Looping a standard cirrus
Old January 16th 18, 02:26 PM posted to rec.aviation.soaring
Nick Kennedy
Default Looping a standard cirrus
Oh come on, If Bruno can do it... Finish your Aero training and go for it, whats the worst that can go wrong? Wings or elevator comes off? Tailslide? Thats what your parachute is for BTW, practice getting out in all conditions and go for it, the glider IS certificated for the maneuver, what could got wrong? Pilots do loops all the time.
Old January 16th 18, 03:17 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Monday, January 15, 2018 at 10:32:06 PM UTC-6, Richard Pfiffner wrote:
On Monday, January 15, 2018 at 6:17:32 PM UTC-8, wrote:
I do not believe the Standard Cirrus can be looped safely. Don't try it, or the world will spontaneously combust and all life will end.
Flight manual predicts the end of life as we know it maybe!
http://www.standardcirrus.org/flight...vicemanual.pdf
Richard
I like the statement: "The sailplane enters into a spin from a sharp stall applying full rudder. The control stick should be pulled during the spin."
So, are you to remove the control stick if you enter a spin? :-)
Steve Leonard
Old January 16th 18, 03:49 PM posted to rec.aviation.soaring
Scott Williams
Richard
Steve Leonard
Hey Steve,
I think I get (and appreciate) your joke,
but For my own safety, "pulling the stick" is to intentionally induce and maintain a spin, Correct?
Old January 16th 18, 05:01 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Tuesday, January 16, 2018 at 9:49:52 AM UTC-6, Scott Williams wrote:
Hey Steve,
I think something is lost in translation, but I believe the manual is saying you need to keep the stick back to keep the plane in the spin. Relaxing back pressure may lead to a spiral. It says recovery is done by easing the stick forward, and applying "slight opposite rudder". Both implying not full motion of a control. Not having any Std Cirrus experience myself, I would defer to someone who does have this experience.
Steve Leonard
Old January 16th 18, 05:48 PM posted to rec.aviation.soaring
I believe the joke is, "pulling the stick" as in.......removing it.......
Yes, most aircraft, pulling the stick either deepens the spin, or, (sorta worse) makes it a spiral.
Big difference between a spin and a spiral is that a spin will usually stabilize until you escape it, recover or hit terrain. A spiral may mean you "remove the wings" as you either exceed VNE or G loads, possibly BEFORE you hit terrain.
I believe I get the joke.
Old January 16th 18, 05:50 PM posted to rec.aviation.soaring
Hopefully it is dual controls so someone else can recover, you have a chute, you have enough altitude so the aircraft saves your butt........
Old January 16th 18, 07:37 PM posted to rec.aviation.soaring
I have looped an early, all-flying stab Cirrus, Mini Nimbus, and Janus A. Seriously locked down my control hand/arm on my leg as the elevator stick pressure in all of them is pretty neutral and it would be pretty easy to pull too hard.
Old January 17th 18, 05:29 PM posted to rec.aviation.soaring
Am Dienstag, 16. Januar 2018 01:57:46 UTC+1 schrieb :
Who has done a loop in a standard cirrus? Any comments or hints. Currently getting some acro training with the goal of looping my cirrus.
Hi,
I would recommend good training before trying to loop the cirrus, as the cited entry speed of 97 knots is quite near to VNE of 119 kt. Very easy to get out of it with a lot of speed.
Don't do it without a G-meter installed.
Regards
Stefan
Old January 18th 18, 02:23 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
Default Looping a Standard Cirrus
Looping the Std Cirrus is very straightforward, and no different to looping
any other glass glider.
If you're competent to loop *any* glider the Cirrus should be no problem
(If you can't maintain speed within 20% of your target (97kts vs 118) then
you should probablyy give it a miss)
KN
Old January 19th 18, 01:52 PM posted to rec.aviation.soaring
Andrew Ainslie
I never understand why people loop gliders designed for competition. Grab a club 21 or Grob or something less slippery with a bigger spar and have fun with that. Or even better, pay to go up in a Decathlon with an instructor and actually learn something in the process.
All that looping a slippery glider gets you is an awful butt-clenching sense of "Oh **** Oh **** Oh **** Oh **** Oh ****" as your eyes jump between the bending wings and the clockwise acceleration of the ASI.
Looping a competition glider makes as much sense as turning the engine off on a Pawnee and trying to soar it. In both cases, you're using the wrong tool for the job.
Standard Cirrus Walt Connelly Soaring 10 December 31st 11 04:03 PM
Standard Cirrus Walt Connelly Soaring 23 March 20th 11 03:14 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Standard Cirrus Don Burns Soaring 0 January 10th 07 05:24 AM
F/S - Standard Cirrus 75 Bob Soaring 0 October 4th 04 12:23 AM
