Is there a nose hook modification for a standard cirrus
Old October 5th 17, 10:13 AM posted to rec.aviation.soaring
Bruce Hoult
Default Is there a nose hook modification for a standard cirrus
On Thursday, October 5, 2017 at 11:37:45 AM UTC+3, krasw wrote:
On Thursday, 5 October 2017 06:08:14 UTC+3, wrote:
The CG hook "problem" on aero tow is an airport myth. Nose hooks are a hardware solution to a software problem. Spend your money elsewhere - like a pneumatic tailwheel or spoiler mod.
Agreed, nose vs. cg hook is non-issue and gets way more attention than it really deserves. Most pilot woudn't notice any difference. Tail skid on the other hand is something that should have been left in 1910's and biplanes.. Just horrible thing to have in anything, royal pain in the ass everytime it touches ground.
Certainly in normal circumstances it isn't a problem.
In rotor with slack line I've pitch up when the rope suddenly becomes tight has been noticeable in a Janus, but easily dealt with.
Someone asked a while ago whether there was any history of towplane upsets with nose hook gliders. I don't recall that it was ever answered. You'd think that if it happens someone would be able to quickly point to an example or two.
Old October 5th 17, 02:27 PM posted to rec.aviation.soaring
BobW
biplanes. Just horrible thing to have in anything, royal pain in the ass
example or two.
Dunno if it was "kiting" in the sense of "torquing about the glider's CG" or
not, but I recall reading about a tow pilot fatality after a K-8 drove it into
the ground; happened in the 1960s in Utah. The article was given me as part of
a Safety Corner collection by my club's chief instructor for a
reading/feedback assignment during my primary instructional days. My takeaway
was: Kids, don't DO this!
I'd bet other instances in the U.S. - where nose hooks predominated for much
of soaring - can be found...
Bob W.
This email has been checked for viruses by AVG.
http://www.avg.com
Old October 5th 17, 04:44 PM posted to rec.aviation.soaring
Dan Marotta
Please describe the "spoiler mod".Â* Sounds interesting.
On 10/4/2017 7:13 PM, Scott Williams wrote:
On Wednesday, October 4, 2017 at 4:27:58 PM UTC-5, wrote:
I bought a standard cirrus. I havent flown it yet, but I was wondering if it's possible to put a nose hook on the plane?
Last year I spoke to Heinze of M&H the U.S. Schempp-Hirth Dealer, he thought kit, less Tost release would run $1500, Tost release maybe $500. Installation labor??
Heinze thought it would not be cost effective.
I bought the spoiler mod instead. My glider already had the hatch and wedekind sleeves.
Spoiler mod was worth twice what I paid IMO.
Good Lift,
Scott.
Dan, 5J
Old October 5th 17, 05:27 PM posted to rec.aviation.soaring
Tony[_5_]
There is a tech note to add a second panel to the Std. Cirrus airbrake. Makes them much more effective. I did the mod almost as soon as we bought Kate.
Old October 5th 17, 07:35 PM posted to rec.aviation.soaring
Dan Marotta
Makes sense, thanks!
Dan, 5J
Old October 6th 17, 01:30 AM posted to rec.aviation.soaring
son_of_flubber
Is there an advantage to using a nose hook when aerotowing through rotor? A year or so ago, I ran the wing for a very_accomplished_glider_pilot in an LS-4 w/c.g.hook who the tow pilot said, went vertical UPish in rotor. The towplane went vertical DOWNish and broke the rope. Both came back to the airport.
Is a C.G. hook better in rotor?
Old October 5th 17, 06:22 PM posted to rec.aviation.soaring
Bruce Hoult
Good Lift,
Scott.
I thought it was in the early or mid 90s that absolutely every Cirrus at our club (six or seven of them I think) had a 2nd panel added to the airbrakes, all done in a batch over a couple of days.
Old October 8th 17, 08:53 AM posted to rec.aviation.soaring
Aaron Thomson
Hi,
I have a Nimbus 2B that is certified with a nose hook installation. I can look through my records for the 337 if you would like.
Aaron Thomson
N71TT Nimbus 2B
nose section from salvaged standard cirrus. Scott Williams Soaring 1 May 27th 17 04:58 PM
Jantar standard SZD-41A C.G. hook Žiga Munda Soaring 3 November 24th 15 02:00 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Hook up an mini headset to a Vertex Standard VX150 or 210 radio Peter Soaring 2 July 3rd 06 04:49 PM
Nose hook addition Jack Soaring 2 April 29th 06 08:08 AM
