#11
My AME swears by Tri Flow Superior. If it's good enough for rotor heads, it should work for gliders.
On Thursday, April 11, 2019 at 12:16:39 PM UTC-4, wrote:
What oil to use for lubricating control system bearings and components. Dan Checked my Ventus maintenance manual: "The Ventus" should be lubricated with acid free grease and oil customary in trade" "ball bearing with sealed grease filling do not require service"-are these the bearing with a felt enclosure ? Dan |
wrote on 4/13/2019 9:01 AM:
On Thursday, April 11, 2019 at 12:16:39 PM UTC-4, wrote: What oil to use for lubricating control system bearings and components. Dan Checked my Ventus maintenance manual: "The Ventus" should be lubricated with acid free grease and oil customary in trade" "ball bearing with sealed grease filling do not require service"-are these the bearing with a felt enclosure Bearings with a felt covering are definitely not sealed, nor even shielded. On my Schleicher gliders, I stick the straw (one a can of LPS2) underneath the felt and give the bearing a show every few years. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
Thank you all for the advice !
Dan |
A big problem, especially with an older glider is getting to moving parts that you can't see, and certainly not reach with a needle and syringe. I've spent many trials making a PIK-20B's controls operate smoothly. Bearings deep inside the wings and tail were intended to be "permanently lubricated", but that permanence was intended for perhaps a decade, not four.
My current solution is to run a small plastic tube along a bendable but otherwise rigid long rod along with a cheap USB endoscope, both attached at the end of the rod. This allows seeing and reaching several meters into structures to drip lubricant on redirects, rollers, and belcranks far inside. I use LPS-2, as it lasts for a year on most moving contacts. Flap hinges seem to dry out faster so they need a second application mid season. |
On Sunday, April 14, 2019 at 4:29:43 PM UTC-4, Wit Wisniewski wrote:
A big problem, especially with an older glider is getting to moving parts that you can't see, and certainly not reach with a needle and syringe. I've spent many trials making a PIK-20B's controls operate smoothly. Bearings deep inside the wings and tail were intended to be "permanently lubricated", but that permanence was intended for perhaps a decade, not four. My current solution is to run a small plastic tube along a bendable but otherwise rigid long rod along with a cheap USB endoscope, both attached at the end of the rod. This allows seeing and reaching several meters into structures to drip lubricant on redirects, rollers, and belcranks far inside. I use LPS-2, as it lasts for a year on most moving contacts. Flap hinges seem to dry out faster so they need a second application mid season. With the exception of WD-40, used for it's original intended purpose, I try to avoid anything that come in a spray can. Spray stuff gets all over and collects dirt and makes repair work more complicated on composite ships. If the lubricant dries out, it's probably not the right stuff to use. Lubricating does 2 things- reduce friction and wear, and keep moisture out. UH |
On Thursday, April 11, 2019 at 2:16:11 PM UTC-6, JS wrote:
Whatever happened to Marvel Mystery Oil? That's a mystery...…….. |
On Tuesday, May 7, 2019 at 2:32:38 PM UTC-7, K m wrote:
On Thursday, April 11, 2019 at 2:16:11 PM UTC-6, JS wrote: Whatever happened to Marvel Mystery Oil? That's a mystery...…….. It took nearly 4 weeks, but K m wins! Jim |
Grob gliders, new TM about control system pulleys | Robert M | Soaring | 5 | February 14th 14 04:47 PM |
latest control system! | Jordz | Piloting | 0 | July 23rd 07 02:48 PM |
sim cockpit control system | El Baron Rojo | Simulators | 0 | July 28th 05 09:32 PM |
A New Air Traffic Control System On The Horizon | Larry Dighera | Piloting | 0 | June 17th 05 03:03 PM |
Tactical Artillery Command and Control Information System (TACCIS) | Roberth Andersson | Military Aviation | 0 | May 25th 04 11:33 AM |
