air extractor for asw19 and asw20
Old October 18th 17, 12:33 AM posted to rec.aviation.soaring
Default air extractor for asw19 and asw20
I didn’t cut the holes, but mine has a fold down wood bulkhead with a pretty gap (about 1/2 inch) around the perimeter. That gap was large enough that I though I’d give it a try before cutting the holes. I was happy with the result, so I’ll probaby not cut the holes. The fiberglass bulkhead has a tighter fit, so you may ne d the holes.
John
Old October 18th 17, 03:17 AM posted to rec.aviation.soaring
sisu1a
On Monday, October 16, 2017 at 8:03:30 PM UTC-7, JS wrote:
On Monday, October 16, 2017 at 6:47:55 PM UTC-7, wrote:
I just installed a very cool - pun intended - air extractor in my ASW19.. Its a nifty device that replaces that little hatch cover where the control connections are. My guess is that it was made on a 3D printer. Anyway, I couldn’t believe how well it worked and so I’m putting a shameless plug for that thing here. I got it from an outfit in the UK called LJ Panels. I don’t often get carried away raving things, but this one is the cats meow.
Is it anything like the ones that Paul Hanson sold years ago?
They are similar, but they adopted the dual 'louver' type outlet the Jonkers team came up with. No form on treatment on the interior. Te parts are laser sintered nylon so finish is quite rough (something between sandstone and wood) until primed/sanded, though some Polyprimer and sanding would make them really nice.
My guess is they work at least as well if not better due to having higher surface area with the double outlet even with the forward louver is partly blocked by the attach point, though likely to make a bit more noise with the air hitting the outlet without any organization taking place on the inside..
Wish I would have made my test pod to quantify this stuff, but never did though I do still make/sell the hatches I have been in fiberglass, prefinished with PCL 907 white to a #320 grit
Old October 20th 17, 01:13 PM posted to rec.aviation.soaring
Dan Mockler
wrot=
e:
ASW19=
contr=
Anywa=
y, I couldn=E2=80=99t believe how well it worked and so I=E2=80=99m
putting=
UK
called LJ Panels. I don=E2=80=99t often get carried away raving things,
b=
=20
Jonker=
las=
and=
make
t=
hem really nice.
s=
b=
the=
inside=
..=20
th=
prefinishe=
After installing a Nixon special in my 20, I heard a burbling sound coming
from
the vent.
I reduced the size of the extractor opening using mylar.
Each flight I would trim another 1/8 inch until the airflow, in the
cockpit,
returned to original levels. Very nice setup.....
I now hear air leaking around the flap while in negative settings.
What sounds are heard due to this design?
Old October 20th 17, 03:21 PM posted to rec.aviation.soaring
On Tuesday, October 17, 2017 at 1:12:58 PM UTC-4, Paul Agnew wrote:
The purpose of the extraction vent is to increase the available airflow to the cockpit. The ASW-19 has NACA vents under the wing roots to draw air in, but there is no clear path for it to exit. The extraction vent, and modification of the bulkhead to allow airflow, gives the air someplace to go and reportedly greatly increases the comfort level in the cockpit. Noise reduction is primarily due to being able to keep the canopy vent closed and a reduction of "pressurized" air leaking under the canopy seals.
Any performance benefits are a bonus in my book and not a serious consideration unless you are a hard-core performance tweaker looking for every .1% gain.
Paul A.
Some experience on this topic(about 80 sold for 9 types)leads me to comment..
1) Extractors can and do help ventilation(and removal of exhaled moisture). They are a big improvement in 19's and 20's, maybe a bit less so in ships with better ventilation to start with.
2)Sealing the cockpit area off from the aft fuselage has a meaningful effect on this extraction by increasing the pressure differential between the cockpit and ambient. Without sealing, the pressure reduction is limited by air coming from the rudder horn and hinge area that is low pressure, but not as low as the vent.
3) Canopies leak. It is better to have the leak be into the cockpit and not out over the wing root area. Commonly one of the noises heard is air being sucked in around the edges of the little vent window.
4) The extractor shown may well infringe on the patent applied for by JS or their resources.
FWIW- Hard core performance guy.
UH
Old October 20th 17, 04:17 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Not having seen the JS patent application, but cockpit air extractors have been in the public domain for a while now. Unless JS has something unique (perhaps the little airfoil in the middle), and unless they filed their patent before selling the first JS1 with an air extractor, JS is not likely to be granted a patent for the air extractor on the JS1c. The JS-3 extracts air out the underside of the fuselage. The JS-3 air extractor is new and I suspect that is what their patent is for.
Paul A.
Old October 20th 17, 04:34 PM posted to rec.aviation.soaring
Papa3[_2_]
IIRC (and I could be wrong) didn't the Mandl Extractor with DG predate Jonkers? At one point the Mandl was advertised as "patent pending" as well....
Old October 20th 17, 06:33 PM posted to rec.aviation.soaring
JS mention of patent application as mentioned on their web site was for the incorporation of airfoil shaped additional element in the outlet area.
UH
Old October 20th 17, 08:28 PM posted to rec.aviation.soaring
krasw
Haha, you are taking about factory that "borrowed" ASH26 fuselage and added Ventus-2 wing geometry to create JS1.
Old October 20th 17, 10:59 PM posted to rec.aviation.soaring
You mean the JS1 wing that differs in aerofoil, plan form, dihedral, winglet and structure from the Ventus 2 - that in fact shares no design features with it at all.
Old October 21st 17, 03:17 AM posted to rec.aviation.soaring
Michael Opitz
UH
I am buying one for my old ASW-19 which my brother now owns.
In emailing Alan, I mentioned the RAS patent infringement
musings.
Here is his response to that issue:
No patent infringement. My product was developed long before
Jonkers tried to patent their version and also uses different airfoil
sections, materials, technologies.
FWIW,
RO
ASW19 for sale [email protected] Soaring 2 September 12th 16 10:07 PM
ASW19 Inner Tube [email protected] Soaring 1 September 21st 15 03:54 PM
Air extractor for sustainer and motor gliders? [email protected] Soaring 12 August 26th 15 07:41 AM
Air Extractor: Better than a Plastic Jesus? [email protected] Soaring 23 December 18th 13 08:48 AM
asw19 airbrake kit steve[_2_] Soaring 2 April 7th 11 08:32 PM
