#11
thanks guys, I ordered a new replacment internal battery, just because if I open it up to fix that I might as well put a new one in
On Saturday, September 30, 2017 at 11:31:12 AM UTC+10, wrote:
thanks guys, I ordered a new replacment internal battery, just because if I open it up to fix that I might as well put a new one in ![]() Service Info No. 20/97 Adjusting Squelch Sensitivity of Dittel Radios in DG motorgliders (if necessary) https://www.dg-flugzeugbau.de/wp-con.../1997-20-e.pdf |
Issue has not reappeared. currently when I turn it on it breaks squelch then goes silent. previsouly it didnt go silent for 10-15 min. I used the same procedure of turning on sn10, 302, powerflarm and then radio. So time will tell thanks for all the advice Ill keep you all informed if it returns.
CH ASW 27 |
Did anyone keep a copy of this service bulletin - DG has changed their website and the link below is no longer valid.
email to me please if you have it dave"at"foxonecorp"dot"com Thank you! Walter Dittel had a service bulletin, N0. 20/97 regardting the auto squelch. There is a copy of the bulletin on DG Flugzeugbau that shows the location of the said potentiometer. http://www.dg-flugzeugbau.de/Data/TN.../1997-20-e.pdf MN |
FS Dittle radio base station | Bob Epp | Soaring | 0 | October 9th 08 11:06 PM |
F/S Dittle FSG 60M | JJ Sinclair | Soaring | 0 | January 6th 07 02:33 PM |
Memory battery for Dittle FSG71M | Ray Gimmey | Soaring | 14 | December 29th 06 12:13 PM |
dittle fgs-50 display | Kevin Brooker | Soaring | 0 | May 5th 05 06:53 PM |
Dittle FSG50-wiring | [email protected] | Soaring | 2 | December 27th 04 08:33 PM |
