (and down in
sink), and you can sort of guess there's a thermal there - reduce
power, see what happens. There's so little penalty to stopping the
motor and re-starting anyway, just whirl a little knob.
Now, if the FES controller and the vario (both LX) talked to each
other and we could have the vario FES-compensated, that'd be
pretty cool..!
You could even imagine a "get me home" mode which tried to
maintain altitude by adjusting power - so you could slow in lift and
extend the range.
At 20:28 24 August 2017, V1 wrote:
While reading the FES article in June Soaring (yes, I=E2=80=99m
behind in
m=
y reading), I noticed the author=E2=80=99s comment about
searching for a
th=
ermal while FES was running, then shutting down FES as he
started to
climb.=
This is a topic I don=E2=80=99t recall seeing discussed in any
FES vs gas
comparisons.
In my Solo-powered Ventus 2cxT, my experience has been that the
vibration
and possibly disturbed airflow) caused so much wild gyration in the
vario
r=
eadings that it seemed pointless to try to determine if I was flying
into
r=
ising air, so I just climbed first, then shut down the engine and
started
a=
thermal search.
My question =E2=80=93 do others have experience to share about
their
abilit=
y to find thermals while a sustainer or self-launcher (either gas or
electr=
ic) was running? If electric has an advantage here, this could
reduce the
r=
un-time needed and conserve =E2=80=9Cfuel=E2=80=9D.=20
- Frank
Old August 25th 17, 07:09 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
extend the range.
Best "get me home" mode is to shut off the motor and climb in the lift. :-)
Steve Leonard
Old August 25th 17, 07:45 PM posted to rec.aviation.soaring
Shaun Murdoch
Default UmU6IEZFU192c19HYXNfRW5naW5lX+KAk19GaW5kaW5nX2FfVG hlcm1hbD8=
extend the range.
lift.
Steve Leonard
Here in the UK, at the end of the day - when you need the FES, nature
isn't always enough... but it helps!
Need help finding someone. Tim Murphy Soaring 0 March 12th 12 04:15 PM
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Finding a partnership Greg Owning 11 November 10th 03 08:40 PM
Help finding photo Chris W Piloting 11 July 29th 03 04:07 PM
