Yeah, with most flight computers you spend too much time looking at the
screen or turning a knob to reach a menu, etc., while you should spend more time looking outside. Most of the programs available for PDA's require no more than a quick glance to get all the information you need. Regards, Rod |
As far as I am concerned, my PDA is my verification
for the math I am doing in my head. I use Glide Navigator II software linked to my Cambridge Model 20 and GPS-Nav display. The PDA acts like a moving map and will give you pretty close to exact distances to turnpoints, airports and so on. It also tells me if I am with in final glide to a safe landing area. It also comes in handy while in thermals as it shows x's every few seconds which can help you stay in a thermal or other forms of lift. Granted, I have a great deal of respect for the pilots who were competing pre PDA's. The work loads during a contest must have been insane at times..... Also, the PDA is only as good as the equipment and software you are using so do a lot of research. It is also best to download as many of the programs to demo them as possible. I also recommend speaking with other pilots in your group about what they are using and the pro's and con's that they have come across. Best of luck, Brian 17 |
The one I've been using for a few years, CEGlide, can do all but the TAT
optimization--your last question. It may be able to do that w/the upgrade now available, dunno. I've found the final glide STF to be amazingly accurate, even w/out TE input. I'd recommend adding a handheld to your existing set-up for all the reasons you mention. Brent "BJen" wrote in message ... I've got a late '80's model flight computer with an integrated non-GPS final glide calculator and an IGC GPS logger. I'm thinking about upgrade options to minimize the mental workload for these items that I currently have trouble with: What's the current wind speed and direction? What altitude do I need to final glide upwind to airport X and turn back downwind to home at airport Y? What airport is easiest to get to when I'm low given different airport field elevations and current wind direction. When should I turn to get home 3 hours after I started this task? I'm not really sure what options I have. More generally, I'm wondering what the PDA's can do. I presume they have no airspeed/pitot input, no TE input and only GPS altitude. Is that correct? Can they perform vario/TE/STF/final glide functions? I realize they can do GPS moving map, flight track recording. I suspect they can figure wind from a circling algorithm, but without TE or airspeed can they replace my old flight computer? If not, can they supplement it (with my GPS/pressure logger) so I can avoid the expense of a new flight computer? Anyone want to give me some comments here? Thanks. |
![]() What a PDA can do for you depends on how you interact with a computer. Every program you would get will get you the necessary basic information, so the most important part for you is the user interface. You need to make your own decisions based on trying (or at least looking at a program). A good place to start is http://www.soaringpilotsoftware.com look for the GPS_LOG WinCE (it is free) program, download version that runs on a PC and play with it to see what it can do for you (oh and yes..., bring your brain with you ![]() Remember also that PC user interface is always a different from that on a PDA. Henryk Birecki BJen wrote: I've got a late '80's model flight computer with an integrated non-GPS final glide calculator and an IGC GPS logger. I'm thinking about upgrade options to minimize the mental workload for these items that I currently have trouble with: ............ |
It will kill you, if it requires to much attention to operate.
So carefully think about the features you need and then get one that requires no attention during flight and that has an audio output. Best Regards Hans |
I use a PDA (iPaq) and an SN-10 and I like the SN-10 because is has big
knobs and I hate poking at the PDA screen in flight with the stylus. If you go with a PDA, set it up so you only need look at it during cruise, minimize the finger-poking by programming the buttons on the unit. I NEVER have time to mess with any of my instruments or even my radio knobs while thermaling - for some reason I'm always been concentrating solely on climbing in the core - I normally glance occasionally at whatever screen is up, but poke or turn knobs? Not very successful with that unless I'm straight and level (or close to it). The lady I bought my Nimbus 3 from flew did her 1000km using a sectional encased in two pieces of plexiglass with a string over the top tensioned by a rubber band. It apparently worked very well for her - I've had no luck tapping on it with my finger or even my iPaq stylus - damn thing doesn't respond at all ;-) Of course she flys farther in her 1-26 than I do in her old Nimbus... Jim "BJen" wrote in message ... I've got a late '80's model flight computer with an integrated non-GPS final glide calculator and an IGC GPS logger. I'm thinking about upgrade options to minimize the mental workload for these items that I currently have trouble with: What's the current wind speed and direction? What altitude do I need to final glide upwind to airport X and turn back downwind to home at airport Y? What airport is easiest to get to when I'm low given different airport field elevations and current wind direction. When should I turn to get home 3 hours after I started this task? I'm not really sure what options I have. More generally, I'm wondering what the PDA's can do. I presume they have no airspeed/pitot input, no TE input and only GPS altitude. Is that correct? Can they perform vario/TE/STF/final glide functions? I realize they can do GPS moving map, flight track recording. I suspect they can figure wind from a circling algorithm, but without TE or airspeed can they replace my old flight computer? If not, can they supplement it (with my GPS/pressure logger) so I can avoid the expense of a new flight computer? Anyone want to give me some comments here? Thanks. |
