LiFePO4 chargers
Old November 10th 18, 06:02 AM posted to rec.aviation.soaring
kinsell
Default LiFePO4 chargers
On 11/4/18 3:51 PM, wrote:
On Monday, November 5, 2018 at 8:02:04 AM UTC+10, wrote:
I also have heard the stories about fires while charging, but, as far as I know, most involved a different Lithium chemistry (Li-ion, Li-Polymer etc.) LiFePO4 is supposed to be safer, but by how much I do not know. At any rate, I am pretty much stuck with charging them in the plane, as they are mounted well behind the spar, and it takes a good 20-30 minutes to get them out and put them back in.
Here is an FAA report that supports the assertion that LiFePO4 cells are safer:
https://www.fire.tc.faa.gov/pdf/TC-16-17.pdf
In their testing, which they admit had quite variable results, they did not get any thermal runaway with LiFePO4 cells, but did with all the other Li chemistries they tested. Note that the graphs in the above article show 1 cell out of 5 consumed by "thermal runaway" but that was the cell that they were heating externally to try and initiate the runaway.
Not to say that you shouldn't take precautions, all battery chemistries store enough energy to start an electrical fire, even if they are relatively immune to thermal runaway and overcharging.
I would hope they're safer than something like a li-po, model airplanes
using those things routinely put on a fireworks display during a crash.
Fascinating videos on YouTube.
However, "safer" isn't actually the same as "safe", LFP's are quite
capable of burning, despite what the scholarly articles say. There have
been a number of fires, particularly when they're used as starter
batteries. High charge rates and very high discharge rates seem to
cause problems, as homebuilders of small power planes have discovered.
There was also that LFP battery fire in an EB-28 in Finland this summer.
-Dave
Old November 11th 18, 02:02 PM posted to rec.aviation.soaring
-Dave
Dave, if you look around youtube long enough, you will find that a AAA battery can make a fire. Certainly a 12V lead-acid has enough juice to do that if circumstances are right. The overwhelming evidence of many years of usage of LiFePo4 chemistry in glider batteries suggests that they are as safe as the old gel-cells. Give progress a chance, I'm not saying be a Progressive.
Herb
Old November 14th 18, 01:08 AM posted to rec.aviation.soaring
Mark, When K2 was fairly new on the market I contacted them asking if Battery Tender Jr. is okay and safe, they replied that it is perfectly okay and nearly the same as their charger. I also contacted Battery Tender Jr. with the reverse question and they said the BTJr is fine for LiFePO4. I used the BTJr for years on my K2 with no issues. They're about $25 on internet sites.
Old November 14th 18, 04:18 AM posted to rec.aviation.soaring
kinsell
On 11/4/18 3:51 PM,
-Dave
Herb
If you come across a YouTube video of an AAA battery filling a cockpit
with toxic smoke, you be sure to post the link, OK?
Meanwhile, this is the sort of progress I can live without:
https://www.pilotsofamerica.com/comm...-fires.102016/
-Dave
Old November 14th 18, 09:40 AM posted to rec.aviation.soaring
Jim White[_3_]
Not all LifePo4 battery chemistry is the same. When I fitted 2 LifePO4
batteries to my 27 I chose A123 because of their chemistry and BMC. See
he https://tinyurl.com/ybmof8qh
Unfortunately theses batteries were only 4.5AH but because of the way the
voltage stays good until the BMC shuts the battery down I have never run
out of power.
Also unfortunately, I am not sure that the 12V7 form factor is still
available so I am hoping that the rated 5000 cycles will see me out!
Old November 14th 18, 03:34 PM posted to rec.aviation.soaring
Dan Marotta
The original poster called the battery a "Lithium Iron".Â* Later on in
the thread someone said, "Lithium Ion".Â* Which is it?Â* I haven't yet
heard of a Lithium Iron Phosphate (LiFePO4) battery causing a problem.Â*
Stemme installs LiFePO4 batteries in the S-12 new from the factory.
On 11/4/18 3:51 PM,
them back in.
cells are safer:
batteries.Â* High charge rates and very high discharge rates seem to
summer.
-Dave
Herb
-Dave
Dan, 5J
Old November 14th 18, 04:03 PM posted to rec.aviation.soaring
On Tuesday, November 13, 2018 at 11:11:52 PM UTC-5, kinsell wrote:
Have you measured the amount of charge you're getting into the K2's? It
will be considerably less than the rated amount due to using a lead-acid
charger.
Also, if K2 has cell balancing capability, it won't be used because your
Battery Tender doesn't put out enough voltage to make it work.
Many simple lead-acid chargers reach up to around 14.2-14.8 volts. That voltage would suffice to charge an LFP battery to well above 90% capacity if it stays there for a while. If it quickly shifts to "float" at 13.5V or so then it won't do well in charging LFP. So simpler is better in this case. Measure what your charger does. And disconnect it after several hours, don't leave it on "float".
Old November 14th 18, 05:11 PM posted to rec.aviation.soaring
On 11/4/18 3:51 PM,
using those things routinely put on a fireworks display during a crash..
Old November 14th 18, 07:55 PM posted to rec.aviation.soaring
kinsell
charger.
Hate to break this to you, but at $24, the Battery Tender Junior is one
of the cheapest chargers on the market, and is fully featured with a
float mode.
14.2 volts wouldn't begin to charge an LFP to "well over 90%" as you
claim. If you found a charger that delivers 14.8 volts under load, then
it would overcharge an SLA and would be considered defective.
If you're going to spend big bucks for an LFP, you ought to get a proper
charger for it. Still waiting to hear just how much charge the K2's got
in them from a BTJ.
-Dave
Battery Chargers Stan Amyett Soaring 2 March 12th 04 05:27 AM
Solar Battery Chargers Jay Honeck Piloting 32 February 22nd 04 11:17 PM
Battery Chargers Mike Rapoport Owning 11 December 2nd 03 11:55 PM
Rechargable AA batteries and chargers TripFarmer General Aviation 2 October 17th 03 06:34 PM
Rechargable batteries and chargers....... TripFarmer Products 2 October 17th 03 06:31 PM
