![]() "Miguel Lavalle" wrote in message ... Does anybody know wheter this conecctions are of the L'Hotellier type? Regards Miguel Lavalle N5SZ Which ones? The ones on your Jantar or automatic ones? If you mean automatic ones then things are different to 'traditional' control runs that use 'l'hottelier' connections. In the traditional system a series of pushrods and bellcranks transmit stick movement from stick to surface. In some cases ( ASW20 and Grob elevator ) a pushrod connects directly to the control surface via a hottelier and ball joint mounted a small distance from the hinge line. In the wing control surface connections the in wing pushrods terminated in hotteliers extend into the fuselage and are connected to ball joints mounted on the belcrank arms. In 'Automatic' hook up different arrangments are made to connect things up. For example: on Schempp elevators a 2 pronged fork, permanently connected to the control run using bolted and secured connections, plugs into the elevator surface. My guess is that this is about 99% certain of being done correctly and without fault. ( I fly Schempp ships and I still DI and check before every flight ) Some ships (DG's) have an elevator pushrod that terminates in a 'C' shaped fitting. A roller bearing on the elevator fits snugly into the open 'C', a reliable automatic hookup but does need attention at assembly time. At the wing root you get to play a different game! My Ventus uses two different systems. The flaps are driven by a rotating 'torque' tube. The bit in the fuselage is permanently hooked up and as the wing is fitted a very simple 'dog clutch' connects the flaps to the drive. The Ailerons and brakes are a devilishly clever system. On the wing root rib a bellcrank is fitted, one arm connects to a traditional run inside the wing to the control surface, the other arm, protruding straight out from the root rib, is terminated in a roller bearing. The roller bearing slides into a funnel shaped receiver in the fuselage as the wing is fitted. When the wing is in place the fit between the bearing and the funnel or horn is reduced to zero. The horn is permanently connected to the control system so 'voila' automatic hookups. Could you convert a traditional ship to automatic hookups? I suppose so given enough time and money. Worth it? Not really. Rather spend a quiet 5 minutes before every flight going over your ship properly and making sure everything is in order! Ian |
terminates in a 'C' shaped fitting. A roller bearing on the elevator fits snugly into the open 'C', a reliable automatic hookup but does need attention at assembly time. Wrong there, my friend. The standard Cirrus accident where the elevator disconnected failed because the pushrod did not catch in the "C". Admittingly, it is very difficult to make it happen, but it can and did. Had he done a proper inspection, he would have caught it. This is proven by tests Tom Knauff did on a standard Cirrus. After much effort, he was able to invoke the failure mode. Jim Vincent CFIG N483SZ illspam |
Jim Vincent wrote:
(DG's) have an elevator pushrod that terminates in a 'C' shaped fitting. A roller bearing on the elevator fits snugly into the open 'C', a reliable automatic hookup but does need attention at assembly time. Wrong there, my friend. The standard Cirrus accident where the elevator disconnected failed because the pushrod did not catch in the "C". Admittingly, it is very difficult to make it happen, but it can and did. Had he done a proper inspection, he would have caught it. This is proven by tests Tom Knauff did on a standard Cirrus. After much effort, he was able to invoke the failure mode. After the glider is assembled, and before the pilot does the PCC, doesn't he walk around the glider and inspect the control surfaces and move them through their full deflections, in addition to other inspections? Isn't the improperly assembled elevator noticable during this inspection? When the Std Cirrus elevator is connected improperly in this fashion, isn't the front of the elevator quite high and easily visible to pilot standing near the cockpit while doing the PCC? It's been a long time since I've had my Std Cirrus, but I think a pilot that does a proper inspection has as least 3 chances (including looking in the little window right after assembly) to notice an improperly assembled elevator without the need to be at the control surfaces during the PCC. I'm with Ramy on this one: keep it simple. This one unfortunate case is not a good argument for everyone to have the pilot at the control surfaces during the PCC. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() After the glider is assembled, and before the pilot does the PCC, doesn't he walk around the glider and inspect the control surfaces and move them through their full deflections, in addition to other inspections? Isn't the improperly assembled elevator noticable during this inspection? Apparently not. A Twin DG at out club has a small storyboard attached to the top of the fin leaving no doubt in the riggers mind exactly how , where and when to put things when rigging. I helped with the stab assembly once and when it didn't go together easily. I suggested the pilot read the list on the tail, we removed and refitted the stab discovering in the process that it had gone together wrong first time round! Everything worked OK but the travels were all out of kilter. Ian |
Eric Greenwell wrote in message ...
Jim Vincent wrote: (DG's) have an elevator pushrod that terminates in a 'C' shaped fitting. A roller bearing on the elevator fits snugly into the open 'C', a reliable automatic hookup but does need attention at assembly time. Wrong there, my friend. The standard Cirrus accident where the elevator disconnected failed because the pushrod did not catch in the "C". Admittingly, it is very difficult to make it happen, but it can and did. Had he done a proper inspection, he would have caught it. This is proven by tests Tom Knauff did on a standard Cirrus. After much effort, he was able to invoke the failure mode. After the glider is assembled, and before the pilot does the PCC, doesn't he walk around the glider and inspect the control surfaces and move them through their full deflections, in addition to other inspections? Isn't the improperly assembled elevator noticable during this inspection? Eric, I did misassemble my Std. Cirrus tailplane once. Just once. The person that showed me how to assemble didn't know that it could go together wrong. I guess I didn't either, until I did it. When the Std Cirrus elevator is connected improperly in this fashion, isn't the front of the elevator quite high and easily visible to pilot standing near the cockpit while doing the PCC? Not if the pilot is sitting in the ship!! And the trim is all the way forward to ease assembly, so the tailplane is normally high at this point anyway. It's been a long time since I've had my Std Cirrus, but I think a pilot that does a proper inspection has as least 3 chances (including looking in the little window right after assembly) to notice an improperly assembled elevator without the need to be at the control surfaces during the PCC. The window gets dirty easily and is not very big. It should be cleaned every year (at least) at annual time. Even then, the plastic yellows, and it is dark in there I'm with Ramy on this one: keep it simple. This one unfortunate case is not a good argument for everyone to have the pilot at the control surfaces during the PCC. My misassembly was caught at the PCC stage. I have since changed my assembly procedure to recheck two different ways for tailplane assembly immediately after installing the tailplane. The manual says to look for the hook through the little window. But, the most obvious way is to examine the range of motion of the tailplane for correct, full travel. The PCC catches it also, with some obvious banging. After assembly, I corral someone and teach them how to do a Critical Assembly Check on my ship (and offer to do theirs!). There is actually a Critical Assembly Checklist in the manual. Then of course I tell them all the ways the tailplane will look wrong when not put together correctly. Then we do a PCC. Then I feel like I have a properly assembled ship. There are many ways improper assemblies can be caught, I like to use as many as possible to decrease the odds that any mistakes I make get through. Assembly (me) Check each system after assembled, wing pin & safety pin, spoiler l'Hotelliers and safety pins, ailerons and safety pins, tailplane. (me) Critical Assembly Check (someone else) Positive Control Check (someone else with me) Regards, John Gilbert Std. Cirrus s/n 266 PY Seattle, WA, USA |
![]() "Jim Vincent" wrote in message ... (DG's) have an elevator pushrod that terminates in a 'C' shaped fitting. A roller bearing on the elevator fits snugly into the open 'C', a reliable automatic hookup but does need attention at assembly time. Wrong there, my friend. The standard Cirrus accident where the elevator disconnected failed because the pushrod did not catch in the "C". Admittingly, it is very difficult to make it happen, but it can and did. Had he done a proper inspection, he would have caught it. This is proven by tests Tom Knauff did on a standard Cirrus. After much effort, he was able to invoke the failure mode. Sorry Jim but where was I wrong? It is reliable - provided that the assembler pays attention to what they are doing as I said. If it is assembled correctly it is extremely unlikely to fail unless a pushrod corrodes, a belcrank fails, a mounting delaminates or other completely unrelated failure occurs. I first typed 'fairly reliable connection' in my post but changed it to 'reliable' on reflection with the caveat that it does need attention to detail. BTW I didn't know the Cirrus used this type of hookup. My post was not meant to be an exhaustive description of how automatic hookups work just a fairly reasonable response to Miguels' question. Ian |
Hi,
According to http://www.standardcirrus.org/, Knauff did not find it difficult to get the stabilizer hooked up improperly, nor did the NTSB. I discussed this with the NTSB investigator. Unless one knows what Tom describes in the link, and instructs the assistant, things can happen. There is also a sight glass installed on the top. Unfortunately, I had the experience of watching the accident occur and the aftermath. The individual who did the check was NOT instructed on anything other than to observe movement. I spoke with one experienced glider pilot who had owned a std. cirrus and never heard of the potential problem. The point is, know your manual and any quirks associated with the glider, instruct your helper in the proper PCC procedure and have someone double check your critical assembly. And, I sure hope no one ever takes off having automatic hookups and not performing any of the checks. Trust nothing to chance. NTSB Identification: NYC02FA159. The docket is stored on NTSB microfiche number DMS. 14 CFR Part 91: General Aviation Accident occurred Saturday, August 10, 2002 in Hilltown, PA Probable Cause Approval Date: 12/30/03 Aircraft: Schempp-Hirth Standard Cirrus, registration: N47SS Injuries: 1 Fatal. The glider was being towed by an airplane for takeoff, when it was observed to bounce hard on the runway twice, then it assumed a steep nose up attitude. The tow rope broke, and the glider impacted the ground in a near vertical descent. The C-hook on the stabilator push rod, was found in front of, and not connected to the roller bearing on the stabilator. The pilot's flight experience was over 3,000 hours with about 84 hours in gliders. He had accumulated 28 hours in the accident glider, including 17 flights. This was the first glider the pilot had operated, that he was required to disassemble for storage and reassemble for flight. Witnesses reported the pilot experienced difficulty with the assembly process. A view window was located on top of the stabilator to check for proper engagement of the C-hook, and the AFTER ASSEMBLY checklist called for it to be used to check for proper assembly. A witness reported the pilot moved the control stick in the cockpit and observed movement of the flight controls, but he was not observed to actually check the view window for proper assembly. A check of another glider of the same make and model found it was possible to lock the stabilator in place on top of the vertical stabilizer, with the C-hook in the same place as found on the accident glider. In this configuration, the control rod that held the C-hook was pressed against the roller bearing and held in place by friction. However, the incorrect assembly was visible through the view window on top of the stabilator, and when the stabilator was held in place, it was still possible to move the cockpit control stick abut 1 inch forward or aft, with no corresponding movement on the stabilator. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: The pilot's improper pre-flight, and failure to follow procedures in the flight manual to determine that the stabilator was properly connected prior to flight, and which resulted in a loss of control while under tow, and uncontrolled impact with the ground. Chip F. |
Miguel Lavalle wrote in message ...
Jim, My Jantar Std 3 doesn't have automatic connectors for the ailerons and elevator. Does anybody know wheter this conecctions are of the L'Hotellier type? Regards Miguel Lavalle N5SZ The original Jantar STD had manual hookups but they were not L'Hotellier type. Those connection were pin in one component mating with a hole in the other component and secured by a sleeve that slid over both. The sleeve ensures the fitting is correctly mated and no additional safety is required. (That's based on memory from over 15 years ago). I have no experience with the -2 or -3 but would be surprised if they changed to L'Hotellier which are a ball which mates with a cup. After mating the 2 components, the cup is closed with a plunger driven by a spring loaded wedge. If one of these descriptions matches your glider then you have your answer. Andy |
Spaceship One Presentation at Seattle Museum of Flight | C J Campbell | Home Built | 2 | January 28th 05 05:44 AM |
Signed Charles A. Lindbergh 1953 Presentation Edition | Rare Old Things | Aviation Marketplace | 0 | February 27th 04 05:22 AM |
Spirit Of St. Louis Signed Presentation Edition #25 | Rare Old Things | Aviation Marketplace | 0 | February 23rd 04 04:24 AM |
Newcastle Area (UK): Siberian Aviation presentation | Graeme Carrott | Military Aviation | 0 | September 9th 03 06:29 PM |
Need Powerpoint soaring presentation for Kiwanis group (USA) | Eric Greenwell | Soaring | 8 | August 16th 03 06:58 PM |
