FAI Sporting Code Section 3 experts wanted
Old August 29th 04, 06:30 AM
Marc Ramsey
Stewart Kissel wrote:
So if a Start Point is declared....you can tow as high
as you want with out penalty? And a declared finish
point altitude is then subtracted from this?
Not quite. You don't declare the elevation of the start and finish
points, nor is the elevation of the ground underneath the points
relevant. The start altitude for a declared start is the (pressure)
altitude from the last fix recorded before you cross the start line or
exit the start sector. The finish altitude for a declared finish is the
(pressure) altitude from the first fix after you cross the finish line
or enter the finish sector. So, if you cross the start line at an
altitude of 3120 meters, you have to finish at 2120 meters or above to
avoid the penalty.
Marc
Old August 29th 04, 06:37 AM
Marc Ramsey
And if you use tow release as your start with no declared
finish...can you land anywhere you please?
Yes, but for a distance task you can do that in any case, even if you
declared a finish. I also believe (but I'm not 100% certain, Judy can
correct me on this), that you can declare a start point, fly the
distance task without actually claiming the declared start, and get
credit for the distance task based on an undeclared start at the point
of release.
Marc
Old August 29th 04, 07:35 AM
Stewart Kissel
Ah, that was going to be my next question Mark. Can
you use the release point if you have a declared Start
Point. I gotta see what Judy says on this.
Would you not want to always have a declared finish...so
you can get credit for altitude you have at the finish,
rather then use the landing for the finish and lose
that altitude for your calculation versus the start
altitude?
case, even if you
certain, Judy can
fly the
start, and get
start at the point
of release.
Marc
Old August 29th 04, 07:39 AM
Marc Ramsey
altitude?
That's what I always do...
Marc
Old August 29th 04, 02:51 PM
Stewart Kissel
altitude?
Marc
Ok, this helps clear up an issue that has been bugging
me. I would be interested in anyone who could verify/comment
on whether a tow release could be used for a start...If
a Start Point had been declared. If this cannot occur,
I see pluses and minuses for using either scenario.
Old August 30th 04, 12:09 AM
Denis
Eric Greenwell wrote:
What I think is a quirk in the rules lets a motorglider pilot
effectively choose the end of the task by starting the motor, but the
unpowered glider pilot must either declare an end point or use the
landing point.
I agree. Unfortunately it's not the only quirk in the Code Sportif,
which has accumulated rules over rules for 50 years at least without
wiping out *all* quirks that may have resulted from these changes
(despite the good job that has be conducted by the SC3 specialist).
It might be a good idea for the IGC bureau to launch a review of the
Code Sportif as a whole, as they had for loggers (Bob, if you read me
Denis
R. Parce que ça rompt le cours normal de la conversation !!!
Q. Pourquoi ne faut-il pas répondre au-dessus de la question ?
Old August 30th 04, 12:16 AM
Denis
No, it cannot (except reverting to a *free record* performance)
But you may use release altitude as your start altitude (for the 1000 m
difference with the altitude at finish point) and pass within the
declared start point observation zone later and higher (distance flights
only, not allowed on speed tasks)
Denis
Old August 30th 04, 04:08 AM
Stewart Kissel
Gotcha...so u gotta use the Start Point if declared...but
u can pick which altitude for the calculation(Release
from tow, or Start Point elevation)
(for the 1000 m
within the
(distance flights
Denis
question ?
Old August 30th 04, 06:34 AM
Marc Ramsey
SC3 1.4.5.b says that distance using up to three turnpoints is "A flight
from a START POINT via up to three TURN POINTS to a FINISH POINT." Note
that is says "a START POINT", not "the START POINT". SC3 1.1.8 says a
START POINT is either "(a) The RELEASE POINT, or (b) A WAY POINT
declared as a START POINT, or (c) The midpoint of a START LINE." Note
that the pilot or data analyst can apparently choose between (b) and (c)
after the flight, as I've never seen a declaration form (paper or
electronic) that requires that you declare before the flight that you
are using a start line as opposed to a start way point (with OZ). Being
a computer programmer, I'd argue that the "or" in clause (a) has the
same logical precedence as the "or" in clause (b). Therefore, if you
have declared a start, it still seems to me that it would be valid to
use any of the START POINT options, including the RELEASE POINT. Have
you found a rule someplace else that would render this interpretation
incorrect?
Marc
Old August 30th 04, 01:35 PM
Dale Kramer
Marc,
I can verify that this interpretation is correct.
In 1999, I used this interpretation and received my 1000km.
It was not easy to obtain with this interpretation and it took many
months of perseverance.
I believe I was the first to do this and I don't think they were happy
about my insistence on this literal interpretation of the rule.
It would be interesting to know if anyone else has successfully used
it.
I took off at Ridge Soaring with Altoona declared as a start and
finish. Three turnpoints were declared between and then landed at
Ridge Soaring. I got in wave on my way to Altoona and decided to fly
down to Cumberland for fun before I started. I was in wave when I
started at Altoona. I was able to use my tow release as my start
altitude and my finish altitude at Altoona for the 1000m calculation.
Dale Kramer
K1
Marc Ramsey wrote in message . com...
incorrect?
Marc
Run up for plug clearing Roger Long Piloting 78 October 18th 04 03:39 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
