Ballistic chutes would save more lives then safety cockpit. Too bad that ballistic chutes are not built into every glider. There would be far less fatalities.
Ramy |
On Sunday, 9 September 2018 19:26:19 UTC+3, Ramy wrote:
Ballistic chutes would save more lives then safety cockpit. Too bad that ballistic chutes are not built into every glider. There would be far less fatalities. Ramy Yes, safety cockpit can save you or your back in occasional landing gone bad, probably survivable anyway. Spinning to ground or crashing ridge at flying speed is not survivable with any cockpit, there is too much energy and too little structure to absorb this. European ultralights (LSA with 1000lb MTOW) are mostly (?) equipped with airframe rocket parachutes. Cost doesn't seem to be prohibitive, judging from number of them in use. This should have been mandatory equipment for gliders since 90's, think of lives saved after midairs. |
At 05:56 10 September 2018, krasw wrote:
On Sunday, 9 September 2018 19:26:19 UTC+3, Ramy wrote: Ballistic chutes would save more lives then safety cockpit. Too bad that = ballistic chutes are not built into every glider. There would be far less f= atalities.=20 =20 Ramy Yes, safety cockpit can save you or your back in occasional landing gone ba= d, probably survivable anyway. Spinning to ground or crashing ridge at flyi= ng speed is not survivable with any cockpit, there is too much energy and t= oo little structure to absorb this. European ultralights (LSA with 1000lb MTOW) are mostly (?) equipped with ai= rframe rocket parachutes. Cost doesn't seem to be prohibitive, judging from= number of them in use. This should have been mandatory equipment for glide= rs since 90's, think of lives saved after midairs. Ballistic chutes can only protect against problems at altitude, high enough for the chute to deploy. If the accident only starts to happen at low altitudes then it won't help at all. And the chute has to be menually deployed so the piilot has to recognise there is going to be an accident while still at altitude. Not sure how many glider accidents meet these criteria. Midairs are the only ones I think. Chris |
Is there any aircraft which has room for a ballistic shute and an engine aft of the cockpit? I think it is the popularity of engines which has prevented more widespread fitment of ballistic chutes.
Chris,
Ballistic chutes have been successfully deployed as low as 300 feet and BRS claims 386 lives saved, so far! Deployment requires 35 pound pull on the "little red handle", which fires the rocket hooked to a long sleeve with the parachute inside. Rocket and sleeve completely separate, leaving chute with a slider ring up near the fabric. Chute only partially fills at first, then the slider drops and allowes full deployment..........thus preventing chute failure from high speed deployment. My BRS 1050 system is good for 1050 G/W and 130mph at deployment. JJ |
Appears to be pretty survivable:
https://www.youtube.com/watch?v=loNgEDxeQc8 On Sunday, September 9, 2018 at 10:25:49 PM UTC-4, Dan Marotta wrote: Everything Mark said, however the F1 crashing into the wall most often hits it with a glancing blow allowing parts to shed whereas the glider quite often hits the ground head on.Â* I wonder how survivable an F1 crash directly into the wall at 200 mph would be... On 9/9/2018 10:04 AM, wrote: I've watched a lot of Formula 1 lately, where 200mph+ crashes are a regular occurrence. More often than not, the drivers walk away without a scratch. What is to prevent glider cockpits from implementing similar safety designs? The primary factor that imparts superior crashworthiness to F1 and Indy cars is the suspension and wings that are sheared away during impact. As components are peeled off, energy is expended and deceleration happens over a longer period of time. By the time the "tub" surrounding the driver's cockpit is next in line for a pounding, the deceleration that has already taken place reduces the energy imparted to the remaining structure. Additionally, the design of the cockpit has multiple layers of extremely strong carbon fiber and Kevlar formed in such a way that forces are redistributed around the structure and withstand penetration and crushing. The many and regular crashes occurring over the years have provided a wealth of data for the design of each succeeding generation of racing cars. Very little data is collected for the teeny-tiny sailplane market, with only three or four manufactures worldwide. Modern sailplanes comply with CS-22 crashworthiness standards that spell out minimum requirements for structural rigidity and cockpit penetration. Unfortunately, bringing crashworthiness up to F1 standards would require a cockpit that would be lots heavier and might not help much at all, as the deceleration of the little pink body inside is difficult to control. You can scramble an egg inside the shell. Perhaps the next generation of composites (graphene, etc.) will allow for more robust structural integrity, but be prepared for a large price increase. -- Dan, 5J |
My DG 202 has a double wall safety cockpit, there is no removable seat pan for this reason.
On Sunday, September 9, 2018 at 7:25:49 PM UTC-7, Dan Marotta wrote:
Everything Mark said, however the F1 crashing into the wall most often hits it with a glancing blow allowing parts to shed whereas the glider quite often hits the ground head on.Â* I wonder how survivable an F1 crash directly into the wall at 200 mph would be... On 9/9/2018 10:04 AM, wrote: I've watched a lot of Formula 1 lately, where 200mph+ crashes are a regular occurrence. More often than not, the drivers walk away without a scratch. What is to prevent glider cockpits from implementing similar safety designs? The primary factor that imparts superior crashworthiness to F1 and Indy cars is the suspension and wings that are sheared away during impact. As components are peeled off, energy is expended and deceleration happens over a longer period of time. By the time the "tub" surrounding the driver's cockpit is next in line for a pounding, the deceleration that has already taken place reduces the energy imparted to the remaining structure. Additionally, the design of the cockpit has multiple layers of extremely strong carbon fiber and Kevlar formed in such a way that forces are redistributed around the structure and withstand penetration and crushing. The many and regular crashes occurring over the years have provided a wealth of data for the design of each succeeding generation of racing cars. Very little data is collected for the teeny-tiny sailplane market, with only three or four manufactures worldwide. Modern sailplanes comply with CS-22 crashworthiness standards that spell out minimum requirements for structural rigidity and cockpit penetration. Unfortunately, bringing crashworthiness up to F1 standards would require a cockpit that would be lots heavier and might not help much at all, as the deceleration of the little pink body inside is difficult to control. You can scramble an egg inside the shell. Perhaps the next generation of composites (graphene, etc.) will allow for more robust structural integrity, but be prepared for a large price increase. -- Dan, 5J Not good: https://www.youtube.com/watch?v=VDjKCoHD278 Tom |
Well, basically head first in an open cockpit is not a good judge of cockpit safety. Sorta like landing glider canopy first (upside down), the cockpit never really comes into play.
| Thread Tools | |
| Display Modes | |
| Glider Safety Webinar | Tom[_12_] | Soaring | 3 | January 3rd 12 11:53 PM |
| Glider Safety | Tom[_9_] | Soaring | 1 | March 2nd 10 04:41 PM |
| Glider Safety | Tom[_9_] | Soaring | 65 | March 2nd 10 12:39 AM |
| Glider Safety, etc. | None[_2_] | Soaring | 3 | February 27th 10 04:46 PM |
| SAFETY TOOLS IN OUR COCKPIT | [email protected] | Soaring | 7 | October 17th 08 07:04 PM |
