Recovery by Spot
Old May 2nd 18, 09:12 PM posted to rec.aviation.soaring
Wojciech Ścigała
Default Recovery by Spot
Gents,
You forgot about one more device we all have installed: VHF radio. Tune
in 121.5 MHZ and ask for a message relay. All airliners monitor 121,500
so the "coverage" is very good.
Wojciech
Old May 2nd 18, 09:20 PM posted to rec.aviation.soaring
Assuming you don't break the tail boom. Typically, that also breaks any wires or cables through that area which also includes.....drum roll please......tail mounted radio antennas.
The more options you have the better regardless of the methodology or technology.
Old May 2nd 18, 09:21 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Many times in crashes, batteries become disconnected so things like radios do not work. This is why Spot/InReach are great as they have their own power source and leave a bread crumb trail.
On Wednesday, May 2, 2018 at 12:12:31 PM UTC-7, Wojciech Ścigała wrote:
Gents,
Wojciech
Old May 3rd 18, 04:56 AM posted to rec.aviation.soaring
2G
Gents,
Wojciech
This is why I carry a backup emergency radio. Anyone who flies cross-country should, too. If you have to walk out, you have a radio to take with you. And if your onboard radio dies in flight, you've got a backup. This is pretty routine for IFR pilots.
Tom
Old May 2nd 18, 11:54 PM posted to rec.aviation.soaring
Dan Marotta
Thanks for that reminder!
On 5/2/2018 1:12 PM, Wojciech Ścigała wrote:
Gents,
Tune in 121.5 MHZ and ask for a message relay. All airliners monitor
121,500 so the "coverage" is very good.
Wojciech
Dan, 5J
Old May 3rd 18, 05:27 AM posted to rec.aviation.soaring
bumper[_4_]
Gents,
Wojciech
That worked for me when I spotted a "body" lying face down in Nevada's Black Rock Desert a dozen years back. Landed my Husky and found the guy was still alive! Got on 121.5 and had they were scrambling to help! Airliner relayed call for air ambulance to Reno Approach. Another Husky in Oregon heard the traffic as well and asked on another forum who was that Husky who rescued the guy in the desert :c)
I used the aircraft radio, I'm sure a handheld would have worked also, though the rubber ducky antenna receives far better than it transmits, plus you aircraft radio may be putting our over 10 watts and the handheld is probably less than 1. Still worth having if your tail boom is broken.
Old May 4th 18, 01:30 AM posted to rec.aviation.soaring
2G
Gents,
Wojciech
I checked several popular handhelds, and they are all 1.5 W carrier (they also use peak envelope power, PEP, but the carrier is what gets the job done). Rubber ducky antennas are crap, especially when you are close to the ground. It would be great if there were a telescoping 1/4 wave emergency antenna.
Tom
Tom
Old May 4th 18, 01:32 AM posted to rec.aviation.soaring
2G
Gents,
Wojciech
Tom
Well, I just checked, and there IS such a thing!
https://www.solidsignal.com/pview.as...AjA_EALw _wcB
Old May 4th 18, 04:03 PM posted to rec.aviation.soaring
Dan Marotta
Careful, that's a marine band antenna and you'll get a much higher VSWR
in the aviation band unless you don't extend it to its full length and
use it as a quarter wave antenna, about 22 1/2 inches.
This one will extend to 47.5 inches so it would make a great half wave
antenna (44 inches):
https://www.amazon.com/Anteenna-TW-9...er+antenna+bnc
Gents,
Wojciech
Tom
Dan, 5J
Old May 3rd 18, 07:00 AM posted to rec.aviation.soaring
Darryl Ramm
On Tuesday, May 1, 2018 at 7:47:21 PM UTC-7, Tango Eight wrote:
Just back from a long weekend at Mifflin...
We had a glider land at the big field near the South end of Raystown ridge Sunday about 1930 local (30 minutes before sunset). His was the last glider flying, no one heard his landing call on 123.3. There is no cell coverage and no available land line phone for several miles around this remote field. At sunset, we noticed we were short one glider. We found the pilot by consulting his spot page, noted multiple pings in same location and an "Okay" msg. Access to this field is difficult, includes a locked gate, so authorities were involved. They got the pilot out late evening, glider recovered on Monday. Despite our assurances that the pilot was okay, the cav was sent complete with fire and emergency medical support.
Coincidentally, this pilot and I were discussing our lack of satisfaction with Spot the evening before. Both of us planned not to renew our subscriptions.
This incident underscores the obvious problems with cell tracking, PLBs (only communicates with .gov functionaries, provides no data, only a non-specific call for emergency help), Spot (one way comm without confirmation, only sends canned msgs to pre-arranged email and txt via email, many potential points of failure, toy like reliability). Inreach might be better? Perhaps. If your device hasn't been bricked by a software "update".
It's probable in this specific incident that we'd have figured things out (albeit with significant uncertainty) from a cell based tracking device. I expect the flight track, time of day and lack of other communication would have made the Raystown field the first place we'd look, but having a firm location and okay msg was pretty huge here. I'm not rethinking any of my misgivings about Spot, but in this specific instance it was a big help.
best regards,
Evan Ludeman / T8
Glad the pilot was retrieved OK. Was somebody actually aware ahead of time the SPOT was potentially going to be used to order up a retrieve? And an "OK" the understood message for that?
Possibly Instead of sending out "OK" it would have been better to have prepared custom message with one saying they are not injured and need a retrieve and having that go directly to the crews/club email. (only one custom message is a limit... you can't ask for example for an air retrieve vs ground retrieve).
But even better, just ditch SPOT. InReach is so much better, and the two way messaging is great. Very flexible and clear, like: "Landed OK, pls. send ground retrieve, cash in trailer, bring Lagunitas IPA, babyback ribs, coleslaw" :-) (ah reminds me of a retrieve from Milford back to Parowan, what a crew, and they did not actually need fancy messages to know to bring beer and great BBQ).
But a reminder there is to load a contacts database in the InReach... relying on looking up contacts on your phone, even if it is still with you, and working, is not a great idea. The rechargeable batteries in the current Garmin InReach units seem great but I carry a USB charger cable to power the InReach from the ships battery just in case I've forgotten to recharge it fully before flying. (And I also have a 406 MHz PLB on my parachute, so covered lots of ways).
FS: SPOT GEN 3 Tracker; NEXGEN SPOT? Duster[_2_] Soaring 0 August 13th 17 01:24 AM
Spot vs Spot Connect guy Soaring 9 January 25th 12 04:48 PM
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 11:30 PM
SPOT D.Rizzato Home Built 0 February 5th 08 01:39 AM
He-111 recovery Vicente Vazquez Military Aviation 3 September 15th 04 01:37 AM
