#11
Eric Greenwell wrote:
I thought Johnson's criteria was +/- .004". Thanks Eric and Udo. I got the +/+.002" from a Soaring article *not* written by Mr. Johnson. My mistake! I tried looking at some of the flight tests from the SSA website and +/-.003" to .004" seems to be what Mr. Johnson uses as his benchmark, as Udo says. Now I'm feeling a lot better about my wing reprofiling work! ;-) Regards, -Doug |
Doug,
it is "not + or -" the total is max .004" Udo |
Udo Rumpf wrote:
Doug, it is "not + or -" the total is max .004" Udo OK. Sorry. I read your post a bit too quickly. Then +/- .002" as I originally stated wasn't really wrong? I guess. Looking again at the 6 Richard Johnson articles I sampled he doesn't really nail down a precise figure. For example, in a PW5 test Johnson states he found: "an average wave of about .0065 inches (.165 mm) peak-to-peak over the main spar region, which is somewhat high for a modern composite sailplane". -Doug |
![]() "Derrick Steed It happens to some extent to all GRP gliders as they age (some say PIK's are immune - hmmm...), and it's due to shrinkage of the GRP. I reprofiled some PIK wings some years ago - they are different but they aren't immune. Interestingly, I think the PIK was Dick Johnson's first major profile job. Of course if you just splash some water on that airfoil the waviness can be ignored... |
Maule Driver wrote:
"Derrick Steed It happens to some extent to all GRP gliders as they age (some say PIK's are immune - hmmm...), and it's due to shrinkage of the GRP. I reprofiled some PIK wings some years ago - they are different but they aren't immune. Interestingly, I think the PIK was Dick Johnson's first major profile job. The later PIKs suffered primarily from an improper profile due to mold problems, not the usual shrinkage from a correct profile. It was so severe, Dick had to increase the chord to get the profile thickness percentage right. It's possible they had less shrinkage once out of the mold, due to the high temperature curing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Doug Hoffman wrote: tango4 wrote: yes it's 'normal' and yes it will affect performance it needs fairing, filling and refinishing. Ian Yes. According to Richard Johnson a laminar flow airfoil not only needs to be accurate in shape , but it needs to have no "waves" larger than +/- .002" in 2", in order to extract best performance. If you can see and feel the bump of the spar you are violating both of these criteria. Fairing and refinishing a wing, and making sure the airfoil is correct, is not a small task, but doable. I am (finally) finishing up my RS-15 wings. I know the shapw is accurate and I know the +/- .002" waviness limit is not exceeded (this is best checked with a dial indicator). I thought Johnson's criteria was +/- .004". Eric, After reviewing the articles I could find with more care, and with Udo's input, I think .008" peak-to-peak (or +/- .004") is too large a wave for laminar flow. Regards, -Doug |
Maule Driver wrote:
"Derrick Steed It happens to some extent to all GRP gliders as they age (some say PIK's are immune - hmmm...), and it's due to shrinkage of the GRP. I reprofiled some PIK wings some years ago - they are different but they aren't immune. Interestingly, I think the PIK was Dick Johnson's first major profile job. Of course if you just splash some water on that airfoil the waviness can be ignored... Tell me about it! I have a PIK 20B. The reason I said "some say" is because I've noticed some shrinkage in my wings (not a lot, but it's there). I don't think it's the water so much that ruins the working of the wing, it's how it's applied - a smooth even sheet of it would be just fine aside from the fact that it might destroy the no-slip condition (now there's a thought...) Rgds, Derrick Steed Aon Transformation Programme EDS Leveraged Delivery *e +44 (0)7790 494589 + Wavendon Tower Wavendon Milton Keynes MK17 8LX |
Maule Driver wrote:
"Derrick Steed It happens to some extent to all GRP gliders as they age (some say PIK's are immune - hmmm...), and it's due to shrinkage of the GRP. I reprofiled some PIK wings some years ago - they are different but they aren't immune. Interestingly, I think the PIK was Dick Johnson's first major profile job. The later PIKs suffered primarily from an improper profile due to mold problems, not the usual shrinkage from a correct profile. It was so severe, Dick had to increase the chord to get the profile thickness percentage right. It's possible they had less shrinkage once out of the mold, due to the high temperature curing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA I recall that Dick Johnson found the profile near the leading edge to be too blunt and some friend of his (at JPL, I think) also checked the published airfoil figures and found them to be slightly off and corrected them, he re-profiled a 'B to this and tested it at higher Reynolds numbers (add water, inside rather than outside the wing) - he reported maximum 45:1 and average 43:1. The repairer who works on my glider always cures the repairs he does at elevated temperature as recommended by the resin manufacturer - I believe PIK did just the same. Rgds, Derrick Steed |
Doug Hoffman wrote:
I thought Johnson's criteria was +/- .004". Eric, After reviewing the articles I could find with more care, and with Udo's input, I think .008" peak-to-peak (or +/- .004") is too large a wave for laminar flow. I'm sure you are right - I meant peak to peak. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Derrick Steed wrote:
The later PIKs suffered primarily from an improper profile due to mold problems, not the usual shrinkage from a correct profile. It was so severe, Dick had to increase the chord to get the profile thickness percentage right. It's possible they had less shrinkage once out of the mold, due to the high temperature curing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA I recall that Dick Johnson found the profile near the leading edge to be too blunt It was more than just a too blunt leading edge: the airfoil was significantly thicker at it's maximum than it was supposed be , requiring a larger chord to bring the thickness percentage to the correct value. I believe the problem was due to molds that slowly warped over time, perhaps because of the higher than normal curing temperatures required of the resin used on the glider. and some friend of his (at JPL, I think) also checked the published airfoil figures and found them to be slightly off and corrected them, he re-profiled a 'B to this and tested it at higher Reynolds numbers (add water, inside rather than outside the wing) - he reported maximum 45:1 and average 43:1. The repairer who works on my glider always cures the repairs he does at elevated temperature as recommended by the resin manufacturer - I believe PIK did just the same. The PIK used a resin that cured at a substantially higher temperature than almost all other gliders; in fact, they could be painted colors other than white. There was an entirely yellow one in California/Nevada many years ago that I flew with several times. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Spar workshop CD and DVD available | mat Redsell | Soaring | 0 | May 6th 04 03:52 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
DuoDiscus Wing | Duane Eisenbeiss | Soaring | 27 | October 31st 03 02:34 AM |
Marske spar workshop | Marske Flying Wings | Restoration | 0 | October 14th 03 04:54 PM |
Marske spar workshop | Marske Flying Wings | Soaring | 0 | October 14th 03 04:52 PM |
