Yes, thanks, that's just the one I had in mind.
I was wondering if anyone was using a more "off the shelf" component though... Try this: http://www.md-flugzeugbau.de/flymic.html |
I once self-made one by extracting the mic capsule
from a 25€ hand-held PTT-mike (the type used with ground VHF units) and wiring it to the mic harness of the radio (Becker AR3201). It was cheap and perfectly functional. You need some soldering skills though, and you may want to insert it in the panel in a presentable fashion. I had glued the capsule behind a hole on the back of the panel, and glued a black round metal grille on the front (this latter taken from a discarded walkman headset's earpiece!). If you want to see the effect, go to www.segelflug.de on the segelflugzeug-testberichte page, find the LS7WL test report and check the picture where my instrument panel is (the one with a Filser DX50 on the top row): the home made mic is on the right hand of the panel at mid height. Good luck! At 14:06 28 September 2004, Ludovic Launer wrote: Yes, thanks, that's just the one I had in mind. I was wondering if anyone was using a more 'off the shelf' component though... Try this: http://www.md-flugzeugbau.de/flymic.html |
Yes, thanks, that's just the one I had in mind. I was wondering if anyone was using a more 'off the shelf' component though... Try this: http://www.md-flugzeugbau.de/flymic.html Hi, Were you able to buy that microphone? Does it work as well as a gooseneck? Is there a retailer in the USA? Thanks |
Advice: Boom Mic or alternative | Vassilios Mazis | Soaring | 0 | March 9th 04 10:09 PM |
Bell X-1 sonic boom. | Ed Majden | Military Aviation | 4 | December 2nd 03 05:20 AM |
Any problems: headsets to handheld? | Michael Horowitz | Home Built | 9 | September 30th 03 04:57 AM |
Icom Boom Mike | Kevin Neave | Soaring | 2 | September 25th 03 09:39 AM |
Telex 500T Microphone... | DGRTEK | Soaring | 0 | July 15th 03 10:55 PM |
