Thanks guys - that helps.
Anyone out there have any experience with heating the wings to get to a stable post-curing shape? I'm a bit concerned about being the first person on the planet to easy-bake my glider. 9B At 16:48 07 September 2004, Tomnkeylargo wrote: What BB said happened to mine also. I also got blowen off with no help offered except bring your checkbook. My bottoms were really bad with waves of great than .009 or worse. Some approaching .018 to .022. Now, everything is fine and they are down to .002 or less. Mr. Fidel did mine, he does great work, as do several others around the country. BUT you have to get it done for the performance to be where it should be. # 711. |
Anyone out there have any experience with heating the wings to get to a stable post-curing shape? I'm a bit concerned about being the first person on the planet to easy-bake my glider. But at the same time I don't want to make this a bi-annual event for the next half-dozen years. At least I have a convenient, lame excuse for my competition performance this year. 9B At 16:48 07 September 2004, Tomnkeylargo wrote: What BB said happened to mine also. I also got blowen off with no help offered except bring your checkbook. My bottoms were really bad with waves of great than .009 or worse. Some approaching .018 to .022. Now, everything is fine and they are down to .002 or less. Mr. Fidel did mine, he does great work, as do several others around the country. BUT you have to get it done for the performance to be where it should be. # 711. |
Andy Blackburn wrote in message ...
Thanks guys - that helps. Anyone out there have any experience with heating the wings to get to a stable post-curing shape? I'm a bit concerned about being the first person on the planet to easy-bake my glider. But at the same time I don't want to make this a bi-annual event for the next half-dozen years. One repair man I know gets the recommended repair cure temperature by putting black polythene over the trailer. Just moving back to Arizona may be good enough. Andy |
In a similar vein, I was thinking about using a toilet
plunger to pull the dimples out. It was only 105 in the PHX area today - autumn must have arrived! ;-) At 23:18 07 September 2004, Andy Durbin wrote: Andy Blackburn wrote in message news:... Thanks guys - that helps. Anyone out there have any experience with heating the wings to get to a stable post-curing shape? I'm a bit concerned about being the first person on the planet to easy-bake my glider. But at the same time I don't want to make this a bi-annual event for the next half-dozen years. One repair man I know gets the recommended repair cure temperature by putting black polythene over the trailer. Just moving back to Arizona may be good enough. Andy |
Hi John,
I have some issues with my ASW 27A as well however I do not have dimples in the true sense of the word. Have you or anyone else measured the depth of the reported dimples? I thought I had dimples which appeared in regular rows both spanwise and cordwise, however, they had no depth and could not be felt. They were visible only when looking at the wing obliquely in the sunlight. I am told they are produced when the wing is being made. Apparently, when the wing is made there are vent holes in the jelcoat which are filled with a somewhat different material and then finished leaving what look like dimples but are completely smooth. Do you have any depth measurements of the dimples or further obsevations? By the way my ship was manufactured in Oct.'98 and has flown about 750 hrs. Lorry Charchian (LJ) I've seen the same thing on a local A model. It's a totally different phenomenon. The A's sometimes get these very little dimples on the top, which as someone else said probably don't do anything. The Bs get much bigger and deeper dimples along the bottom surface where the spar is glued to the wing. The ribs also shrink, but that is chordwise rather than spanwise so probably only esthetic. John Cochrane |
Larry,
The dimples you see are from holes in the foam core that allow resin to penetrate the foam and insure a good bond between the cloth and core. Usually don't cause a performance problem. Some ships are perfect and stay that way, others go to hell in no time at all. Ever wonder why? We have a 27 here in Northern California that is absolutely perfect and it shows. It's owner just won the 18 meter nats with it. JJ's theory--------------Oh, lets hear yours first. :) JJ |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
