Gageteers, we need a digital heading sensor
Old June 17th 04, 06:36 AM
f.blair
Why can't the GPS create the 'heading data' my $90 Etrex gives a heading
reading.
"Bill Daniels" wrote in message
news:_y8Ac.53766$0y.15362@attbi_s03...
Dave, can it give highly accurate, real-time wind data, second by second
on
a straight one hour glide?
My last flight showed this problem during a long glide. For 30 miles the
wind data showed SW winds at 20 knots but then I noticed the glider
drifting
to the west. Two 360 turns and the computer showed wind at 090 at 10
knots.
When I crossed the wind shift line I had a chance to change strategy. 30
miles later when the wind error became obvious it was too late.
More and more I think we need very accurate real-time wind data with no
requirement to be constantly changing heading. A cheap, reliable heading
sensor would make this possible.
Bill Daniels
"Dave Nadler YO" wrote in message
m...
Bill - The heading is not required. In the ILEC SN10 we do this
without heading, and it normally has the wind by the time you're
off tow. Pilot feedback and measurements indicate that we do
it quite accurately. We just use TAS and GPS ground track over
multiple observations (TAS requiring accurate IAS, press, temp).
Best Regards, Dave "YO"
news:gw%zc.59643$HG.25574@attbi_s53...
I've been analyzing the IGC files from my flights and comparing them
to
others.
Generally, in good conditions, I'm circling less than 25% of the time.
Other, far better pilots than I, are circling less than 15% of the
time.
This means that wind data that depends on the glider flying circles
gets
way
out of date during the long glides. OK, "S" turns can give the
computer
a
chance to compute wind if you remember to fly them but there are still
a
lot
of long, straight glides.
To compute real-time wind data we need Groundspeed, Ground Track (any
GPS
gives these)True Airspeed (Some computers do this if they have OAT,
Pressure
Altitude and IAS) and accurate heading data. Heading data it the
tough
nut
to crack.
So, how do we get Heading? One way might be to put a GPS antenna in
each
wing and look at the carrier phase difference. If the computer saw a
constant track, it could assume the wings are level and determine a
heading
value. This heading value might update an aerospace quality MEMS
heading
gyro that would maintain a flow of heading data to the glide computer
during
times when the wings were banked.
With good heading data we could get uninterrupted high quality wind
data
regardless of the gliders' maneuvering or lack of it.
OK, RAS gageteers, how about it?
Bill Daniels
Old June 17th 04, 07:20 AM
David Starer
The GPS gives TRACK, not HEADING. It can't tell what direction the glider is
pointing in, only the direction its motion is taking it across the ground.
David Starer
"f.blair" wrote in message
news:E5aAc.44219$2i5.30680@attbi_s52...
reading.
on
drifting
knots.
30
heading
Bill Daniels
m...
to
others.
time.
time.
gets
way
computer
a
still
a
lot
(any
GPS
Pressure
tough
nut
to crack.
each
a
heading
heading
computer
during
data
Bill Daniels
Old June 17th 04, 07:51 AM
Mark Navarre
Subject: Gageteers, we need a digital heading sensor
wind data showed SW winds at 20 knots but then I noticed the glider drifting
to the west. Two 360 turns and the computer showed wind at 090 at 10 knots.
I very strongly agree, because I too am "cursed" with long glides between
thermals when flying long cross country flights. Air masses may change
dramatically in 10's of miles, but you won't know if you don't stop for a few
turns, also late in the day shear lines come through and cannot be easily
spotted on blue days without real-time wind info. This info WILL make the
difference between getting there faster or slower (or getting there at all!).
If you don't understand this, then you either haven't flown 50-60+ mile glides,
or are just not observant enough of the situation to care.
Our climb instruments have evolved to the point that we really know what the
air is doing in the vertical direction, it would sure be nice to have as much
info about the horizontal direction.
Mark Navarre
2/5 black ace
LoCal, USA
remove brain to reply
Old June 17th 04, 12:09 PM
Dave Nadler YO
Bill, you're absolutely right, during a dead straight glide
with constant airspeed their isn't enough information to
compute the result. With an SN10 you need to make an S-turn
at least to get an update.
The heading sensor issue is a bit difficult. Certainly it can
be done with GPS using multiple antennas (I can't remember the
commercial products that do this off-hand). Google and you'll
find a few research projects using GPS for attitude as well
as heading. Cost is not on for gliders real soon. Compasses
are very cranky beasts, especially if they need to be glider-
pilot-proof (about which I could tell stories for hours).
Making something that is low-cost, self-calibrating, immune
to stupid installations - that's the hard bit.
Hope that all makes sense,
Best Regards, Dave
PS: Haven't seen anyone suggest a sun-tracker yet ?
Or vision-system with terrain matching ?
"Bill Daniels" wrote in message news:_y8Ac.53766$0y.15362@attbi_s03...
Dave, can it give highly accurate, real-time wind data, second by second on
Bill Daniels
m...
I've been analyzing the IGC files from my flights and comparing them to
others.
Other, far better pilots than I, are circling less than 15% of the time.
This means that wind data that depends on the glider flying circles gets
way
out of date during the long glides. OK, "S" turns can give the computer
a
chance to compute wind if you remember to fly them but there are still a
lot
GPS
Pressure
Altitude and IAS) and accurate heading data. Heading data it the tough
nut
to crack.
each
heading
heading
during
With good heading data we could get uninterrupted high quality wind data
Bill Daniels
Old June 17th 04, 01:26 PM
Clint
To compute real-time wind data we need Groundspeed, Ground Track (any GPS
gives these)True Airspeed (Some computers do this if they have OAT, Pressure
Altitude and IAS) and accurate heading data. Heading data it the tough nut
to crack.
So, how do we get Heading? One way might be to put a GPS antenna in each
constant track, it could assume the wings are level and determine a heading
value. This heading value might update an aerospace quality MEMS heading
gyro that would maintain a flow of heading data to the glide computer during
The LX 5000 has the facility for a digital compass - precisely for the
reason that you are looking for a solution for. I have not used a
digital compass with my unit so I have no idea if it works better than
the other estimation methods used by the unit without a compass
attached.
Clinton
LAK 12
Old June 17th 04, 02:23 PM
Bill Daniels
om...
Best Regards, Dave
Bob Lepp e-mailed me info on a company called Aventech that makes wind
direction detection equipment for crop dusters. These folks need very
accurate winds aloft data to predict the drift of chemicals sprayed on
crops.
Their gadget works just like a glider computer with the addition of a
two-antenna GPS array that provides heading data accurate to .5 degree. To
cover any gaps in the GPS signal, they use a solid state inertial unit.
Sensors that detect the earth's magnetic field will always be tricky. GPS
heading sensing looks like a winner since we need the GPS receiver anyway.
Maybe a couple of self-contained Bluetooth GPS receivers attached to the
wingtips would work. An inertial measurement unit would be very useful for
applications other than wind data. These could determine true vertical
regardless of the glider's attitude and very accurately measure Z-axis
acceleration. What vario maker wouldn't love to have that data.
No doubt this will be expensive at first but then we couldn't afford GPS 20
years ago. Twenty years before that glider pilots couldn't afford radios.
Electronics always seems to follow a learning curve that exponentially
reduces cost.
Bill Daniels
Old June 17th 04, 04:11 PM
Bill Daniels
This is what we need but smaller, cheaper, lighter and all other good things
engineering-wise.
http://www.xbow.com/Products/product...s.aspx?sid=104
Bill Daniels
om...
Best Regards, Dave
on
drifting
knots.
30
heading
Bill Daniels
m...
to
others.
time.
time.
gets
way
computer
a
still a
lot
(any
GPS
Pressure
tough
nut
to crack.
each
a
heading
heading
computer
during
data
Bill Daniels
Old June 17th 04, 04:50 PM
Derrick Steed
Isn't there some form of flux gate compass which can be used? The GPS's we use originated in the maritime market (after NMEA is a maritime standard), surely there is a flux gate compass with NMEA output.
Rgds,
Derrick.
Old June 17th 04, 04:52 PM
Andy Durbin
"David Starer" wrote in message ...
David Starer
True, but the issue is confused because some Etrex models incude a
magnetic heading sensor.
Andy
Coupled approach? Roy Smith Instrument Flight Rules 22 September 29th 04 09:46 PM
GPS/Flight Planner/ATC/Auto Pilot Dave Schwartz Simulators 11 May 11th 04 02:05 AM
FA: 10 Watt - Solid State Digital VHF- Transceiver Unicom OH Aviation Marketplace 0 March 30th 04 02:29 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
Great circle formulae, True cource and actual heading Sims Piloting 27 October 11th 03 01:55 PM
