Engine monitoring systems for towplanes
Old September 18th 18, 03:55 PM posted to rec.aviation.soaring
Boom Powell
Default Engine monitoring systems for towplanes
TSS has a EDMI in our 235 Pawnee for over a year and think it was a good investment, although, at times I wonder if it tells us more than we want to know. We had both CHT and EGT at higher limits on tows. EGT unexplainable after several inspections. Having cowling louvers installed to get the CHTs lower. The cooling monitor is most useful to avoid shock. Keep below 30deg change while reducing power. The power decrease to stay less than 30 keeps the Pawnee level after release, but as temps stabilize and power keeps coming back, you're soon doing 110mph and 1800rpm. Total tow time is about the same as with previous 2000rpm/100mph technique.
Old September 18th 18, 05:27 PM posted to rec.aviation.soaring
danlj
On Thursday, September 6, 2018 at 5:03:42 PM UTC-5, wrote:
Hey, gang,
Soon we will be putting an overhauled engine on our Pawnee, and I am wondering if anyone has had experience with or has comments on engine monitoring systems on towplanes.
I am thinking a basic system with all 6 cylinders CHT (and EGT?) monitored, a shock cooling warning system, and data logging. Would monitoring other parameters be useful, also? If so, what parameters (adding sensors adds up $$$)?
Is such a system useful and helpful for our type of flight duty cycle (e.g., towing)? Do the shock cooling warning systems work for our very unique type of operations (I guess they are just an alarm if the rate of CHT drop exceeds a set value?)? Is the data logging useful for monitoring/predicting engine health and life? Am I overthinking/overkilling this issue?????
I've been using a recording engine monitor for the dozen years that I've owned an airplane -- it's invaluable in understanding how to operate the engine safely and in looking back on flights where one suspects that "something" may have happened.
Some tips I got from Ed Kollin...
- "Shock cooling" does not happen. "Shock heating" happens often (when pilots take off at full power without taking a few minutes to at least get the oil temperature above 100 degrees (an engine monitor will tell you exactly where itis)
- CHT are optimally between about 380 and 320 dF. Aluminum begins to deform above about 400 dF; in my own experience, rings can lose their temper and become brittle and later break above about 430 df.
My own experience is that CHT is extremely helpful in operating an engine for maximum longevity. I have mine alarmed at 400dF.
Oil temperature is important to understand whether the engine is adequately warmed up before takeoff.
Carb temp is useful in understanding risk of carb ice.
I like to run LOP in cruise for economy at low power (65%) but high-power, ROP operation only makes the oil dirty. It's good for the engine.
Tire Pressure Monitoring Systems for Trailers AS Soaring 6 July 11th 18 04:00 AM
North American Sabreliner pics [1/9] - BAE Systems Flight Systems T-39A flight test aircraft at the Mojave Airport.jpg (1/1) Miloch Aviation Photos 0 January 31st 18 03:41 PM
motorgliders as towplanes Brad[_2_] Soaring 262 March 22nd 09 02:17 PM
Trailer tire pressure remote monitoring systems Eric Greenwell Soaring 11 August 9th 08 06:03 AM
Engine monitoring system VM 1000C experience? Bandit Home Built 0 November 13th 06 01:25 PM
