Prandtl multi probe receptacle used for TE only?
Old February 15th 18, 04:26 PM posted to rec.aviation.soaring
krasw
Default Prandtl multi probe receptacle used for TE only?
torstai 15. helmikuuta 2018 15.29.25 UTC+2 kirjoitti:
Now tell me again...
Why aren't the O rings on the probe?
Must be an oversupply of engineers needing to design something like this O ring insertion tool.
If the grooves for O-rings were in the probe it becomes quite weak at the base. Aluminium or brass develops crack at groove area because TE probe vibrates a lot. My guess: they discovered that probe with O-rings/grooves did not last too long. BTW, one-way TE probe has usually a groove and O-ring in the probe. It cracks sometimes but it is easy to glue a new base part to an old probe. With two- or 3-way probe this is impossible.
Old February 15th 18, 05:36 PM posted to rec.aviation.soaring
That makes sense. Unlike the triple probes the ESA TE/Static double probes use the ST2 socket and the probe has a short aluminium (I think) insert with O -rings on it. I had one of those break in flight at an O-ring groove inside the socket. Part way through the task I lost the ability to thermal properly and didn't understand why until I landing and found the probe drooping about 30 degrees and being held by the probe internal flexible tubing..
I contacted ESA directly and they repaired the probe very quickly for a very reasonable cost.
Old February 15th 18, 08:32 PM posted to rec.aviation.soaring
Sure wish ESA would redesign their UN and SUN adapter to offer a "screw-off" front end which could be exchanged when o-rings become faulty. Hey ESA, want to make more money?
Prandtl Flying Wing Testing by NASA [email protected] Soaring 2 March 24th 16 06:55 PM
military spec receptacle MIL-C-24368/2 [email protected] Naval Aviation 0 June 30th 08 05:53 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
Discus Prandtl tube Serge Serfaty Soaring 5 October 6th 04 08:48 AM
