first Comp
Old December 25th 18, 03:17 AM posted to rec.aviation.soaring
Roy B.
Default first Comp
Don't worry about the glider - get yourself in shape:
1) Practice setting a task on every flight, then fly that task, then analyze that flight on SeeYou. What could you have done better?
2) Try to crew for somebody else experienced (even if only for a couple of days) before your first comp. You will learn a lot in a more relaxed atmosphere than when you are competing.
3) Get the contest waypoint & airspace files downloaded early and study them. Download comp flights from the last contest at that location and see the lines that successful competitors used. Learn where the airport and land out options are.
4) Have fun and be mindful of Gary Ittner's saying: Competition is just flying cross country as efficiently as possible.
ROY
Old December 25th 18, 08:29 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default first Comp
On Sunday, December 23, 2018 at 12:00:04 PM UTC-8, Neil Croxford wrote:
folks
I am entering my fist Comp flying an LS4 in June 2019
Now i know i am not going to win and it is all about taking part, but
what can i do to the glider to gain more points
Welcome to the addiction Neil.
It would help a bit if you mentioned what country and contest you are flying. National rules vary from country to country (UK, Australia, and US are all different for instance). Read the rules for your country - particularly starts, finishes and penalties.
I agree with others, knowing how to use your flight computer under pressure is the most important thing. Second is making sure all the bits on your glider that need to work in a contest do in fact function well so that you aren't running around like a chicken with your head cut off prior to grid time. After that, if the finish on your glider is shot, getting things smoothed out as best you can would help. If seals are missing that's next and beyond that don't forget gap-sealing tape. If your pneumatics are shot and you can't get energy compensation to work you will end up in crappy thermals, so a few flights doing pull-ups and watching the vario (if you haven't already) would be useful. Beyond that, take starts on the early side so you get home and study the weather forecast (get a subscription to one of the glider forecasting services).
Best of luck,
Andy Blackburn
9B
Old December 25th 18, 04:46 PM posted to rec.aviation.soaring
krasw
Default first Comp
Looking back at my first comp it was all about learning to fly a lot faster than alone. Learning curve is pretty steep, it is much easier to find yourself a nice gaggle and see what others do, learn the rhytm of fast flying and see some uncomfortable decisions, low saves etc. that you would mostly avoid flying alone. It takes some practise to keep up with fast group, after that you can learn to do things yourself.
All of this of course if your aim is to get most points.
If you want a fast lane to comp flying, get a good twin (Duo etc.), national level pilot to the backseat and fly with him.
Comp Monster and Comp Air 6 [email protected] Home Built 0 July 23rd 17 03:50 PM
Comp Monster and Comp Air 6 [email protected] Home Built 0 July 23rd 17 07:16 AM
NSW State Comp pictures are up Mal Soaring 0 November 29th 05 12:59 PM
1000k comp task Mel Dawson Soaring 0 July 5th 05 09:22 PM
Boeing wins MMA comp Neil Gerace Military Aviation 24 June 29th 04 07:51 PM
