"Paul Remde" wrote:
...the software calculates wind speed and direction while thermalling. Hi Paul, Is GNII able to provide wind and/or ground speed info enroute? Is any nav software able to do either? Ray |
Romeo Delta wrote:
"Paul Remde" wrote: ...the software calculates wind speed and direction while thermalling. Hi Paul, Is GNII able to provide wind and/or ground speed info enroute? As a user of GNII and a 302: if the GNII is connected to the 302, then yes; if it's connected to "just a GPS" (like my Cambridge model 20), then no. Is any nav software able to do either? The nav software also needs the airspeed information, or heading information (compass). Just a GPS input isn't enough to update wind info while cruising. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
I do not have any of these instruments but for my ASW20 I am putting a B50
in it due to reliability issues with cambridge gear,at our field some praise some curse cambridge 50\50, I prefer 100% reliability and Borgelt gear seems to fit this ideal gary "Romeo Delta" wrote in message om... I am soliciting opinions on which is the best way to go: 1. Cambridge Aero 302 -or- 2. Borgelt B50 system combined with a data logger: a. CAI 302A b. Colibri c. Volkslogger I would appreciate comments with consideration to ease of installation, ease of use, performance (to include comments about timing and accuracy of indication vs. actual conditions as well as one's liking of the respective vario's audio tones), compatability, reliability, factory support, etc.--especially from anyone who has experience flying with both systems. Add'l info: I intend to couple either system with a PDA using GlideNav II. Also, I live in the U.S. Thanks in advance, RD |
I have a B50 and it is probably the best averager I
have ever flown with. It is reliable, acurate and very easy to use. I have it linked to a PDA and a Volklogger and the system as a whole is great. (It may also be worth stating that I completely re-worked the tubing when I bought the glider (there wasnt a problem Ian but we re-did the whole panel!)). My only problem is the 'push' noise. I hate the noise but to be fair it leaves you in no doubt that you are at the wrong speed! I have three mates who all run 302's in their glider. Two have gone back to the dealer for repairs (one of those has been back more than once) and the third person is having problems. I dont want to slag off CAI instruments because in general I think they are good but the 302 seems to have some issues. Owain At 09:36 26 May 2004, Goneill wrote: I do not have any of these instruments but for my ASW20 I am putting a B50 in it due to reliability issues with cambridge gear,at our field some praise some curse cambridge 50\50, I prefer 100% reliability and Borgelt gear seems to fit this ideal gary 'Romeo Delta' wrote in message . com... I am soliciting opinions on which is the best way to go: 1. Cambridge Aero 302 -or- 2. Borgelt B50 system combined with a data logger: a. CAI 302A b. Colibri c. Volkslogger I would appreciate comments with consideration to ease of installation, ease of use, performance (to include comments about timing and accuracy of indication vs. actual conditions as well as one's liking of the respective vario's audio tones), compatability, reliability, factory support, etc.--especially from anyone who has experience flying with both systems. Add'l info: I intend to couple either system with a PDA using GlideNav II. Also, I live in the U.S. Thanks in advance, RD |
Owain Walters wrote:
...My only problem is the 'push' noise. I hate the noise but to be fair it leaves you in no doubt that you are at the wrong speed! Dear Owain, Can one program the B50 to emit audio only when in lift? Is there a choice of tones available? RD |
Sorry to say - but I've had bad luck with my 302 which was plagued from =
the beginning with the "bad seal" problem. This has been compounded by = a bit of "musical chairs" as to who owns the company and warranty = responsibility. Also the "fully integrated" concept is a 2 edged sword. It fits in a = neat little hole in the panel for sure - but when it's broken in flight = (or needs to go for repair) you are without anything - no vario, no = averager, no logger, no gps souce. In short :"zip" The only thing I really trust is my winter mechanical! Good luck Roy. |
RD,
I would be delighted to find I am wrong but the 302A we are using gives no indication of outputting a wind calculation in its interaction with a variety of PDA programmes that my partner has tried with it (althout SeeYou Mobile seems to calculate its own circling drift wind when attached to the 302A). Also he has corresponded with Paul Remde (US agent for Cambridge and GN11 as you will know) about this subject and I am sure he would have been able to tell us if this was wrong. I had a look at the 302A manual and it doesn't say it calculates winds - but the 302 manual also has no mention of wind calculation which it does do. The 302 variometer calculates vector winds and not circling drift wind. Take away the pneumatic inputs and it has no way of doing this - even if the computer hardware that allows the 302 to do this isn't removed in the process of turning it into a 302A - which I suspect it will be. John Galloway At 21:54 26 May 2004, Romeo Delta wrote: John Galloway wrote: ...the 302A cannot calculate winds and GN11 also does not do a wind calculation when attached to a 302A. Dear John, I appreciate your considered response and don't mean to cast dispersion; however, Are you 100% positive that the 302A cannot calculate winds? This seems odd for any GPS not to be able to do so. Can anyone verify this? RD |
RD: If you choose to go with the B50 (a very good instrument), I can
offer a B50 plus Volkslogger system at 75% of current price. This system was removed from my glider which was sold sans instruments. Both units are in perfect operation. The Volkslogger is the new connector type. Email me direct. I can send photos if needed. Manuals are provided. Steve Koerner Mesa AZ |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Cambridge Aero Explorer Fix | Guy Byars | Soaring | 8 | May 19th 04 03:04 AM |
Colibri Data Logger reviewed | TOM RENT | Soaring | 18 | April 16th 04 10:47 PM |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
