Oudie won’t download flight
Old May 2nd 18, 01:17 AM posted to rec.aviation.soaring
Nick Kennedy
Default Oudie won’t download flight
Dennis
My thinking is if the logger is permanently on then it is going to record your flight, every time, without having to remember to turn it on. My CAI 302 and my PowerFlarm both automatically record my flights BTW
Old May 2nd 18, 01:21 PM posted to rec.aviation.soaring
Idea Nick. I have changed the settling. Thanks everyone.
DC
Old May 3rd 18, 03:55 PM posted to rec.aviation.soaring
kirk.stant
I have my Oudie2 updated to the latest s/w.
Now, when I land after a flight, I get the "Flight will Finish" caution on the display, and the Oudie locks up - I have to do a hard reset via the button on the back to restart it.
Not a big deal since I don't use my Oudie as a logger (my PF and SN10 take care of that), but it is irritating.
Anyone else seen this problem?
Kirk
66
Old May 4th 18, 05:12 AM posted to rec.aviation.soaring
Paul Remde
Hi Kirk,
I'm not sure if this is the issue, but make sure the Oudie is not trying to save the flight log to a microSD card when one isn't installed. Go to Menu, Settings, Files and set it to save flight logs to internal memory if it isn't already.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
______________________________
Kirk
66
Old May 4th 18, 02:43 PM posted to rec.aviation.soaring
Hi Paul....I think you mentioned this before... when I go to menu...I hit files and that page does NOT say saving file to anything. I get a greed out terrain...A greed out airspace....waypoints resident flash \airfields and airspace\USA\U. And the file folder Flight Folder.... has \ResidentFlash\Flights\. When I hit the button to the right of the list of files including the flights folder.
I on’t see anywhere it says save to memory card..
Dennis
Old May 4th 18, 04:54 PM posted to rec.aviation.soaring
kirk.stant
On Thursday, May 3, 2018 at 11:12:03 PM UTC-5, Paul Remde wrote:
Hi Kirk,
Good idea - I'll try that tomorrow. Thanks!
Old May 10th 18, 01:55 AM posted to rec.aviation.soaring
My Oudie 2 hangs up after flying a task and landing. It started doing this after I interfaced it with my Portable Flarm. It works well during the flight otherwise. I too have to do a "reset" to get it working again.
I tried setting the Oudie 2 not to allow the flight to be downloaded from the Flarm, but that didn't help either. It hangs up at the end of the flight regardless of the setting ... and I have a Micro SD card.
Even with the "stuck" Oudie at the end of the flight, it still contains a valid .igc file and I've used the file successfully for regional races.
flarm flight log download through Oudie? Matt Herron Jr. Soaring 4 January 21st 15 02:28 AM
Oudie download of task to CAI302 [email protected] Soaring 4 July 17th 13 10:22 PM
CAI 302; slow download of flight log BillT Soaring 9 November 8th 11 04:40 AM
LX20 flight download errors Gabriel Duford Soaring 0 May 1st 11 02:35 PM
Flight download Steve Freeman Soaring 8 June 19th 07 10:01 PM
