Pay-out winch video
Old October 12th 04, 06:17 AM
ashburn.mail
After getting the bug again, I turned up this really nicely engineered
pay-in
static tow setup.
Ignore the 1500N rating listed, the sailplane version has a much thicker
side wall.
It's rated to 1500lb tension.
A follow up e-mail suggests a tost release can be used for a quick
release, and the
auto-level kicks in for the electric motor powered retrieve.
http://www.tow-systems.com/en_vijesti.php
It is NOT cheap though!
Chris
Gary Boggs wrote:
Bill, this is a payout winch. The starter motor is for reeling the line
back in after the truck mounted winch gets to the end of the runway. Check
out the video:
http://www.nwskysports.com/
"Bill Daniels" wrote in message
news:QIV6d.147361$D%.8795@attbi_s51...
"Gary Boggs" wrote in message
My guess as to the force on line is probably something like 300lbs? I
think
the next mod we will incorporate will be a tensiometer on the line.
Right
now we use a pressure gauge on the brake line and as the disc brake
heats
up, the pressure required to get the correct tension on the line goes
up.
It would work much better if our winch operator was able to monitor the
actual tension on the line, instead of the pressure on the brake. If we
could find an electronic tensiometer, we could program it to operate the
brake, but this would make the winch even more complicated and
expensive.
I've searched the web for available tensiometers, but found nothing
suitable,
so I think we will just build one into our system.
The tension on the line should be about the same as the gross weight of
glider. 300 pounds will result in a poor launch. The tension on the line
is the result of cooperation between the pilot and the winch operator. No
matter how hard the winch tries to increase the line tension it won't
happen
unless the glider pilot pulls up.
A better idea is to use an RC model airplane telemetry package like RCAT
to
send the glider airspeed to the winch operator and let him control that.
The glider pilot can then control the line tension with the elevator.
I think it will require more power than a starter motor for that though.
Bill Daniels
Old October 18th 04, 09:56 AM
jp
Hello,
We are doing glider launches with a car and the altitude you are
getting is about the same with a static line. We can use 1/3th of
runway lenght of rope and need 2/3 for getting the max height which is
almost the 1/3th!(0 wind condition) The real out system is much safer
if you could provide feedback to the tension of the drum with a pre
selected force. And there is also less wear and tear of the dyneema
(only small part is in contact with the surface) If you could develop
a system we are very interested. What if you contact the winch docter
http://www.monkeytumble.com/winchdoc/winch.htm he lives in your area
but doesnot react on my emails....
greetings,
JP
Preventing Landing Accidents Video Thomas Knauff Soaring 0 March 21st 04 02:01 PM
Why is Melissa Morrison the *STAR* of the video... X98 Military Aviation 1 March 20th 04 07:39 PM
Winch design c1rrus Soaring 10 January 19th 04 12:18 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
