why isn't there composite tube fuselage design?
Old February 16th 05, 03:02 AM
BobR
Shin Gou wrote:
I am just wondering...if composite materials are stronger and lighter
than steel, why composites tubes aren't glued together to form the
fuselage frame just like the traditional 4103 steel tubes being
welded
together? Any reasons?
Shin Gou
Rans S-9
Warrenton, VA
The better question would be why would you want to use carbon fiber to
build a tubular type framework? The real secret is to utilize the best
strengths of your material and design to that strength. There is no
technical limitation that would prevent using carbon fiber composite
tubes to create a tubular framework. The only limitation I can think
of is the joints for replacing the welded joints of the steel. That
could easily be solved by custom bondable carbon fiber joints. Clamps
could substitute for welded tabs and so on. One thing for certain, you
would never have to be concerned with rust.
One thing though, due to the very limited amount of composite vs steel
involved, you would not be saving a lot on weight.
Old February 16th 05, 10:08 AM
Bonding titanium to carbon tubes does not sound like a homebuilable
technique to me.
You are right the joints will always be the problem. However it is
interesting to study the way in which items such as bicycle frames and yacht
steering wheels are made in one piece from tubular sections in carbon ... I
won't say any more on this. You can find plenty of info on the web.
There are fouth major problems/issues that I can see.
First .... if you layup a tube from carbon you cannot put all of the fibres
along the tube axis. Some will need to wrap around. As carbon fibre is
highly orthotropic (i.e. different material properties in different
directions) then the impressive properties of the carbon fibre along the
fiber axis will not be attained in the completed tube. Don't get me wrong
the carbon will still be lighter and stiffer for a given weight but probably
not by as much as you would expect.
Second ... the properties of carbon composites are strongly dependant on
moisture and temperature conditions. For example the compressive strength of
Fibercotes E-765/T700 24K uni prepreg is 147 ksi at room temperature / dry
conditions. At elevated temperature and equilibrium humidity conditions in a
tropical environment the compressive strength drops to 88 ksi ! Not really
any better than steel. Compressive moduli and any other resin dominated
properties (such as shear) will exhibit similar behavior. Yout need to
design for these low strengths at the extreme environmental conditions in
any composite structure and thus at room temperature you will end up with
larger than required margins and hence more weight.
Third .. composites suffer from microcracking and other issues which will
limit the laminate strains to approx 4500 micro strain at ultimate load (a
rough number ... complicated issue not room to explain here). What this
means in plain english is that you can only use approximately 1/3 of the
potential strength of the material if you want a structure with long life.
Fourth ... composites have no ductility like metals and I would hate to be
sitting in a fuselage made of carbon tubes if it hit anything. The tubes
would fracture and splinter and the pilot would be in all sorts of trouble.
To control this behaviour you would need to add another tougher composite
material such as Kevlar to the laminate (common practise in fwd fuselages
for gliders to improve crashworthiness).
"BobR" wrote in message
welded
Shin Gou
Rans S-9
Warrenton, VA
Old February 16th 05, 07:05 PM
LCT Paintball wrote:
Round is very strong. The only way you could improve on a simple
round tube
for strength would be to add material in the direction that you
needed more
strength, and take away material where the strength wasn't needed.
Yep they're called box beams, or torsion beams for those
who like an extra sylable. Hollow beams are a very weight-
efficient approach to construction. In monocoque design
the entire fuselage and/or wing is designed as a box
beam.
FF
Old February 17th 05, 03:28 AM
BobR
technique to me.
The joints would not need to be titanium but could be made from carbon
fiber as well. Bonding of carbon fiber to carbon fiber would present
few problems. The majority of tubular frames I have seen are designed
so that the stress on the frame remains in compression.
and yacht
.... I
That would be the obvious method if you are constructing the frame from
raw materials instead of existing carbon fiber tubes.
fibres
is
wrong
probably
The solution to this was on display at Oshkosh about three years ago.
Ever see the Chineese finger lock? They were using the save weave
technique to form the carbon fiber tube, wetting out after forming to
desired size and curing. The result was the optimum strength in all
directions.
on
strength of
/ dry
conditions in a
really
dominated
to
conditions in
with
Those properties can be programmed to just about any desired result.
The accepted standard for most composite design is 2X vs 1.5X for steel
equilivent design. The issue will always be a design problem, and the
best would be to design to the best properties of the materials being
used.
will
load (a
this
life.
A property not unique to composites.
to be
tubes
trouble.
composite
fuselages
Composites have proven to be very crash worthy in practice but I agree,
that the carbon fiber tube frame would not provide the same protection
of a tube steel frame. It goes back to designing to the qualities and
strength of the material.
composite design [email protected] Home Built 16 February 11th 05 04:25 PM
Who can identify this tube frame aircraft fuselage? Rob de Bie Home Built 5 January 13th 05 09:45 PM
amateur design consultant? Shin Gou Home Built 14 June 30th 04 01:34 AM
F-32 vs F-35 The Raven Military Aviation 60 January 17th 04 08:36 PM
Defining Composites (long) B Lacovara Soaring 1 September 13th 03 08:04 PM
