Accelerated spin in unexpected direction at low altitude
Old July 3rd 18, 11:40 PM posted to rec.aviation.soaring
CindyB[_2_]
Default Accelerated spin in unexpected direction at low altitude
On Monday, July 2, 2018 at 2:26:21 PM UTC-7, wrote:
Bob, N232PC is my N number for a ASW27
Cliff Hilty (CH) ASW 27 formerly Paul Cordell's hence the PC
N numbers can change over the lifetime of an airframe, at least in the US.
New owner? They can apply for a new random or personally chosen (registration) N-number. The only number that remains with the machine throughout its life is the factory serial number. And sometimes, if there is a damage incident -- major components from one wreck might make it onto the other parts of another airframe. Hence a fuselage wtih one serial number and a wing or elevator with a differing serial number. Changes of that significance would hopefully be reflected in the maintenance logs.
Seen this in person,
Cindy B
Old July 4th 18, 06:30 PM posted to rec.aviation.soaring
My bad, mine is 272PC. New to me last August. I have reserved 272CH but not sure its worth the effort to change it
Cliff Hilty (CH) ASW27
Old July 2nd 18, 08:42 PM posted to rec.aviation.soaring
Soarin Again[_2_]
Thank you for this. The only time I have been in an over the top spin
was
in one particular 2-32 only from a slip to the left. Allow this
particular
2-32 to get slow in a left slip and over the top you went. Would not do
it
from a slip to the right and I had always been thought that an aircraft
will not stall from a slip. Unfortunately this glider is not with use
any
more and I have not been able to get any other 2-32 to do an over the top
spin entry from a slip.
In the mid 90's while high in Minden wave and test flying a Puchacz
for
a potential club purchase. An investigation of the gliders slip and
slipping
turn characteristics. During a deep left slipping turn the glider
abruptly
broke over the raised right wing into an aggressive right spin. Onlookers
said it appeared very much like a left slipping turn into a right snap
roll
spin entry. Considering that I was at about 1g at the time so there was no
g-loading associated with this event. My assumption was that the raised
wing was blanked and stalled by the associated fuselage/wing turbulence.
I did not attempt to repeat the incident in that or any other Puchacz, so
I
have no idea if that characteristic was typical for make and model or
limited
to that particular glider. It's still remains the most aggressive spin
entry I
have ever experienced in a glider or airplane.
I should add that the club did go ahead and ordered a new Puchacz.
Unfortunately a number of years later during a check flight with the clubs
primary instructor/club president and a new club member/airline pilot,
were
both killed when their Puchacz spun to impact.
Old July 3rd 18, 01:29 PM posted to rec.aviation.soaring
On Sunday, June 24, 2018 at 11:03:16 PM UTC-4, wrote:
There are three messages here
Your glider may not always enter spin in the same direction you turn or circle. At high bank 50-60 degree in tight turn with high G load your upper wing may stall first. In a split second you can get in accelerated spin in unexpected direction. Scenario could be a new quick decision at altitude below 200 feet during land-out.
I witnessed Jantar Std3 doing 180 from downwind to short final in 60 degree of bank at an altitude about 150 feet. In the middle of RIGHT 180 turn the glider flipped LEFT and made ONE full turn of accelerated spin in about 2-3 seconds before hitting ground. UPPER (left) wing stalled first. It was so fast that there was no chance for pilot to react. The 21 years old pilot survived with broken legs. His life was saved because left wing hit the ground and broke partially mid section taking some energy off of the nose of the cockpit.
The next day I took Jantar Std3 to try to duplicate case of glider spin in opposite direction to the turn (at altitude 3000-4000 feet). I was determined to find out what happened, I tried 60-degree bank with high G and different aileron positions. Finally it happened on the 16th try.
There is another important message here with a twist. Above accident would not happen at all if the pilot would stick to his original plan after he completed his speed triangle. His plan was to make only one 90 degree Left turn at an altitude 400 feet over flightline and land toward hangars. When he initiated that Left 90-degree turn, the flight instructor noticed that and sent him on close downwind pattern to land on flightline from that low altitude, he said on the radio "right love! right!". I will never forget that radio call. The 21 years old pilot should have followed his original plan.. So now from that low altitude of 400 feet he had to do Right turn 90 degree, go downwind 200 yards then tight Right 180 to short final for landing. And this was the instructor who thought the pilot from scratch when he was 17. Sometime the same instructor who teaches you can kill you. The young pilot was worried that he could be grounded for not following landing instructions. Stick to your original plan, you are the final authority when you fly. You are not radio-controlled model. You can argue later. If you spin below 150 feet you have better chance of survival if you keep spinning versus stopping rotation, but take your feet off the pedals and bend your knees. And please teach full spin and recovery in US, please. Fly lower on tow, always keep more speed, you will live longer. Be safe. Andre
Could someone tell me what an "accelerated spin " is.
Thanks
UH
Old July 4th 18, 02:30 AM posted to rec.aviation.soaring
Bruce Hoult
There is another important message here with a twist. Above accident would not happen at all if the pilot would stick to his original plan after he completed his speed triangle. His plan was to make only one 90 degree Left turn at an altitude 400 feet over flightline and land toward hangars. When he initiated that Left 90-degree turn, the flight instructor noticed that and sent him on close downwind pattern to land on flightline from that low altitude, he said on the radio "right love! right!". I will never forget that radio call. The 21 years old pilot should have followed his original plan. So now from that low altitude of 400 feet he had to do Right turn 90 degree, go downwind 200 yards then tight Right 180 to short final for landing.. And this was the instructor who thought the pilot from scratch when he was 17. Sometime the same instructor who teaches you can kill you. The young pilot was worried that he could be grounded for not following landing instructions. Stick to your original plan, you are the final authority when you fly. You are not radio-controlled model. You can argue later. If you spin below 150 feet you have better chance of survival if you keep spinning versus stopping rotation, but take your feet off the pedals and bend your knees. And please teach full spin and recovery in US, please. Fly lower on tow, always keep more speed, you will live longer. Be safe. Andre
I'd assume one resulting from an accelerated stall i.e. a stall at higher speed than the normal straight and level stall speed, due to G loading.
Old July 4th 18, 07:36 AM posted to rec.aviation.soaring
CindyB[_2_]
Thanks
UH
"Accelerated spin" ? No such thing unless you wanted to quantify rotation rate.
I think what Marty and Andre meant to say was abrupt, unexpected departure.....
or departure from accelerated stall --
but that makes for less storydrama by having a more concise description.
Don't spin a Puch without chutes and a hard deck(1000m agl). Ever.
Best wishes,
Cindy B
Old July 4th 18, 02:57 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Out of sheer curiosity, why do you say that?
I've been flying gliders for 18 years and have spun the club's Puchacz at
least once in each of those years. Its always done what I expected it to
do apart from the occasional wing drop in an intentional stall and has
never spun when I wasn't expecting it to. Its the one of our club's two
seaters that I most enjoy flying solo.
Martin | martin at
Gregorie | gregorie dot org
Old July 4th 18, 04:38 PM posted to rec.aviation.soaring
6PK
It's that one time that will get you....
Old July 5th 18, 05:38 AM posted to rec.aviation.soaring
Charlie Quebec
Because of the large number that have spun to the ground and killed the occupants perhaps?
The Puch is overepresented in these kinds of accidents.
Old July 5th 18, 06:33 AM posted to rec.aviation.soaring
Bruce Hoult
And generally with an instructor on board. And not spinning accidentally in the circuit, but spins deliberately initiated at altitude.
They recover just fine 99.99% of the time. But it seems that every so often .. no.
an unexpected result a[_3_] Piloting 11 September 26th 08 04:23 AM
An Unexpected Treat Jay Beckman Piloting 14 March 13th 07 03:01 PM
Glider in an unexpected place... Capt. Geoffrey Thorpe Soaring 3 September 15th 06 03:56 AM
Headset: Unexpected safety bonus Vaughn Owning 16 January 18th 06 02:27 AM
Accelerated spin questions John Harper Aerobatics 7 August 15th 03 07:08 PM
