Replacing a multi-probe socket
Old March 13th 19, 02:59 PM posted to rec.aviation.soaring
Dan Marotta
Default Replacing a multi-probe socket
Oh, Jeez...
So now skin oil is suspect?Â* I learned about that little trick for
assembling and (especially) disassembling my fishing rod when I lived in
Alaska... :-D
On 3/12/2019 3:13 PM, Tango Eight wrote:
On Monday, March 11, 2019 at 9:52:53 PM UTC-4, Roy B. wrote:
Dan:
For some reason the O-Rings on my South African glider get really dry & stiff. We use a very light coat of silicone "plumbers grease" on the probe about twice a year to fix that (petroleum based grease attacks the O-Ring). My US glider in Massachusetts doesn't have the problem.
ROY
If everyone used this, we'd have fewer problems: https://www.amazon.com/Dow-Corning-V.../dp/B001UHMNW0
What I use on the o-rings I rely on in my day job, as well as my triple probe socket.
T8
Dan, 5J
Old March 13th 19, 05:55 PM posted to rec.aviation.soaring
JS[_5_]
A previous thread suggested using ACF-50. I've used that since. $1.65 from Aircraft Spruce. It is quite a thin liquid and unlikely to clog the tiny orifices in a multi-probe. The Dow-Corning or Super-Lube stuff can clog things.
But none fix a socket that leaks.
This seems like the thing to do: Rent a tool from Wings and Wheels for $25 plus $3.00 for the 3 O-Rings.
https://wingsandwheels.com/aircraft-...ntal-tool.html
Proper Way to Insert Multi-Probe Dan Marotta Soaring 18 February 19th 18 01:31 AM
Prandtl multi probe receptacle used for TE only? Matt Herron Jr. Soaring 12 February 15th 18 08:32 PM
castellated socket Stuart & Kathryn Fields Home Built 1 June 3rd 08 12:37 PM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 04:54 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
