stowing horizontal stabilizer on tail boom in trailer
Old September 9th 18, 05:20 PM posted to rec.aviation.soaring
C-FFKQ (42)
Default stowing horizontal stabilizer on tail boom in trailer
Pictures of my boom-mounted stab.:
https://www.dropbox.com/sh/7vnlgujvt...jO-itjlIa?dl=0
Old September 9th 18, 06:03 PM posted to rec.aviation.soaring
Frank Whiteley
On Friday, September 7, 2018 at 8:43:22 AM UTC-6, Steve Leonard wrote:
On Thursday, September 6, 2018 at 7:44:09 PM UTC-5, C-FFKQ (42) wrote:
My Kestrel uses a saddle that straps onto the tail boom and is kept from rotating by a section that goes up the fin.
The horizontal stab fits into a full cuff at one end and an open cuff at the other, held in by bungee cord.
If I can get at the ship in the next day or so -- and remember -- I'll take pictures and forward them to you.
Or, you can go to the Wings and Wheels classifieds, look in the "recently sold" for the Slingsby T59 Kestrel and see the cuff.
https://wingsandwheels.com/classifieds/?m=sold
Sorry, I can't pull it up by itself any more. It is on the first page, though. Can't miss it.
Steve Leonard
That cuff design needs to be secured to the trailer floor also to keep it from sliding forward during stops. As displayed, that strap will not keep it from sliding forward and rolling to the weighted side, which is likely to damage the trim (anti-balance) tab.
Frank Whiteley
Old September 17th 18, 08:45 AM posted to rec.aviation.soaring
We've had a few club trailers with this setup - much like the Kestrel picture functionally but made of two wood pieces with felt pads connected to each other by square section steel tube and strapped to the fuselage. The fuselage taper prevents the saddle from sliding. They work but I've never found it to be a desirable setup myself. Even in the box trailer my ship came in I found it much easier to use the hanging-from-the-ceiling type stowage the builder installed. I found the horizontal stabilizer both added weight to the tail when moving the fuselage out of or into the trailer and made it more awkward to get a grip on it. It does have the advantage over most mount-to-the-floor holders in that you don't need to remove it from the trailer and secure it somewhere before taking the fuselage out though. None of those club trailers were tall enough inside to use the overhead mount for the horizontal stabilizer though. We do have a privately owned Phoebus C at the field in a box trailer where the horizontal stabilizer sits in a floor mounted bracket to the left of the left wing and doesn't need to be taken out before the fuselage and wings - really convenient but unfortunately impossible on most box trailers I've seen due to lack of space.
Old September 19th 18, 01:13 AM posted to rec.aviation.soaring
Charlie Quebec
Hanging the tail plane near the top of a trailer can cause excess heat to,damage surface in hot environments.
Ive seen a tailplane that had severe gel coat damage on the surface nearest the top of the trailer, despite no signs of failure on any other part of the glider.
Old September 19th 18, 03:14 PM posted to rec.aviation.soaring
Dan Marotta
Coincidence, perhaps?
Cobra and Komet trailers have been carrying the horizontal stabilizer
attached to the underside of the top for as long as I can reall (the
mid-80s).Â* I've never seen the damage you described.
Dan, 5J
Old September 19th 18, 04:14 PM posted to rec.aviation.soaring
Mid 70s for me. Yeah, there must be thousands of trailers with the horizontal stab up against the top. I suspect UV was a big contributor. Early trailers didn't include a layer said to specifically block UV. The stab was often the first to go. The second area to craze was often the top of the fuselage behind the canopy: i.e., a big flattish area exposed to UV penetrating the trailer. Obviously other factors were at work (e.g., moisture, stress cracking of the brittle gel coat layer) since the underside of the wings also showed damage eventually.
Chip Bearden
Old September 20th 18, 05:03 AM posted to rec.aviation.soaring
Charlie Quebec
If you have a glass top trailer you won’t. The normal home built aluminium type commonly seen here in Oz, where
the glider has been stored for a couple of years with the tailplane within an inch of the metal......
Old September 20th 18, 03:21 PM posted to rec.aviation.soaring
Dan Marotta
Aha!Â* You're talking /_heat_/.Â* No argument there.Â* I thought you were
talking /_UV_/...
I got my initial winch training at Bond Springs, NT, and know how hot it
can get there.
Dan, 5J
Old September 29th 18, 07:20 AM posted to rec.aviation.soaring
Morgan[_2_]
I built one of these for the DG-101 we used to own. Now owned by the Central California Soaring Club.
Pretty simple build out of 3/8" plywood if I remember right. Maybe 1/2". I can't seem to find a photo of it unfortunately.
Definitely could have been better built, but it's lasted many years with only a few repairs.
The front "bulkhead" has the larger radius half circle cutout for the tailboom and a vertical notch for the horizontal to drop into.
The aft "bulkhead" has a smaller radius half circle for the tailboom and a full airfoil cutout for the horizontal to slide into.
The bulkheads I mocked up in cardboard to make a template, then dropped that onto plywood and cut it out.
I made something of a box frame to join the fore and aft bulkheads and it extends into a V type of fork that slips around the vertical stabilizer.
All surfaces of wood that touch fiberglass were wrapped with a soft boat carpet and I made some steel v cuffs from sheet metal to secure the horizontal and the rudder.
The whole thing just secures with bungees and is quite stable on the road.
Not the easiest thing to describe, but it wasn't too hard to build with wood and a jigsaw. Just get the cutouts for the fuselage close and then use thin foam and carpet to pad it.
I started with wood as a simple prototype. Of course, I never went back and made a new one.
One unanticipated downside is that it adds a fair bit of weight to the tail.. So if you've got to lift the tail out of the wheel cup or carry it out of the trailer over the ramp, you've got a fair bit more weight to deal with.. That's not surprising, but how much harder it can be to extract from a tube trailer due to the extra weight was. I added a third rail ramp to allow the glider to be rolled out until the tailwheel was on the ground. That helps a lot.
Morgan
On Thursday, September 6, 2018 at 7:14:01 AM UTC-7, wrote:
I have seen a glider trailer in which the aircraft's horizontal stabilizer is strapped to the glider's tail boom for storage and transport. I can't recall where I saw this, and a google image search did not yield any hits.
At any rate, strapping the horizontal stabilizer to the tail boom is one solution I am investigating as my partner and I work to retrofit a new tube trailer to our DG-101. It seems to me that this could be a storage configuration that would not require the awkward stooped climb-and-carry maneuver that is required if the stabilizer is attached to the roof of the trailer.
I am seeking advice on whether this is generally a good idea and if there is a commercial product we could use.
Matt
Old September 29th 18, 07:44 AM posted to rec.aviation.soaring
Charlie Quebec
Mine for the very similar DG200 is made in much the same way, however I changed from bungees to Velcro to secure to the boom, works much better.
Scheibe SF-25 Motorfalke horizontal stabilizer and other parts needed [email protected] Soaring 7 January 25th 17 05:51 PM
Looking for a Libelle Horizontal Stabilizer J Wahl Soaring 1 May 2nd 15 05:01 AM
G-103 horizontal stabilizer airfoil section ? [email protected] Soaring 3 November 23rd 08 04:30 AM
Why are (some) delta wings stable without a horizontal tail? xerj Piloting 13 April 11th 06 02:38 AM
WTB: 1-34 Horizontal Stabilizer Jeremy Zawodny Soaring 1 October 15th 04 05:12 AM
