iPhone X and iGlide - the verdict is in.
Old November 29th 17, 08:14 PM posted to rec.aviation.soaring
waremark
Default iPhone X and iGlide - the verdict is in.
As owner of an Oudie IGC (also Samsung S8, Kobo Glo HD, and LX 9000) I think brightness has ceased to be a major issue. I have never encountered any conditions in which the Oudie (pointed at me) is difficult to read. What is the relevance of looking at the instrument at an angle?
Old November 29th 17, 10:21 PM posted to rec.aviation.soaring
jfitch
The posting was meant to inform those using a cell phone, where brightness has historically been an issue, as battery life has prevented manufacturers from using bright displays. There have been a few threads questioning the usability of iGlide due to this. At least with the X, it is no longer an issue. With a 6 Plus, I only had an issue looking into the sun wearing dark glasses, as I also did with the Avier/Oudie. This seems like less of a problem with the X, which is brighter, higher contrast, and higher resolution than either.
No relevance looking at an angle - just an observation that LCD and OLED displays have different artifacts (dimming and blue shift respectively), and it appears that the LCD suffers more. Of greater relevance is the reflections, and it appears that the anti-reflective coatings on a high end cell phone work better than the matte screen of an inexpensive PDA.
Old November 30th 17, 12:50 PM posted to rec.aviation.soaring
krasw
torstai 30. marraskuuta 2017 0.21.42 UTC+2 jfitch kirjoitti:
Thanks for the pictures, Iphone X looks good. I would actually like bigger screen than current Oudie has, so Iphone X in Plus-size would be perfect.
Old November 30th 17, 10:17 PM posted to rec.aviation.soaring
If you really want to go big, try iPad mini 4. It works well with iGlide. Easy to read, and has more info boxes than on IPhone.
Old November 30th 17, 11:57 PM posted to rec.aviation.soaring
Jonathan St. Cloud
How specifically are you mounting the iPad Mini in your glider?
Old December 1st 17, 04:27 AM posted to rec.aviation.soaring
SoaringXCellence
The iPad Mini is roughly the same size as the Nexus 7 I used in my glider. Get a Ram system (one inch ball) and screw a diamond ball to a hard shell case for the Mini. Should be too tough. The hard part may be the connection between the vario and the iPad.
Old December 1st 17, 06:30 AM posted to rec.aviation.soaring
krasw
perjantai 1. joulukuuta 2017 0.17.44 UTC+2 kirjoitti:
I would but iPads do not have same display as X. Pure gliding use X is total overkill, with iGlide licence package is close to 1500 euros.
Old December 1st 17, 05:09 PM posted to rec.aviation.soaring
jfitch
1500 euros makes it about 25-50% cheaper than a dedicated glider display......
For example the Air Display L is 3200 euro. And you can't make phone calls on it. Alternatively an LX9000 is US$5500 (about 4600 euro), quite a bit more than an Air Vario and an iPhone X with iGlide (around US$4300). And you still can't make phone calls on it.
You just can't compete with the economics of mass produced consumer electronics. Apple is currently making 500,000 iPhone Xs per DAY. They expect to sell over 50 million phones this quarter. LX probably will sell 100 in a year.
iPhone X and iGlide - the verdict is in. Andy Blackburn[_3_] Soaring 3 November 26th 17 02:29 AM
alternative to iGlide for iPhone (6 plus) Bob Pasker Soaring 50 September 21st 17 07:17 PM
LXNAV S80 compatible with iPhone running IGlide? [email protected] Soaring 2 October 11th 16 03:12 AM
iPhone 6 Plus and iGlide jfitch Soaring 39 May 20th 15 01:07 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
