EASA AD on FES battery systems
Old September 12th 17, 12:17 PM posted to rec.aviation.soaring
Graham Smith
Default EASA AD on FES battery systems
from https://members.gliding.co.uk/wp-
content/uploads/sites/3/2017/09/BGA-Newsletter-September-17.pdf
Airworthiness
FES Battery Fires. On 10th August, a FES-equipped sailplane
experienced a severe fire in the forward FES battery after landing
normally at Southdown Gliding Club. The pilot was uninjured and the
fire was extinguished, although the battery compartment and
surrounding structure were damaged by the fire. This event is the
subject of an AAIB Field Investigation and no findings of cause have
yet been established. The AAIB is aware of a second FES battery fire
that occurred on a different FES-equipped sailplane in May 2017, and
is working with the sailplane manufacturer and LZ Design, the
manufacturer of the FES system, to determine the cause of both
battery fires. Whilst the facts have yet to be determined, it is possible
that there could be internal fault within battery cells that could cause
an electrical short between cells and thereby a spontaneous
combustion which battery temperature monitoring will not warn of.
Part of the AAIB work programme involves CT-scanning battery packs
to identify any foreign objects. The potential lack of fire warning is
also being carefully considered.
If you have any questions about operating and maintaining a FES
installation and associated battery, please contact the glider agent in
the first instance.
Old September 21st 17, 07:40 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Airworthiness
the first instance.
This is from the LZ Design webpage news section ( http://www.front-electric-sustainer.com/news.php ) :
"September 2017
On Sept 6th 2017, the European Aviation Safety Agency (EASA) issued Airworthiness Directive (AD) number 2017-0167-E. The AD identifies the occurrence of fires in the FES battery packs produced by LZ Design. It is unknown whether the fires are a result of battery internal issues, the specific installations in the affected aircraft, or external conditions such as mishandling.. LZ Design is collaborating with the EASA and also the AAIB from UK with the intent to issue battery inspection procedures and, if necessary, modification instructions."
Old September 28th 17, 08:45 AM posted to rec.aviation.soaring
Burt Compton - Marfa Gliders, west Texas
Photo of the glider on fire in the UK found he
http://www.wscountytimes.co.uk/news/...ions-1-8170542
Old September 28th 17, 12:10 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
At 07:45 28 September 2017, Burt Compton - Marfa Gliders, west Texas
https://assets.publishing.service.go...017_G-GSGS.pdf
Would be more factual and detailed.
Old September 28th 17, 01:48 PM posted to rec.aviation.soaring
Dave Nadler
On Thursday, September 28, 2017 at 7:15:06 AM UTC-4, Tim Newport-Peace wrote:
Thanks Tim, actual facts are *much* appreciated (and rare on RAS)...
Old September 29th 17, 06:56 AM posted to rec.aviation.soaring
krasw
I do not think facts are rare on RAS, can you elaborate?
Old September 29th 17, 01:15 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
On Friday, September 8, 2017 at 12:14:40 PM UTC-4, JS wrote:
Saw the document on [Aus-Soaring] thanks to John Welsh.
Link to UK site below.
http://publicapps.caa.co.uk/docs/33/...D20170167E.pdf
It's not call rant.aviation.soaring for nothing.
Old September 29th 17, 06:16 PM posted to rec.aviation.soaring
Ramy[_2_]
Comparing to other online news and discussions, I find RAS to be highly reliable source of information with reasonable amount of rant. In fact, I am not aware of any other single source of news and facts which is better, more reliable and more timely than RAS. Usually when someone posts misleading information they get corrected quickly. Using this thread as an example, I wonder if/when/how I would have known about this serious issue without RAS. I wouldn't be surprised if some FES owners learned about this issue first time on RAS.
Ramy
Old September 29th 17, 10:11 PM posted to rec.aviation.soaring
Craig Funston
On Friday, September 29, 2017 at 10:16:13 AM UTC-7, Ramy wrote:
Comparing to other online news and discussions, I find RAS to be highly reliable source of information with reasonable amount of rant. In fact, I am not aware of any other single source of news and facts which is better, more reliable and more timely than RAS. Usually when someone posts misleading information they get corrected quickly. Using this thread as an example, I wonder if/when/how I would have known about this serious issue without RAS.. I wouldn't be surprised if some FES owners learned about this issue first time on RAS.
Ramy
Some of us just have PTSD from the Lennie days & view RAS with a measure of skepticism. You're right though that viewed from the perspective of the current state of the web RAS isn't too bad. Thanks everyone for keeping this a reasonably civil discussion space.
Craig
Old September 30th 17, 01:21 AM posted to rec.aviation.soaring
waremark
Are Schleicher sitting pretty or does the electric ASG32 use similar batteries?
EASA licence and insurance Andrew Ainslie Soaring 16 March 4th 17 12:58 AM
L-13 STC approved by EASA Frank Whiteley Soaring 0 June 14th 11 10:17 PM
EASA Vs FAA glider[_2_] Soaring 5 December 26th 09 02:38 PM
EASA glider imports Sleigh Soaring 0 June 15th 07 11:54 PM
JPI 800 & GMA 340 into C206 in EASA countries? Jouni Laukkanen Owning 3 August 4th 05 07:30 AM
