Proper Way to Insert Multi-Probe
Old February 15th 18, 08:46 PM posted to rec.aviation.soaring
kirk.stant
Default Proper Way to Insert Multi-Probe
On Thursday, February 15, 2018 at 2:30:07 PM UTC-6, Steve Thompson wrote:
There are clear instructions by ESA at
https://tinyurl.com/ESAFAQEnglish
which suggest cleanliness, light lubrication, and give
orientation advice also. Just saying.
Ah Ha! Oriented UP!
Let the arguing - and bogus explanations - begin!
(FWIW I've always been in the UP camp...position relative to the horizontal, angle of the probe when changing AOA, less chance of hitting it when installing tail dolly...)
Kirk
66
Old February 15th 18, 09:54 PM posted to rec.aviation.soaring
Dave Springford
Ah Ha! Oriented UP!
Of course it goes up - it's more virile.
Old February 16th 18, 11:14 PM posted to rec.aviation.soaring
Ah Ha! Oriented UP!
Kirk
66
I used to always put my probe up (whenever I had the opportunity), but then someone pointed out to me that when the probe is installed down and the glider is in flying position, the probe is quite close to vertical. Seemed that was likely the correct position.
Old February 17th 18, 07:37 AM posted to rec.aviation.soaring
The typical designed probe is designed to point up which gives the intended angle to the airflow and also keeps the tip high and as close to the line of the tailplane. See Rudy Brozel's articles.
Another quite common factor is to avoid the down pointing probe interfering with a fin pitot which is often close below. Dick Johnson tested this and showed that there was significant interference.
Old February 17th 18, 08:44 AM posted to rec.aviation.soaring
krasw
I'm confused. The adapter for the probe is pointing straight to airflow at flying angle-of-attack. The probe end sticking up or down would have same angle relative to airflow?
Old February 18th 18, 10:15 AM posted to rec.aviation.soaring
Most compensation probes are designed to function with an angle of 70°, not 90° (but some do), between the prong and the airflow. Whatever you do, that angle will change whenever you increase or reduce your airspeed, so the system must have some built-in flexibility. How much flexibility and in what direction (up or down) will probably depend on the design of the probe. So follow the instructions of the manufacturer, would be my advice. ESA Systems says prong up, so that's it for me.
There are two-pronged probes that should be placed with the prongs horizontal.
https://www.esa-systems.com/en/produ...e-dnst-840-mm/
https://www.esa-systems.com/en/produ...robe-dnstatek/
According to a German study, this type gives the best compensation results.
Old February 18th 18, 01:49 PM posted to rec.aviation.soaring
On Thursday, February 15, 2018 at 4:54:24 PM UTC-5, Dave Springford wrote:
Ah Ha! Oriented UP!
Aside from virility raising the sensing point by another 6 inches gets it further above the turbulence coming off the wing root, especially at low speed and high angle of attack.
Also less likely to catch it when removing the tail dolly.
UH
Old February 19th 18, 12:44 AM posted to rec.aviation.soaring
TomNau
This may be a silly question, but isn’t there only one way for it to be oriented correctly for the ports to line up properly?
Old February 19th 18, 01:31 AM posted to rec.aviation.soaring
No, the O-rings seal sections of the tube in the fin, the ports in the probe just empty into that section.
Prandtl multi probe receptacle used for TE only? Matt Herron Jr. Soaring 12 February 15th 18 08:32 PM
Proper Std. Cirrus class Jacopo Romei Soaring 4 January 9th 17 07:57 PM
I will be insert usenet Mark Piloting 2 October 10th 10 12:32 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
